Home » Modeling » TMF (Xtext) » Guava dependency and compatibility
Guava dependency and compatibility [message #1022447] Thu, 21 March 2013 22:32 Go to next message
Hallvard Traetteberg is currently offline Hallvard TraettebergFriend
In https://bugs.eclipse.org/bugs/show_bug.cgi?id=370651 is it noted that
Xtext should be compatible with both guava 10 and 11, to allow other
plugins (e.g. Kieler) to pull in guava 11 (when Xtext depends on guava 10).
The bug is closed as fixed, but when I recently installed Kieler, I got
the same problem as reported in the bug. I believe the offending class
this time is EclipsePreferencesProvider in xtext.ui.
Hallvard
Re: Guava dependency and compatibility [message #1037199 is a reply to message #1022447] Tue, 09 April 2013 09:24 Go to previous message
Tim Geisler is currently offline Tim GeislerFriend
Member
Hi all,
is there any solution or workaround for this problem? Xtext (2.4.0) seems to require Guava 10 which leads to the abovementioned problems if other plugins are present which require Guava 11.
Tim
Previous Topic:RFC: Indentation based grammar
Next Topic:GraphView style grammar breaks in Xtext 2.4
Current Time: Thu May 24 14:16:45 GMT 2018
Powered by FUDForum. Page generated in 0.02148 seconds
