Home » Eclipse Projects » BIRT » PDF Pagebreak Problems(How to break inside instead of before on long row content?)
icon5.gif  PDF Pagebreak Problems [message #1020725] Mon, 18 March 2013 20:10 Go to next message
Markus Dresch is currently offline Markus DreschFriend
hi community,
i also posted this topic over at birt-exchange, not sure if this is considered crossposting (/org/forum/index.php/topic/29023-pdf-pagebreak-problems/), just trying to increase my odds.
i got a problem when generating PDF reports. when i got some short row content followed by a long row content that doesn't fully fit onto the same page, the page breaks before the long row content, resulting in almost blank pages with only one row of text.
here are two examples, the first one is a html table with two table rows. i managed to set the pagebreak using inline CSS on that one to get the desired result.
example 1 (html table with 2 rows):
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.23" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 4.2.2.v201301221637 Build &lt;4.2.2.v20130206-1509></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">72</property>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="7">
<property name="pageBreakInside">avoid</property>
<text-property name="content"><![CDATA[<table style="page-break-inside:avoid">
<tr style="page-break-inside:avoid;">
<td>
Short Text
</td>
</tr>
<tr style="page-break-inside:auto;">
<td>
<p>Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text </p>
</td>
</tr>
</table>]]></text-property>
</text>
</body>
</report>
the second one is a detail view with two block elements in the same column. same thing happens with any combination of grids, tables etc. i believe i tried every possible combination of page breaking settings on these elements without success.
example 2 (ignore the missing data source/set):
<property name="layoutPreference">fixed layout</property>
<styles>
</style>
</styles>
<page-setup>
<property name="type">a4</property>
<property name="headerHeight">30mm</property>
</page-setup>
<body>
<table id="847">
<column id="854"/>
<detail>
<row id="850">
<cell id="851">
<label id="855">
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<text-property name="text">Short Text</text-property>
</label>
<text id="856">
<text-property name="content"><![CDATA[<p>Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text </p>
<p>Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text Really Long Text </p>]]></text-property>
</text>
</cell>
</row>
</detail>
</table>
</body>
</report>
on repeating details this leaves me with loads of almost empty pages. is there any standard way to fix this or some workaround? version is 4.2.2
any hints and pointers very much appreciated.
Re: PDF Pagebreak Problems [message #1020857 is a reply to message #1020725] Tue, 19 March 2013 03:40 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
A solution on the second could be to set the display property for both elements to "inline". The setting can be found at the bottom of the general section of the property editor, for each element.
Michael
Developer Evangelist, Silanis
[Updated on: Tue, 19 March 2013 03:43]
Report message to a moderator
Re: PDF Pagebreak Problems [message #1020899 is a reply to message #1020857] Tue, 19 March 2013 06:26 Go to previous messageGo to next message
thanks for the tip michael. i'll use that as a workaround for now. however, the problem persists with repeated detail rows. is there any way to fix this?
Re: PDF Pagebreak Problems [message #1021153 is a reply to message #1020899] Tue, 19 March 2013 15:27 Go to previous messageGo to next message
Please log a bug for this and post the bug info in here. I'll let you know if I find a workaround.
Michael
Re: PDF Pagebreak Problems [message #1021154 is a reply to message #1020899] Tue, 19 March 2013 15:27 Go to previous messageGo to next message
Michael
Re: PDF Pagebreak Problems [message #1021155 is a reply to message #1020899] Tue, 19 March 2013 15:28 Go to previous messageGo to next message
EDIT: Sorry for the duplicate posts. The newsgroup was acting up and not showing my post. Smile
Michael
[Updated on: Tue, 19 March 2013 15:31]
Re: PDF Pagebreak Problems [message #1021157 is a reply to message #1020725] Tue, 19 March 2013 15:28 Go to previous messageGo to next message
Michael
Re: PDF Pagebreak Problems [message #1021158 is a reply to message #1020899] Tue, 19 March 2013 15:29 Go to previous messageGo to next message
Michael
Re: PDF Pagebreak Problems [message #1021214 is a reply to message #1021158] Tue, 19 March 2013 17:15 Go to previous message
Sorry again for the duplicate posts. Eclipse.org was not showing my post, which it does at times, so I hit submit again a few times and like 3 minutes later, they started showing up. Smile
Anyways, Kris was working on your issue, this morning, so we talked about it a bit and he came up with an interesting workaround to use while the bug is not fixed. It's posted on your question on BIRT Exchange:
BIRT Exchange Forum - PDF Pagebreak Problems
Please still log the bug and post the bug info in here, though. Thanks!
Michael
Previous Topic:Bug in Crosstab Aggregation
Next Topic:crosstab get aggregate value in javascript
Current Time: Mon May 21 07:35:55 GMT 2018
Powered by FUDForum. Page generated in 0.02143 seconds
