Re: Opening old UML diagrams? [message #1021099 is a reply to message #1021088] |
Tue, 19 March 2013 14:10 |
Ed Willink Messages: 7655 Registered: July 2009 |
Unfortunately no UML2 Tools developers were available to accommodate the
MDT/UML2 migration from 3.x to 4.x that introduced UML 2.4.1 support,
consequently UML2 Tools is not installable unless you also use a
pre-Juno version of MDT/UML2.
One day the tools may support UMLDI. There is a common GMF Notation
influence so diagram transformation may not be totally impopssibl;e, but
I doubt that it's easy.
Ed Willink
On 19/03/2013 14:01, Camille Letavernier wrote:
> uml2tools and Papyrus are two different tools, and each of them
> support its own format. The only thing you can reuse is the *.uml
> file, which contain the semantic model (i.e. no graphical information
> on the diagrams and layout). As far as I know, there is no migration
> tool between uml2tools and Papyrus. However, you may still find a
> uml2tools release somewhere... although I don't know where you should
> look to find it.
> Camille
Re: Opening old UML diagrams? [message #1021120 is a reply to message #1021099] |
Tue, 19 March 2013 14:59 |
Toralf Lund Messages: 70 Registered: July 2009 |
Member |
So, simply put, if you have used Eclipse to create UML diagrams, then upgraded the software, you have to recreate everything more or less from scratch? Pretty disappointing
Ed Willink
I did test that option briefly. To me it seemed unnecessarily cumbersome to use in that there is no way to just translate the model into a diagram - you have to add each and every item via drag and drop. Or have I missed something?
Also, I couldn't find a way to create a component diagram, which is in many ways what I'm most interested in. Isn't this supported?
- Toralf
> look to find it.
> Camille
FUDForum. Page generated in 0.02204 seconds
