Home » Newcomers » Newcomers » A potential eclipse juno bug?(A potential bug)
A potential eclipse juno bug? [message #1019041] Thu, 14 March 2013 23:31 Go to next message
David W is currently offline David WFriend
I've found a problem and I think it might be an eclipse bug. Please see my attachment.
I am on redhat 5 x64 running juno. The following code prints out checkpoint2. However, eclipse grayed out checkpoint1 and checkpoint2 . Appraently, eclipse uses a different ULONG_MAX value as from the gcc compiler. Is this a bug from eclipse?
#include <stdio.h>
#include <limits.h>
int main()
printf("%llu\n", (unsigned long long) ULONG_MAX);
/* prints 18446744073709551615 and checkpoint2 */
/* but hover mouse over, the ULONG_MAX shows (9223372036854775807L * 2UL + 1UL) */
#if (ULONG_MAX >> 31) == 1 <---- grayed out
printf("checkpoint1\n");
#elif (ULONG_MAX >> 63) == 1 <---- grayed out
printf("checkpoint2\n");
#else
printf("checkpoint3\n");
#endif
return 0;
  • Attachment: error.jpg
    (Size: 108.67KB, Downloaded 58 times)
Re: A potential eclipse juno bug? [message #1019542 is a reply to message #1019041] Fri, 15 March 2013 23:58 Go to previous message
Can someone just copy and paste the code and let me know if you see the same problem? Please make sure you use 64 bit machine.
Previous Topic:SWT Problem
Next Topic:Editing files opened through remote system explorer
Current Time: Wed Jan 24 02:14:11 GMT 2018
Powered by FUDForum. Page generated in 0.03452 seconds
