Home » Eclipse Projects » Rich Client Platform (RCP) » Command contribution to EditorActionBarContributor
Command contribution to EditorActionBarContributor [message #1018883] Thu, 14 March 2013 16:05 Go to next message
Jan Krakora is currently offline Jan KrakoraFriend
I have an editor with its EditorActionBarContributor class. This contributor contributes actions to a toolbar
that is visible only when the editor is active.
Is it possible to declaratively contribute a command into this toolbar using the command framework?
Using eclipse plugin spy I can see the menu uri
toolbar:cz.tigra.spl.client.modul.slide.editor.PartieEditor?after=org.eclipse.gef.zoom_in
but using this menu contribution
<menuContribution
        locationURI="toolbar:cz.tigra.spl.client.modul.slide.editor.PartieEditor?after=org.eclipse.gef.zoom_in">
    <command
         commandId="my.dummy.command"
         label="Test"
         style="push">
    </command>
</menuContribution>
doesn't show anything.
index.php/fa/13861/0/
  • Attachment: image.png
    (Size: 55.77KB, Downloaded 643 times)
[Updated on: Thu, 14 March 2013 16:06]
Report message to a moderator
Re: Command contribution to EditorActionBarContributor [message #1021911 is a reply to message #1018883] Wed, 20 March 2013 23:07 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Hi Jan,
You probably have to define a handler as well. Did you define that command
with the command extension point?
Wim
> <menuContribution
> <command
> label="Test"
> style="push">
> </command>
> </menuContribution>
> MB5!.1PT*&@H````-24A$4@```\X```%_"`(````7?@?V`````7-21T(`KLX<
> MZ0````1G04U!``"QCPO\804````)<$A9<P``#L,```VY^=Z;<_9]N.Q,TM+3#Y:<OK_XU/W%)Q.!12<2%YZX)Y'`6'`<N+O@
> M#Y%XA6,44J:'H.7QA(7`B81%)^X18.13]Y?`B<XD+8.3GGNTXOQCYXLI*R^E
> MKKZ2ON9JQKKK6>MOYFRXE;OI=OXFUX+-96!NQ9L]BC>T7_>_?(C[;'OK!
> MYN!W-P1,6N,[<:7/A)7>;SA?IRP//U98`'\!K'_=6E$DL`MU>6N+ZR
> MF/#RXMLO+U)X"5@(W+(-M'%]>1'K[D9&6PKC>XY?[C7>&:;A^^9J_
> M/GCRAI!W-H5-=8F8MC5J^O;8]W?&??!;_$>[$S[>F_CIOON?D?/M')O#=B6S"R9SO@5.$'X#3N1)Y
> M/SH,-!8ZYK+1.&Q\/4-M8PM-%SUBX]/B!>;^<$J"35O#*08_"/9A-.
> M`%G#RS?'&9E&9&AK3F1^>S(+^.Y4-KFN,SD_GLW]\6S>S'-Y/YW/__E"@43A
> M+Q0HL)J?SA?\="Y_YED@]'T+XZF??%_X'>Q+?WWWO_=\2WOOMOBGAU5GWU><?8"75_B\O-P;>&FY]XO+O0C+%%ZP"VE#ND!'@64*
> M+TC0ISXO+O?5LL)/A5*O@37P-V"Y;30M5_B_M"+@)>?`EU8.!K01>)$\0D<]
> M4!^D(_"E%0+2(!S-B40T+;7G$F$--.=U!&EP.K<7=9#7QR;PZLGXO;3"E\%_
> M0,OAARL!/^BE@+?"$N\75'B]L-A3C0?P_"*&^W.&+'1[;J'K<PN`VRJ<;@G<
> M9/Q+`)X^O^#F\POI(P/*"V^^0+CUPB(.N:<L<GUI,>'E)0#<?2A+W?@M">Y0
> MRSU>)\!]Q'/\"L_QSN1V!C>U">36YO,FL,IGXFJ_MQAKX!;C_S:P%@B8M"Y0
> M9++,>B!HBA'DD-1LTKH`,A3!$`$ZWTOM-9\!KP@K/-U9XC%_F/GZ9
> MV^M+75];?.O51<#-5Q;>>'G!]9><KKTT_^J+\Z^^,._R\_,N/3\7N/@<,`>X
> M\*\Y%_XY^_P_@%GG_O'+V?_ZY<Q__2QSFO`30ZB'-K^<^0?GBG\S;O@-Z^"79Q='GF
> M"W?%-)V*:
> M3L8TGXQK.1W7>CJN_CW-N$"SG$BAWS8RS`F>`>-.9
> M.X33A#:94T!LZZG8%N`DIQFF=()R/!IH.A[="/P1U7@L$J@7^3VB-=N#IFZ'MXIX*V!"#>U;6]XGP+G9G#S%F'RO=0=`.>VI=V2<^NU
> M6Z/:\'9)5!M.-'Z%SQN@VJO\)H)JKX6WL^#)&\/><0E_=TO4]&W1_N_OQ[GN?[$W\;/^#&6#;![AM@VI_>33MZZ-4M8^I5%N64::;DCWGSSS#
> M*)AYMN`G&\`ATH"VA"Y:5;)5`_>5D8_*:!K80M-+@]Q,)=G\-P3"&9%\
> M-:227@ZY(DF^J9(2YX;?4F3GUFCW$UHX<US;MBW`/3M;\FPBV<RPP:IG72R:
> M?:EH]N7B.802@>+9EPC0`"#^?;](NMKM6U_P6T;
> M5)O8]@RNVM2V#Q+;_GC_07>>Y^J]KWWP+9WW9T&@&KO`-6.>V<;
> MV';,E"W1DXEM1T[:1&SN>L`Y4.PA4>_QJ4.V`UU=RVWX%;!L\
> MF^#-(<*M4FU`H]>&D)9&JLV0;)M*&!%NP;E5)CVLJJUI1J&:*-FJQG1%9"65
> M>)D79-D5@7JUSLJ>+<)'H&A.)R.VT9WJ"V352;V#;<7,"#0;5%VRS%MHEPKX*34M46;7NIVVM+;K]*;)NJ]L(;1+6=B&J_./_*"[]>>?BVK-0$:MN*<$/9OFH#YRB*:L,I@.?F$KAP@_%SU;ZDJ/9\
> MKMK$MA75OO;*PFNO$K2V+:@VMVW.4E>`";>1:A,FK``\`(=46^W97+75GBUB
> M9-N#"K?WQ-7>;Q$4M]8@>#95;=FSURB>353;(]7L#J28W9+-MQ^;;STVWWQD
> MOO'0=#W)=.V!Z=K]MJN)K5?NM5Q.:+X$Q#==!.XT7F#$$<['-9R/JQ<YIR$6
> MJ#L;4RMR+J:>0`Z1-E+?!C)L/.'277K&A.8KB:U7$]NN/C!=?V"Y_M!R\V''
> MS<<=MY.-.ZW%+
> MZP9<@=3N6\E=-QYW7DMJOY1H.A/7]$=$GLN05/6^4]:2W[=AW>B"2M])SC#(UD,T/`&<7&BXV\P
> M$5?,6]!N[MP@TY)S&PBW*[%MTHRJ-EO8)F^1\.;H,P'>$%?[OD8
> M.G5SQ+M;(J=OBWEONV3;>R3;/I#T^<%'9&&;VO97OZ=^)2QL?W<\BZ@VM6UP
> M+*:>(,U,HW\^5_CSN:)?SC.*?H]G<\&5F62#88-2SO5)#*Z^5P=-M?'L\"VOU+9
> M=BJU"5W;5A:V=\L+VPG3J6H;+VQO!M4&PM^6%[;7@VJ'
> M$-5>"ZK-%K8#1-4&1-O6JS:@$6L]I-G@J@W(MBTI-4.1:4VE##O*T`JT5K(!
> M30,!;HW@J1K-U2.+J0K1=&74.BOKM1YY',VY9.0&!,U9](CG=01I9#H9C6<#
> MTCQ%O=8@JC:Q;?X#XC\UG6W##UT0;D&UO>C:MKB\36Q;%FZ=9U.4A6V=;:N$
> M6Z7:C.>9<`O.355;$FYBVTRU5;;]\A(WLKRMV+;':^0F0NXCDFV3FQ15;<FV
> MP7V):H,'"ZI-;)L(]]N&MDU56O$GM`X*M`S,:0O,E3$%Y1."\\TA
> M!>;00DMH47MX<7MX24=$:4=4:6=4>6=T>5=,17=L%=`35]USIZ8W'JCMNPO4
> M]=]K``:`1)E&!Q#;4]@@:OKOU?<GU/??Y=`S"L`<),B48&)Q0+4(F7!<50_,
> MG-(=7=D=5=X=7M(=6M0=D-OED=YUXZ'EPMWF,['UIZ+K3D35_!%1?3RBYA3\
> M<G*GZ5)"R^7[;5<235?NFZ7X*E,(N?2O=8+"<WGXIO.QC4>CZS9'U"Z
> MS3U_W?6,)6<?S3YV,1]M"WUW8]`!!K`^PCU<K80NR2J
> M
> M_U.ZL`VV_07;1@*J_7O:UT?3OA95&SS4$/F>2<R;:+?DW.041HO<,J)5RVC:,/A18MM<
> MN`T]FQREGLT7LV>2Q>S"69>*YEXIF0>&#7I]JW+A:AE
> M0!F`^D6NU=!@P:U*4/!?KY=#KSE72V==AHNESGVN0"W<9#.)>FV;V78JJ/;G
> M1Y)GL&TD1+4?@VI_<N"AO(V$UH:P-^DVD@GK@J6%;6+;KZT"U::VO8+:-MM&(BULBY(MHW%K#:2-0ZH-
> M&*DVP'W:L)X=TJ!U:(>1K%'CN':0#96C\5U`K;.*L]J`C:,YBP@_$:`YD0;Q
> MO`Y"AZ73T'@VH,R0(.NU!I5M\Q^0\B,SLFU@*+;-A7NQNVXS"57MP6SZT4*LVVZ3*.Q;=7"MF3;Y+_0:K:1O,E4V]BV^0JW2J.)
> M;4MKVS95F]@V56T835C8)B<EJBUM(W'GMKV$V_8KBVY*"]O2-A))M:5M)$2"
> MB0TK:]N`J-J";1.X:DO";:C:@$:U"8IJ2[;-55NR;2K<@FT3J&ISVR:;2<A^
> MDD4`"+>@VL2V)=6F"]N2:KMJ))NA4VT#VQ946^79;PWFV2(VA)LB2;;.LV6X
> M9`/J80755GLV4>U4DP5(:3.GM)J36\R/6\R/FADFX&$3)ZG1E-1@>M!@NE]/
> M2*PS)=::)-2U)1K0RJD5X)6DP7V@G@(G:J`G)9@?-L%\+(]:
> MVI.!UHZ4MHX44V>JJ3/-W)5NZ4IO)UT@S=*38NIYU-J=U-2=
> M4-L=6=H=F-OMGMIY\Z'Y^@/PZ9;+]YJO)+;<2#*S-7W!Z:0?
> M#\7/V!GYWN:0:9M"WMD8#&\HD\C897O&RM]QCMSYR;"#6]_5+A5*]QJ7EW?$?<AM.U%CVV0;"=BVH-K?G\Q6/)M*-I7.
> MTKF7R^9=J?CU6N7\ZU7SKU<]7KEK]?@<CCSV'5=K9AS
> MM7S.E;+9ETM_(?)=#(Y.G/ML@;3.+2UR\\W<AL+M.!K;%H2;>K:\;T3>-$(6
> MLR\7SFM?X`RWP"&4`*N'0"N^&Y5'*&7"\<4M`(M(,$,+@U
> M$EO5:&Z0^JD:KK^&!@R56I>U"1^$HCF%B-A,>SH&U,L.N`Y-DVA!L@MGT6L"'<TDX2P;;_I6PC8<O;EUX`!-L6=Y)0U586MF7;EE1;
> ML2N65)MAO+!M[-EVMHYHA9A`1-G0M@7/-E)M'X4UWF\#
> MRIB"9XM+VM2S)X-J%UDLA90"LQG(-YOS9$PF#;DF4X[)E&TR95$R3:8,B<RV
> M-B!+(ML6K:TV:6O+:6O+E:&G8^>%6>7##('V]L+V]B*@HZ.XLFEW=&EV=JAUMRNWL*R'170$YG
> M2&%G>#$A@CX"8<4=844=H86$,*"H(ZRX'0@I;`_*;P_(;?=,;O"W]\:/GUSV%27L'=<PM[='#%M<\3T+9'306VW
> M1;^_+>K][='`>\`VJ(F:OBUJVM:(=S>'D_8;0\'+0;O?6AO`G=O9FPLW^3`E
> M7^&6A5NKVHO5"]NR;<,M3-D=.(;<?:MNV4+X^PA>WT
> M;\"V3X!JYS`-!0<E`@J2?:4<I).Y]<+;M8MNUR]V;5CBUK#4O7&I1Y.">R-4
> MPB%H`,T6W&+F746=NXPL#]L6;E&%1PYET\B9/+)7A*YD2]=81O3Z.EQF%5SF
> M@MOL2NL6N]8M=JM7<*U;=+MVX:V:!3?AEXVJ7^G5@7:#<Y,%;&\&G
> MUP6U;0PQ;PRUN(2W;X;;]M3P;:WR;8=R3\B26R;;B/9$#IA/;%MMK8MV+:_8MM$
> MM<6=)$2XG\2V";)5<PQLFZN8:&EJI>;"+=2HT#BT@W#5MF';X-D:Y$,2S%,)
> MLN]J$-IHS55";*,97X_8V!X:G[8/7@]NV
> MK>5M\EE)K6T;KVU3X;9AVT2UU=M(5*JM_8@D0&V;W58`:MOR\C:]CQC8-KFG
> MB+8-K`'AYK9-A%NP;5MKVQ3U(8"HMF+;DV`086T;;)ONVY8V;5/;?EVT;?DC
> MDH!DVR_H;)NM0]NU;4`4;N+9(D2X#6U[-EDUEVT;&()MJN&G@UH#9NAJ#"#?FR1N++&H1V0[#4*DE(+PRJ5OLJ2
> MMN391+4K+98*2KG97&8VEZJ!&H+)Q"BEE)A,Q293D<E4`!+,5!C*;6V%E**V
> MMN*VMA)*J8Z2UE;JJ.CNJ.CMK,3J.OJJNONKN_N
> M;NCI`1I?4U]?<W]_82!`4;+4T/&86/J:`+H237`3&`^#1+UO;UUE%J@
> MIZ>&4MW34TE_58#?&?*A;T)4/G);W<^WA7WX<Z8#\"_MT9.<PF?2IP813:6$.&&MSR^I43UN4FU;1/A?F6I.T`_2PZV^?NCQ%W3'-OM\Y+=D59NH-M@P
> MB",8)*CD_!M5"VFE;
> MX=6RS*,)S!MLE3DWR#KH+!-NL@;,;9L(-[=MAN9SD\.'QK/)8O8%LF`_YW+9
> MO&OD&IUN$;T&GU*"/A'A*";6N$&XZ"9W]'/P<YDZUG7RJ>!YY]
> MJW*Q>\URH?4MOF^;=&VV;YM>2>)#=OF:]M\)XGJ(Y+$
> MMH6=).03A+ZM22`
> M;-AZ)*]=`6CD58(-(@QN$WXZ.\@:;^DX2P;;)\HVTMDU5F]LV^<(0OXGR!R4EVDX2B.22IMK"V351;9]O>
> MBFV3;R.1=I(LOLULFPNWTS7!MNFF;6K;_Q1M>Q;%V+;U"*IML)F$"O?L<QK;
> M5I:W9=6F7T@B";>XMGV-("YL*VO;-U^3=Y+("]M+5;:MWT;BD&KK)!L8;$F;
> M&O
> M:&]O[.AH[.QL`KJZFKNZ6KJ/>;108&`,L3P?JJD(:%
> MLQ#8&=7`-%H9O;TMO;W-]#<!YMQ$NWMZ`'!NL.TJ*MS%W=U9[=T/&HO)K0<"Z_>Y5.\YGJ6TYG'WQ],^'Q/W(S=
> M<9_N!GN._^2W^,_VWOM\__U_'TSZZO"CKW]__,W1Y&^/I7S'@7+RMT<??WWD
> MX9>'DOY]\/NCO^HUVQ'VR/FKXE8NJFT"GK@]]>QU:XZ982CM@VW1M6L5_?V1\
> M=R+KAU.YQ$3/%X$6@SXZW:P!R09O!L->P7RSY!6Q;6-YFNYRY<!/;=@2M3-N#
> M>C9;1Y<\NWCVI1*P__G7*T&RX5>"I>X-R[V:P:W7!)C7!;6O"X;+[-P8VK4I
> M#"Z6LS&L"RK7!W6L#81?+>#WBC;0>-9>N</]RL81N*2'[
> M27Z0]I-(MBU],^`3H*QP4^AZ]K<P[.F<TDGKW"NV%-0.O&
> M$`O8\\\I@<@@;[,'4@YJ
> M#H(.FK[*KVFY9_UBMYH%M\A^$K!M.!&W;;J3A'TMR5?',K)WDNR,U^_;)CM)P+;Y3A*Z:1MLF^PD"5'O)!$^)2GO)*&J
> MS6R;"C<P`K:MJ)CL9W:46L)9@%=J-=H1%&4D6@PZJW%K0Q3W%6R;(1NV-*`H
> MM;9LF_45AG4(?D8-PNF&AC2"9FM`RK;
> MMK&VS83;Y@<EB6VKA9MXMF3;JK5MIMI:VV;'UG8
> M!FRJ-K'M-QU2;9UD`X)G3Q)@-0RJVB*"80,&*]G4IZE2OL&TP7S!L\NHPO;1=2SV7X2>,RE3T&XV9)V
> M&;5M0^$&2(V19)<QU'W![NN-9OKS.8&BP54NPGHZ&@&.CM;NKK:@.YN
> M$]#38^?>U`?S_0P1@88'0.$;FC"CHF&U]%7Q^<&C`+@'.W]/4U4<_F
> MJ]J]O6Q)&R2;>390TM.3W='SJ*DNNZ(@EM,>6MX<5D3TDEQ/;
> MCD?6[/8K77\S9]&YU)F_W__JP-TO#]S[]_YI''WQU+_?%$QLS3
> M63^?S9EU+G?.A;PY%RD7\F9?R)MU/O>7L]D_G<7]SM>]X9V^RNK#,`]KL+7*9IWYM6[)M\O5_ZK7M.\RV/]GW@-@V^^Z_WU.I:F>#C(*)@@V#%B^X
> M6;/$K6$%2+8_V"=X9_>6R/]Q3@Z6_QUIUWK-MCK5NC
> M!ES">S<0Y^X`00=-7^K>"#H+XCZ?+&^7,]L6-Y-0VZ96*J+5:T?02C:,PSV;
> M?0B2>S;9&`-RO/`VN4:09EGD2X%]RDZ_=7R]GR-M@V**FTF83:-A7N;Q74
> M,CUT8$!R@7!IYPM^N5@T]TKI_.L5"UVKES//#FW?&MWU6WP_./3O*=;CZ=93
> M6=:SN=8+!=:+A90"4KZ0;SV7:SV=93V90?P;M!O:@YKOBNL%X=X8:EX;T.+L
> MW;#4'6R[4K1M./6WIV_13DH?I-P`*M@V`:@O?`$B6MXEM\\TD
> M=]G7DDAKVX)ML^\DX5__)W]*,N2-M<'<MNDW`-*=)'[4MN5O`*3"+6TF,?R\
> M(Z"1;!5+1Q8B9$=5FG$J
> MK\ZY9=1&:VC;K*4XYI!0SB6B/N\04(^CF:H*X04D\->?_^:C4FV&]"-F/W3Q
> M6[=5MBT*MVS;&N'6V;:\PDV<6[1M0;CY)R;5JBUOVN:&+3JW;-O2VK:R;YO<
> M1`;?2<)V)^IL6[5U6MVE;X!4-FZ
> MS6Q;^@9`LV4^WQ
> MR]P83+AUGDT@'Y%T!FRJMMTE;95D3R+?P2=@;-L4`\EF>JW`K9J[M5"C\^PI
> MH-H@UL5LK[;%DF>QY%HL.?!(]VKGT]W;1=2YV2(WF#?;/5)`W3JSQ93:8$JI
> M-Z4UF=);R-9MT&ZH9YM)P+D9;#.)G?TDQ:VM1:VMA1)0)@C=H2790T+7U$'Z
> M:]2V#:K=`G1VM@*B;3/A9K8]',(M]U*0!Q0]6X:>EPDW6]YNT55]$54]H56=05
> MEM\9DM,9F&GQ2VOS3V\+RFH/RZ/+VR5\A3NF@FS=]DIOOW*_\:[=%
> MONL2.F5#$+Q5@6V_L9+OWF:V#>^)Q+:I9U/5EFR;;MKF:]O+P;:]B&VO]'EC
> ME63;:Z6U;;!MMK:]C7Q*\H.==\B?MJ&VS;YI&U3,LNZ_;]V3
> M0+0;G-LEO'M],!'N%=XM2]T;Y.5MW682.A_)MJ45;@?1&3;E6\FS?SR;_Q-9
> MTB1KYLI$E'G6K_)HWA%BV1G?OOCMP(,EZ+,UZ)L=ZH=!ZI<1ZO<)ZN\KJ
> M5D.I)L#3FQ76:V76*\7$O,]F6T^DDZ7N@P^L>^V^3[MB7AEC:3*,+-MVN2;<>]LQ6$&VP87;S/;U@BWK-H<E6TK,-NF&TADP+F5]6Q9M1=H5)O:-E^LX3<1Z5.2
> M\N=_R-V$JC:Q;L6V51MM:U38`.C+AID.)R]MP:F[;GN13DNQ/
> MV\BVS;9N+Y2W;E_A'Y04;7L.M6UEZS;7;IUABRBV_0^M9#/8-A+53A*P;2VO
> M-"55FQ[5FI(;3&G-IO160?><R3@#+49*!5UB9SM)ZMO;&\6U;;J\#<+=VMW=UM,#PFWJ
> M_8"BP@,#@-:>'8!U5"&-R4XAPM:S6^F2=F-?7PV5/>GFGJ2&GCN5=%6;DUI\7K4X'Z_QNU!K??C)O]T4TA.1WA!1T111U0QV;T=5MCAF=YQ%50[
> MNFY?8+F+6\'RRUES3B;///9HYO'DF2?3?SJ=!9+]Z^6BA3?*EKE6.7O5KO:N
> M7^?7N#ZP>6-0"P4*S1L"FM;Z-JSRKG7VJ%YZNV+AM>)YE_)GG<T"X?T=?
> M'$C\9/>=#W:0Y>UW-@;+M@UO<Z\O\WB%KCIPV^:J+;]+RG^;@&RV>Y6L1G#;
> MGL!L>VW`6^L"W]X00O9M$]N.>%>VZ1/:0@&J?R)YY
> M-G\67=)>>+MVN5<S."BX\M;H@5WQQ#Z/I%C_R+">S+:>RK&>S;>>*.YUE-@:9ED3\+A1]1'>3+<
> MDF5I'BKR"&3?"/N^D?.%LRX6TWTC50MNU2QQ;P#/7AO8OBFL>UOT`$@V_"(!
> M,GTLW7HBRWJ:7N/Y`@)(*@"%,_0:C]-K!!??1W^IV`+K!]I6_K<K*\
> M7>MT0]Y,`DI*%H"I;0M;M]7.K4=GVQS>0!KA^S.Y/Y"_!YE/?T$J=;I1N8@N
> M::\+;-L<V;GK3C_S/NV@\@W`)*MV_R^]4E_"NW^682^@=N7IA/
> MOP20?`\@"#?=22(O;ZL_*TDY\X^?":)JLQK"X*HMV?9<_@V`Q+;GT4W;PL(V
> M4VWX34!2;?[Y2/IW;;AJ20_JC-BK5YIGA2DI\IB-D@V8]SCFO9'U9:D2LO],LN]
> M$LO=0DM\H>5NL>5NB26AS'*_PORHECAW1ILYTV3.;#-GM!#_!A=/JC0EE)CB
> M\DTQ>::X`E-\D2FAU'2OG&EWVZ/:ML=UE'KRF`S4MZ4TM*4TMJ4*0`T<>E3;
> M^K"Z]4$5X3X%"DG5K0]K6LDXT+&I+:VE+0.DG&Y3*::?DJP$X;98:JEM-P`=
> M'2#<39V=;#-)2W<WV'9K3P\(=UMO+PBW2=
> M<14]D24]X45$LH-RB6V'%79'%G?'EG?%E'6%%W0%9W?XI;6"9+O=KBS7ON$'83
> M3+_%FG9$F9)Y%_-^.9WQ_;'D+P\]^&QO_$<[
> M8V3;GKC&#]\KRYS90A(?9MMOKO9_D]AV
> M$+?M36'4MJ/)7QX.&_CR1_?33MNY/9/Y\KF',9C*T*
> M-'2E7QLH,CCHHO51BO5INO5%EO5E#J2;`4ZB\7&J]
> M6&0]FT=\]`\F:B"C=ZS;HOHWAG2M"&E=1I=^Z=9M8MMDZ5?922)N)C%$
> M$6B'(5M'B&?3CT+"&7^]5@&>O=BM?H5WR]I`"WCV]ABR8'_P(;%2,&RXQLLE
> MUFL5UEO5UMLU'%?04+A8,%&XS!*R^JM<XSWKSCCXC:)G`UF_;UOAU;38M0Y>
> M0ABR6O_CN?R?SA?`KQ#DV_UN52YQKUWIV
> MI@=>_-]3R'HV3/AVM=6_
> M&NR?+VQ_3?^ZC;QOFRQO$]LFW@VXF81^4I-#E;;*VS9:W'WRXC]CV!W0S
> M"?FLY*ZH"3?3/(&^\IM]@=NV&826;B%%6Z^
> MSBT(-]=NK4!KX"O<4`;G%M!(-D/2,I6K,?@6!0.TMLW0F+1]N.P2B52$573<
> M8*&L8+#"K727X'JJ,5<BW`12EMJHSN@8]H6;0!N(YQT&Y(NB4.U^>44`8Q#A
> M!JAP<^`?`X`(MVI+B1I/->K=VTRX91:Y45Q!NR6H<'/G)GK]O&VX9R\D?T+R
> M18:@VNHE&W8'X9`_KT;P>)U\MQ7A#;*'A*&R;5&UA55M8MMD99I\Y7;`),FP
> MIQ@C?O>V5"D(-_]F$E`W*MSD#]S0S22@CV"3;]"_W#Z>?1$>_682)MP@K_2+
> MM]EF$O;'V\E77Q,#)L)-=GU(SDT^X*AV;DF5^8YGKA.5N$Y:K/%N0;,+$E0S/
> MB;8\V]XRMN]DF;4VD63:$(U;4T"OE:5KAM^4#5K)?@?8&#CN3D%:6
> MP"BEE+3%%)89+=1F&>W=37U]#75]W75];7E]_5E]G6E]K8EUS?^U$->4QM[LT$
> MV^[LS>'5#L*5+NP)Q14.X?8-A0B"KNC2K`JMT2
> MJVRKU_@V;`INVQ%EV1UGWI]@/OS`?/21^8]D2@KA
> MV&/SD233P7NF??&F7=&F+6&M&P(:5GM5+[U5YG2E8/;9K!_^2/GJ\(,9^^Y2
> MVPY[9V,0O$^!;<L%I$7)$"UZ6H$78<@GQ]?Y<MLFWS9MO(I2?K5
> MA.SM,^-`TA>''W]U-.WD!\+`
> ML;2!,WD#ETH&KE<.W*JQNC58/9NMWJU674OT%&3T$@AW
> MKO5D)MF'<(#L0[!NCQ)4DEVDNCV;<L(AJU'X],&_,BV
> M://O""=;1]B2-DCPHMNURSR;5ON9-L+O$C$#X-F''EF/9Y!?$JZ4DDMPJVJP!9FL@PT(6@'WA8N%*ZXFY$AD%X<XB>TL./B#+V]LB>S>2S20F8MML
> M\9MOC0;GZB-@V%>ZDC_<_H,O;]S_8<X\(-_EF
> M$K!M]LTDY$L`R?<`@G#SW=N11+C)\K;\Q]M#J'`K?/+5M@B3<=)V;K'#+
> MPJUW;BTJL2;?T@UJ15?'">1;!360S2J^`GX2_B\,JJ
> MH%=6!POH9%>%W%%/D(+67"G,B>DXY*3DO)I34^2C]B$GTIUWN'!F!`):*_L.5G%NP;<FY*=Y:EGA1%.%^`82;P;=QNW,6`6X,(MPR"V^KT$DV
> MH!@VB+6LVO3I2XL9?"\B$6YV$Z&0^PA5[=<!X0M)F&J3CR>2%1RBVA,!2;7)
> MJC,(L:3:7+(IH,M&5JWB'6`#>91J).=>SVUVUO-3UM:6W7^/>RK
> M1+(%U::>+2]IWW@=5)MN(!F_%)`E^S;Y!A+R)20$IMIO$L.6D21;Y=ET#\DJ
> MU1^LF;2:H3+LR0J#&+:,RJW7R0AN+>BUY-:@U`RJU`3UTXW$LZ>":H>E-8%;
> M!R?7!SZJ"4BJ\DLL]TTL]4$_BH-BBU,3RK+3K?'%]B3B@WWRLW)U:8
> M&7UM+WN++;>[/;>K/;>Y):>Q%J^JAU6T!.2UQV4W1V8TPV%\$+R)8"11=W!V1V^
> MJ2T>#VINQ9==C2FZ&)Y[-B3C7$@F./?-^#+WI#J?E.:`#$MP;F=806=07H='
> M:L>5^ZWD#]F$5&T>6$ZF6TQF6\[GFB_D*%_+,9[/-I])!NTV_)Q'AWAEIVAS<LM:W;H5K^8*K
> MA7/.9?UX/.5KL.V]\1_LB)J^.938-M])X@5O=M2VF5*VS^%LG_
> MVQ]1;?IQ%J+:?A/7^)-M).N#)FT(GK*)[-NF?^OT=L1_LBO]X3\)G^^]_
> M<?C15XZ_:H_DTA
> MG>L"S,Y>34O8MW9<JYA:SP;//Y9.]$ZZU5N]F8M@AG=:(
> M'FM4GS4:'+3?&@./?60].!2NVD+V8'C4$X6]4DQ^J?B#^NANV;;]6I="62O^9EL\LN#>RWY/2&\BUS%7:OU@=7ZR&I]3$FFCTE6
> M:Z*5'(J%:^P@R]N^\'.$'V*1]5R6]5BR]<"]_ITQG9M"VE;*_JD/6MIEMIW.H;1/(\G;*%T=2/J>V33CTF`HW^8N2
> MGQ#;3OJ8VO:'S+9W)G?%T>3L.F+H=A)LL;@L+1;A>BX!;OP1N3?[>
> M,"TPJ&?S;0;>+91+6);?/MU&33
> MMA]9@2:J36R;+4L3U=X0.`5,>JBL#P28<$\AXS#A]IU$A)M\_`YLFPGWA!4>
> MX)I4N,G:-H@IV7=!A1O\E7R)M=-5JKD@NR#<U'VI<`-LD9LL2(,QSV*<!91U
> M:PE63QHHR]B4.83G*,_/.<_AJLT]FZHVL6WZR4CZX4A0[04,8MNODC_23K_O
> MCWIOC"42UWP"(9U/5YIY-59ONU0;;G@BH#)M`_PPN35HEY3UOI.T;#.SQ%4;@TUZV54>@U639&5.F`J1:X!PR9L(HSS?U#E
> M_Z#2+['")Z',.[L#'4%D')LW:!#ZN(Y4/
> M:P*3JF$"8/:^]RI\&_<%$NJG5S?]ZBV+ZFZ[T%E[X-J
> MJMJM7+4?-Q/5CBWOB2CN"2OL"<[K"<SI"<PFWT,25D#VD$04@GRW^Z8TNS^H
> MN1E??C6VZ%)$[CE0BN)+52UJW;Z
> MEJUW+5IV-6_QE?QEMTI7>E2O\VUP"3'MBK8<3+3\D6PYFV6YD&NY6F2Y66ZY
> M76%VK>1`^4:)^4JA^6*N^4R&Z8_'9(5FVP5SSF;^^$?R5X?N
> M?
> M6K;X=LTJGQ:7L,Y=<?V''O:?R.B_4#APO6+`O6'`MVT@P#(`AAW6:XWHLX;W
> M4GJLH=W$30,M5G\05M*ON/B-'6U@_>M>^YP$UWCV[K"HV')[9H%
> M-RI_O5(VYV(Q>/`OH-IG\W\BGU\DMCU3*\U#!D8@4-7^Y7S![(M%<R^5S+]6
> MONAVS7*/QM5T>\P.^%TBD2Q+G\DA2NI:8_5MM89T$,F.'2#+O2"@C/OTD2T`
> MQ\"%=UF#S&3UUY4N;Y_+M1X'VWY`=\M$=&\(LJST:5JV
> M17?M3R0;RL_G66]4D'F&M)-?%>+IA8!>ITFDT\<42;CO@6W#3Q9LN]7J76>]
> M56:]F&L]F68]?']@=VS7EC#3.K_&%9XUBV]7SK]>.N=2X<_G\V:>):K]/57M
> M;XEJ9WSS1P;8]M=_I']UC/#EL;0OCQ*H<*?\F]GVD600[L\//YX!'`(>?7;P
> MT:<'DCW^M:H*5LBI9X6V`
> M3KL5F%<IALUY=079(*4CCKDJV#$TO8S0S%S@/Q>(5]QPV"?
> M!!"`7ZZ6^W"6:?`&7B9X<98"1+@E/%0L8;@SYQ9P?7$1@W\MU8L+973+V(MN
> MO2PB&?8K"JY$LI7[B/MKR^$FXDX^?4ALVX/LC7:FM@UJRUCE\R;Q;`+U;+9#
> MEZDV.)8_)6`R6#)'L>VI&C;J4(X&O@,0YPX`R)@P.-L?S+X!8Q79#C%QI>>;
> MU+9!.B7AOO4Z_0:/5XEMDS5C,%JNN52X7YQW$0`/9L)-G?O\<5K/><+<\R]P+KPP\X_4E`%7MI03BV4MO3UAVF^JUQ`K7-U>X28!GNTMZ+;$*8'HM
> ML1H\VVL2`23;FITB]]@"P".NT.-.D<?=8J_$<K^'-<&IC6"Z
> MD;GFF`)S7"%9X2:JG6^.RC&'95H*MG5?J#O#RHDH`R`
> M-U?YRVX-<@]6#7Z?4.9UMQ3,GLA]?*D7%&`RP+TR+ZK=/DE5`8_K@]-;PK+;
> M8HK:$JK:'C>3CUWFRY^2I%\"R#XH26AO!^$FS@W"36V;"'=W-Z&GIPF$FWZY
> M=0O]G")X,$$4Y:<#AN)C2K0(JLU6M?/8!I*FOI0&LK8-POVHOC>UB6P@R>E@
> MJ]J]B762:A?T!.?V!&1W@VJ'Y,%3LJ0-JLTV:GL^K'.]5WDCOO1J3.&EB)Q+
> MD;G7XXKI!I)Z.!J0:6&J'22K=G3=H=#*77YE&]R+5US/7W:M<*5;^3K?.I>@
> MEAV1X;#F79;E2:+E9:G&MLGC567P;+'Z-E":S3X/9L];L5FF^60;"
> M;3J?93J1;#IRW;\V*VV4+KN3//I/^_;%'_SZ0\.FNF`^V14S;
> M%`)O6/!&]N8J[PG.GN-7>,`[X.O+W"C,LUW!L*4:!KQ+>I#/LD![^N8(MOTF
> MV/8:O[](>QUYW'\ZJ_]R<?_MZGT!D
> M_T#T`&"-ZK=&]EDC>JUA7<2V@RW6@#:K3R/]C%VE]5H)V81P.L-Z])'U0*+U
> MM]B!+6&=ZP),J4-JI:"AJ10H/*)+PG`(G#42?KNPD,W-;F#;)=9S=/T>KG%7;/^6L(ZU
> M_JTK/!N6NL*O$Q7SKI3,ODA4^^=SLFIG_RAUH6#NE>(%-\J):OO4;PAJVQ!!<%O\G`%<&O`5G?$=7.`+XYGLX`V_[Z6-I7`%7M
> M+X^F?LE5.YD!JLT`U28<?/@I0&S[_L?[Y'>Q(^W'WW@]UWW_\-;#L.
> MF+XC=MH.8MOO;HN:NC7J';!M(MP1DUW")FT*>WMCZ-L;0MY:'S)Q/;'M-]<%
> MODF$.P"$^XW5?N.!57=88"HW0;(DLWVI9!QF,>K
> MH:OIKZWT>VTE^<.6#D$^W"D20`E\0E8S@@@JTX6G`JR!!--<5GY=`QE6*]\&
> MT+.\/A@&,P&$F4C(5T$%?94==#-Q%.%%6RE"OD=2@GT&0/HD@.8W*_A="UCN
> MHV49PYOB!;S"\01>!I8"'EJH;5/<.(L!]BEY^K54!@C+V-2P7UG,N*U`/DU(
> M8?^9E$*^M9K=1)8QU78G.S1`9%>0K_Z8L!(@JDU6E%=YLX5M\D$ZKMIL"P%7
> M;;J*R56;N3)XLTJI-P:]:Q]HSR'=I\"8:_TH9&/#I#4^=!<$V0Z^3M>,K#G";#UG
> M>6$N<-X0\.P7YP$7N&%37IH/@&13G"Z_XG2%`*I-#)NR"`#5OO;ZHNL$LG7D
> MQG@"DVS"!.\D@&$K3%SA-M&9\):S^ULK`6+8;RMPR9ZT6H:J]AKO*00N
> MV>_(K`.881.F$ORFKG>`#7HPO!NT&_?5**/&^3U0-Z^[-[NS-WY=;VQY;T11;VA!3Q"H=E87`,X=ED]4&PC-[0K,
> M,/DD-WDFU;G>KRH\DNI\R>X1,]FKG<M5VSVE_2I9U:X]
> M'$)4>Y-[\<J;!2MN%*WQJ-SHUV:O&[%IAOEYHOI!E.I5B.I)HVA-MVA+<N-:K
> M:MG-XOD7LW\YF?K-X?N?[M9I\MRB\Y9'O\%_.W@U=
> M)=A3SOCE`'N7]*2K$70I`MX6J6V_O=9OTOJ`R>L#W]D8/-4E=!JUVQ'SR
> MVYW/]M_[]Z&D;X^E_'PFY]?+Q8MO5ZWR;=H<UK$GON]H<M_9G+ZK)?UN-?U^
> M+?W!:%UH!['/P#:K7Q-9$W6OL=XJMUXI
> M(!IZ,M5ZY(%U;[QU1V3WQB#S&I_F%1YUX/1.U\KF70;5+IQU/A^<&#S[)T64
> MAP$8Y':-LU?CNH"VS>&=>^+)Q_Y.9Y-](&XUUH!6
> MLD4$-!ID&I04!)29:+;5FD,?P5!!21\S);5:HZAM^S9:72NM5PJMIS/);Q3[
> M/9'/CM"$:>>X&(
> M3NN=`;*D#9-GUP67(U\7:#=;VX;?+A+ZK3&=UG"3-:#!ZE%AO9IO/9MF/9K4
> MOR^N8WMXZP;_^I6>54MNESM=*YYZ>SV3^>R?K^5.9W)S.^.Y'^+7`\
> M[1O@C[1OCJ51U4[]ZB@C!53^!Y'\?>?P%<!AX]#GCT,,9P,&DSPX\^'3_
> M_4_V)7Z\+Y':]EVPWQNAWMT6_NS42;/N=S1%3
> M7,*G$-L.!=HA4%5DD^"6J`
> M07OJRFN,$617%G2".`+_IA=@%3BW#60I)^=2B;4.U01LH)Q=-?+3H,P6+L0^
> MFE>5V+:$_'L4A?]RY?/:"HGE&KPI7@SJW)X`$VZ*AX:7&42CWWQY\2V`?"F>`OWM$]8MN>;Q/;]B`[*%:XO;G<%<3TC:6WWJ"ASCFL67G<"S+T??QB@'GVC3>6W)`\^^:$93??7':;
> ML_SVQ.5@V!+.#*K:SNYOKV1X`),8JSQDSYXLL\8+H+;M+:OVU'4R3+(IZWW?
> M)?@9L$$%V+8:_W<9&T6X84_3$CC=A1$PG7HV>SHN.+DA)+D!'H,>UP4^K`UX
> M0%:="4R+'U4')M>'I#>%9K=%YEIBB\SQI>;$*O.#:K)I^QXX=XDYOLA\!YP[
> MWQ23:XK*-D5DRGNOR8X1T/1@"A2"Z(;LP,=U`>#B#ZO]'E3YW@?SAM-5^R?5
> M!#RL#7Q41S=JD\:!R0U0AL;0)00D/JLU/+<UIKCU7G5K,EW5SJ/?WEW2UE9.
> M_XPE^S,W3+@-;)LM;VML6#?W]=?W]5?W]9?W]8-OYW61Y
> M&YP[IX-L*<GMZLWOZ2WH[<WM=ZO)ZH=":J=WQ.<TQ.0V>F?V<E5NYBH
> M-A2"LSL",DR^J2W>CQL]DFI=$ZO<Z'HV>'8@\>SVD!SR=VW(7FVBVI8KB<VG
> MHXEJ_^9?YN)9O.IF@?.MHG5>59L#&G=$F/;'M__QL/U\5ON-XG:/JG;?^G;P
> M['"S)=)"B+)8HLWF*+,Y'(2FFDXFFP[=-?T6T>H2
> M4+?:O7SQM?RY9]-_.);TY8&Y0X*UM@K/'&RO@T&L.V@=\&VMX2]ORWRHYVQ
> MG^Z)_V)_XC=''\\\G3GO4L'BF^6KO>NWA%GVQO<>>]QW+KOO6DF_>TV_?TM_
> MB&4@K&,@HFL@JF<@J@\>R>(N:%Q8AS6TW1IBM@:W60-;K'Z-5I\ZJV>-U;7"
> M>KW(>C''>CK=^L=#ZX$$ZZZHZI;>KG*Z5OKKI:*Y%PIFG<L#
> MT0<SIJJ=/9.MW4I:^02002@PX"]G<V>?SY]:C
> MCZUG<\A'`#WKK,$F:TPO6?H%XP2E!@?-M5KSK-9\"A1`3-D:<#+=B1'?;XWJ
> M))?L56N]64HN\T2*]5"B=5=,S^9@\UK?IA4>M4MN5LX'U;Y8,.M\WB]GX>JR
> M9L+T3@*9/P`GA@K?'
> M4(_4;QM&4KX^F@&%3DK_Z/1DDF_*8<.0Q%>Y'Q+8//?S\4-+G!Y-F''S`
> M5/O3?8F?/E'M&&#Z]NAIVZ.F;8V:NC5BZI:(=S:'
> MOP.VO2EL,MCVQI!)&X,G;0A^>WT0,'%=`&&M_YMK"!.X;?N\L9(P?J6W#`@W
> M=6XOPHHA0CHRR::L)/"%<P6-;=MFE=_KJT5$U;:-5@HI0@.ZEX81-)XIK'T4
> MP26`9&M9%3!^%3SJX`V"%-8,2N`@R"=5$,;7HFEIA&;.6L@G:T5`LCGD9R3_
> MR69?LM^7;S/@NPBF`AL"`*+.LDE3IAE#6W+\WUU/
> MF`H#<MMFVQZ\)P&KO281V_9XRQELVPWLD]CVLML3J&V#L-)UXNNO@]0"U'&I
> M<%\"7@8)YDY,;/O%N<#Y%^>>X\P1.2OS`GF$9FP-VXA?S\@$-6>L)3!;9L*]ZV)1+4I*P#7MYPUN+VUTNUM
> MCOLD`K'MR:MEF&I[3N&`:GM/E5FG"/>[#*C1@7$QN1TQN.Q"=8XG*-M./*K:&9;2$9C03PTYO#@/'S3%'
> MYEEBBBQWRRV)599']>;D1O/C!O*%)`]KS4DUY`M)B'F7F^^6F.**3*#=4;FF
> MR!Q3),BW##S-)D1DF<(S6L/26T+`R-.:0]-;PC+:PC/;(NCG)J-RVJ)S">33
> MD]FM$4`.^5AD=$%K;''KW8K6I/K6-/I=W6Q5FZ@V^Z.2\I]P9\O;LFW3G21U
> MLFVSS20ZVP8A'B?:5T,PE0K":_MS?=TON@@:YJ%_:&
> MYO4$Y73Y9W8`0=E=8?D]D46$\(+NL+RND.R.P$RS?WHKZ+7WXP:?QXW^::V!
> M&>1(;K^8TWZ[M-VT/LUT[(%I?XQI>TCC!N^J%3<+YU_(_/F/1]\<2OAB3\S'VR.F
> MNP3!N]6DM61?&KS-L?<^LAV-<%N'K-WT2S?Y>R5=D*#_B0V$F_X])_:?^>@R
> MPZ:0Z5O"/MP>^?&NV,_VWOWRT(,?3Z3..9^S\%K)2H\:E^"V/7$]1Q_VGLOJ
> MNU;4YU_4'VSJ#S7WAUD&PCL&PML'0BT#H>8!<,V@5F+8@4W6@$:K?;J76/UJK*ZE5MO%EHOYUC/95A//+(>2K#NCNNXRJ-FZ:T*IZO%
> M\R[FSSF?.XMX-A@V&"1X9`;PPXG!@#8:A$-L$**DI[-`XME?\9Q_I6CQK0IG
> MCUIP_2VA9$F;+?V"AH)A%UBMA59K$7UDM@UN
> M"F+ZB"Y^Q_58PRU6?4RZ]?<'UCVQ/5M#S.O\&IT]:I;<+(>3PJEG
> MG<OY^0QX=N:/9(;I/QQ/__YXVA,#W7\\D0ZC_7P:;#MK]H5<<-\E-TM7>%2M
> M\Z_?'F$Z<+?X:8;'>Z556M<&MY056Z7
> M-<9L#6^R^E=;W8NM5)_.)GV'3'LE&__2/[F&.5H\M>$QX3?'W_U^R/&ET<(_SF'$`N#]C?^)G^8%?L^SMCW@?5WAX%
> M3-\6.6U;Y+M;0+7#WMD,A$
> MN=IOPFK?">#9J\BW!9-/#SM<B-?!7`-M>PWF=(1BYL(YNP'A`'$JGI#9A
> M@JL1:&D:*I1?"63H>46&=&J;R%>A9J4>/QE%K!6]UOR()59XDS]WH&$9X"GA
> M`=`OM'9_U1BW5QB"9)-MUGPW")5I1:_IGW0QXM7%!/IMS3)$N]G77,A_)(5]
> MK]P;2UT)].-W#/!7+MS4N84]P9\57"I=<67.8LO$PFMH@S?M'5\8NNO;&8,&'Q=<*2ZQ.6`D2[WUS&N#D1
> MG)MH-^&M%8S;;SDKO.WL^K:SVR3&*L+D5>Z<U0R/*00BW.^L\9K*6"OB_>XZ
> M#;)_$Z89L@'P?5<'5$[;R/`3F<YSX8RE!:4^L:+]7WIY0UGZW
> MI#V^J#VNL#VF`""&'5=LN5-B2:BP/*BU/&ZTI+5:,LR6]#8SH=6<WF).;2+?
> MO?VXGGP/8%(U^6KM>^6FA#("%.Y5F!*`,M-=H-047V*Z4]P65]066T"(*VR#
> MIW?I5P&2+P$L;-ZFQ-XYM(,GK#<SN\DNW^&58@K(*V]M-VWMCVHL3V\C7@V&/8=BR7>
> M8KE+'\&VH\&V6\TAC6:_6K-GN?E6H?E*ENGT(].1>-/NB.8M?C6KW8H77<Z>
> M?3+Y^R/WOMP7]]G.R/<W!\/;S91U/O`6!F]M;Y(%!K!G^M['/XS,OP"(?@?0
> M;?EM44):DW#V>)-_#)E^]'BMSV2RY!`P=2/\$AG\P;;PCW9&?;8[]LL#]WXX
> M]GCVV<P%5PJ<W2HW!3;MCND\FM1JZQ>E5;/"JMY@J>74P?X2FS;=!3MK,YH<\:U6$-:K)Z5EEO
> M%%K/9UK_2++NO].S/=0$U
> M'RE/#'2'06:>3/OI5#H,._M\UOPK>8MO%*\@GR*HV1;6O/].QQ^/^B]D66^5
> MD!]-A,EZI\N:V*?LU99AGDUVHO=;D0V;@FL7NM5MOQ6T:)K>?,O9L\^!R]L&LSAAQ.IW_V1_.TQX/$W1R5^
> M?_2UBH=?'4GZ\K#(@W\?4OCBX/W/*:#:,_;?F=S_=<_>3/7<^WGWG
> MH]UQ'^T"8CJD&+_KQ+_8Y
> M!PG^5SPX5,$]!+B4,^B7;$I([B3'YQ5/F0!GFYZX:QB^`T9LIPO
> MXT]8,QBLF8X)(JN``/JH`2H#)JPV@FSF,8!LJ9=./4&'9@Z4`'NL\G]J=*\A
> MP?>-E3+P,Q)_K-)_(7&6D?Z1@'\\ELO0+_=00?8'CF<?;:?0;Y1BGW<7D#^_
> M*&^V7B+O#&%PI382:P+Y"KG%['LM),@'[]@WRG'8EUV0A6&Z/YC`MP4SW";R
> M;<'27@5I*S#;F3"%XPUWKG?H^JB$LB=AJK#P*:Z&:ED/^#+>70=(0ZT%V_9B
> M@"Q.7@6X3R8KN&[@EV"9;RV__19HZ+);;X*>+KG^!@#^2BSVROB%5\!NB>."
> M+F7?S7FE5_/O_KK!<)\"7JZUQ9<
> M?)UPZ?4%E\<O9)!9`6\L9ER=L/C:F\`2X#IGV?6)RVXH+`=NP34";Z^@.,O<
> MGD1P):QTG;S2C3%E%64UX,YX!UCC\0Y1;<+4M9IY:2T^-N:?:U%-EZJX&S-W5
> MENNZZCNZ&+KH'0Z)9*A!YQ%__VC:F_'Z2_L:>OMJ.OTM17UM)7TMQ7W-A;V-`-
> M%#?VE#3U0F5Y"SE$:.XK)?1"?0DYVE/:U`M/@3+ZR`X5-?3DUG9E5K6GEID>
> M%;<^*&A)R&N^D]MT)J:PKN:HGO:XGJZDGOZVGR-)3TM%3UM5=
> MT=U=V=U=)0!/H;*\J\MV!
> M.P",4P"C>=XI](PO]+Q;Y)50#&?QO5_F]Z`\X%%5<')-6%I#9&9S;&Y;0E'[
> M@_+NY.J^]/J^K*:^W-;^`G-_43NAF#P.%%D&"LT#!>:!_#:;Y+4.Y#8/9#<-
> M9#8,I-<.)%?U/RSON5_2E5#8?B??')/;%I75')G1%)X\!`_<!``1>]`22=Y*7);
> M!S(;!U)K!QY5]MXOLVD`L_N/K>M.KNQQ4=2:66>T6F._FM,3G-
> M45E-D1EP4G+VT%3UA237DN]3TD._84E'->%1=8"&AU6`/\4OJ9)2X?M`IMP'
> MN`^4^226>1-*"?=*O0@E7@DEG@K%GG>!(H]X@GM\(>$.P8U00(BS1;,X(RVT+3\JZ!YW63H/T+V_BFBQ-HAG^'*R1N$&,+M
> MF%P'<;6-FWVT-Y=<MS@@SUV!W%8\%.#.(A"OX$4HY-RUB;<1FC9T*(IRKGR)
> M/,^X/`].KGLLP2TF1R+;+1K(`ER!*,)M0N;M2,XM0H::]%L1MM$V-N`V03D%
> MG,Z5P"<`,V%3XL0PLF7<8W(48D5R/1AQMN`O!;PF!'AQM,BO6(KZV&
> MNRJ\'2%!IM`6/@84B8Q;#3N+#*N4^XKH#\%95E%6N6\'F+`(7`K"+@E<2KG?Q1A>G
> MM2YS5KK\LLSEYZ4N,Q=O_''AAA\7KI^Y>,//2S9!Y:SE`O!T&6GYRU(">RH?
> M8O4SEVSZ;L'ZK^:M_7SVJD]^=OYPYHKI/RR?^MVRJ=^MF#YSU0>_K/UXSH;/
> MYKM\N<CEVV4N/ZYR^7FMR^SU+G,WNOSJXC*?XB0!9:B<M\EE[@;2YI>U+C^M
> M<OG!V>6;I2Y?+G29,7_3QW/6O__3ZJG?.T_Z>NF;_U[TQ@RGUS>4/YMF"-7EXSD;
> MW_]EW;29:]*WSU!]7O_?+^H_FN<R`"USB\MT*EYFK769O
> M<)E'?UX+7%P6P3]4+BY+*/!O,0`%J('ZA?3'"C_3N9O(#_2G->0%@>O]]R*7
> M3W]U^7#VAND_K7WGAU63OB77^,:_R37"V5_;_NH$KS_\I."?MUGP;\=ZEWD;
> M7.9ODO[)A,(FE_GP3RQ<-?RCN\YESEJ77U:Y_.3L\N-RE^^6NGRU<,/G\]=]
> M.F?-A;S:SGX-\1A5_^!4R7@7_4I7_FI_W\3P-TO*_"%\KO*WG*/^]&0<0,#5@1!$`1!$`1!AIUQ??T#"((@"((@"((,
> M.^,ZNOH0!$$0!$$0!!EVQIG:>Q`$01`$01`$&7;&M9BZ$01!$`1!$`09=L;5
> M-G8@"((@"((@"#+LC*NJ;T<0!$$0!$$09-@9EUG0A"`(@B`(@B#(L`.JW8P@
> M"((@"((@R+`S+KNH!4$0!$$0!$&086=<3G$K@B`(@B`(@B##SKB\DE8$01`$
> M01`$08:=<?FE;0B"(`B"(`B"##OC"LO-"((@"((@"((,.^.**\P(@B`(@B`(
> M@@PP6(*7^2SEKWR9H-K<5?_^0=7&8#"8D8NCJIV6
> ME@:WO?7KUV_9LB4I*:F\O#R?II(F(R.CK*RLL+"PH:&!=QAC^>NKC_T9GE&'
> MUSY%^$!2>.U3A`\DA=?J\N?_(/B$I,B5K#!"^>O_\S8L^2M?)JHV!H/!8!R)
> MHZI=4%!PZ]:MZ]>O^_O=.&''0OOH\Z@JLU+PZ2)HS6@G<N$7F+D
> M2L-'QR.VE\M#&N2".KS6;NS_-/E`ML/:R(^&H0T'#V\],G%<M<."CU\_/?_&
> M_NGP&.%_D-<.,1%!)Z^=64`'61#INX_7V@BJ-@:#P6`<B4.JW=C86%Q<[.OK
> MNW___H,'#WI:6LJ+C;IY>&!/EVU";U]I47%=?&!OI>^/4@IS,
> M>-4>"?2]\K9>>DID;R%+JC:&`P&@W$DCJYJ
> M5U=7W13##HEY>M6^>_<N%."15>IC.(@F]MN(1UE97R,6]'%$
> MM:^=<JJO+>CL,'5U==P*S^CI,%O:NQOK\J^?GL];.)#KIQ?4UV5V=K3U=)HZ
> MN\Q`=Y>%#K*`M]#%6+6#G<:-FWBT@#\#B3TZ<1R-4Z-&CG)R<JJHJJ"PI*0%-'!@8@'?JOKX^D\D$S<"S
> M,S(R6*]1"9-CC1]#N:JRQ!'5UBQLLTK['5F&JMKU]?7W[]\_=NS8X<.'O;R\
> MZNKJX)>9H:IV:D;^WE,A/Z^X\/F<8\O67XBY\Q`JGUBUQ?#:IP@?2`JO?8KP
> M@:3P6EV&I-JQL;%0@$=6"='7#!IH+P9JACJ(@THJYNE5&QY96*4^=@[)L=]&
> M/,K*AC4LK%*3054@;*1O>WLG-',+RWANLKM;>'9'1X>EHSTVRCLBZ"1O
> M9S>1/H=@$%-'NP6ZM7=VMG?!8X>ET]3120<YSMNIHU-M*LQ.3DZ":I,JJLQV
> M"L2K>0^I`,?^3-&&$Z)J8S`8S(C%(=4&S\MGYH?EL)K=;%S2!\NFU)8#3L$$<MR[/\T#;O(
> ME?J"8>"H(^&MC2(>967#&A96J<F@_]#NVG3/2P;,%LZ
> M:JOS#^S;S-O9S?Z]FRHK<ULMG1IJJW(-%P-]-(,<O1#A%98>>^=>3V_7AK&+&-ICT\=62=V,'+E*.?E?UYVIGA4T;<
> MRR&JIZ&&_@FJ_?01QV=E?8U8T&=PU=[OTM12);O^:XO./25[/379_
> M;I*/6T1&<WW)@;T;>#N[V;_7I;FYVIT,XO'/=WR>?]OGGU,\GY_B!37U#57[
> M]F_D[=1Q0+7U9>.CQ+JE#22C(-JHVA@,!C.2452;5]A(2DK*GCU[-FW:M'W[
> M]KR\O):6ED8A<#L$SP8M+B@HJ*^OYWUTD<_ER!GET*W:@Z@V2'!C?06GH:*A
> MOAP*Y%$J`XEWH^RK=N+=2-92>\NCYJ;F,]^=H6%Q>7U-14UE(3<9#TK()-AT,>I3S>>BJ\J*KA]/5`
> MGX@,OZ#(_WQS4VAXS#]?GQ45D\B;"K%O+<P:X5$3^1"+6-;$L)D\@B;LJ#>WELIU!!OUI
> M@B57E&0V-;2";;N'9;\PV>M6>(9;>'9]8UU92>K^/5MX.[L!(X?&\#X&@S#&>;QFO!C-*C:&`P&,W+AJLV?
> MV4AS<W-`0,"6+5LV;-AP._'$N\7!82N"/6=7=/9V?
> MS=KYW/1=R<D/7;;NFHRQB&U;6UX@%?0;]:7JXG8N/":RHJP-<(][/;\
> M^V[_ZUKH5=;FP/X#K*")J-IS5UU*R\R)CD_:>]S->7_$W8?9/H&1+WZT8]7.
> M6_L.GCQW_LKXB;-Y4R'VK<6.-1+K%,)K=1$/R64[!3JC8O
> MV3X%U(N1*UGA::(WSB=V4#L=(>SH4WX#"3OJ2!L6?7NY;&<01WZ:!_:X%!;G
> ME=4U--2VN45D@'/#FR!?K<5@,!@,9K@S9-7F_V\W>7EY1XX<6;]^_9HU:P("
> M`L+"PO+S\\U2FIJ:0D-#T]/3H1F8-^\S3`'/=GRO=D5I=F59#@`%F0<)$;$Q
> MT8-Z-@LT`Z"+.((\IIU!'%'MIJ;F=1LWL]W8?B$^'UU^X5//Y]_;]]*'%Y]W
> MC7)E;0X<&%RU?UQ\-CLW;^&F2]FY.5-_/%%05I64FOU_O+$N(?'A2U/FG3I]
> MYHTW?^%-A0S508<:IIYR>*T47BN%UXY`'+],/A4IK(8=@HAE^V$+]FS%G0PD
> MA#70!^12C%C#&D#X<QL:^O2J+18,\S1'6<0VK*RO$0OZ./+33$S(V+]W0UQ<
> M4'%^<DEY7DE!*JHV!H/!8$8N(Z+::6EI>_;L6;MV+:AV2$A(4%!01D9&8V-C
> M?7U]0T-#=75U8&#@HT>/P+:AS/L,7^A6;8>^5QM4N+PDB^%QZQSS9CM^;"MR
> M1QA$'M#^.(ZH-KQ6^P\=C8Z*:JAI;*YOO1UJ^Z[=UUY<F)Z>S-BM6
> MK6(%34357K?K:D1,^H2/UC:WF?8?NU525EI>6;-^ZQE_?T&'(B<3PFN%&%:R#$FU>4DJZVL<";1D8656
> M"1'+FNB-4[_&;'_5>5#5MA_61GXT#&UH+ZP-:VP8\:B^O5S#PBHU<?RGZ7+OOWNAS8NP'>!`<&K`B"(`@R$HR(:B<G)^_>O1L\>]6J50$!`;Z^OHF)
> MB<7%Q44TN;FY7EY>#QX\>/SX\4BH]I`"0EQ6E`'8-V,'X_AH]E5;SIW$I)DS
> M9QZ/W?/5N7=^.?SOS]Q?_MSGY2\\7YM_XGOWI"OAX>$[]AC_.6C>G^:++[]_
> MY;TU`2&1B]:>KZ^M7;KV\-H=E^\G)KPW8^G^@R?^S_]\+SKF'N\FQ$%K$3=5
> M.RB.FD!+_:;J(0UEV-AP6'V>4K7%L$..1&XL]K(S@FB6<EFCFTRU^1-='+_,
> M48S^,N%1C%A#6VGS9)<);X+]`P,(@B`(,A*,B&IG9&3LW;L7/-O9V=G#P\/?
> MW__JU:NWI=R\>?/Z]>N@XP\?/K3U37]/'`?W:HL!+2XM3!\NU79P*`>=H*RL
> M[/#QTUOV;;I^]TQ":MR]Y/AV+],-J9&UJ',
> MUL@=/*/A("P.#B4>M=/2SJ$G5NV^_@$$01`$&0E&1+5!$$^<.+%FS1I0W(/,7"((@"#(2C(AJ-S4U
> M^?GYN;BX@&T?.W:LKJZNS2A5557#^Z<B61S?JSV*&9(3%)>4NOD$S)V_8/6Z
> M#1LVNOSJM&CGG@./4_EV;<=S/_'QDF7[)T]9,&G2_$4+?[MSYSX_8)0GL!8N
> MC%)X[<B'GT\*KW4L3R9G?[O8OTQFKJ.^JOWT>6+5[NGK1Q`$09"18$14&S-H
> M_OJ&AP[Z+`4OTT[@3;"!$`1!1H)G3;6?8*\V!H,9RX$WP:Z>/@1!$`09
> M"9Y!U7Z"O=H8#&;,!MX$.WOZ$`1!$&0D>-94&X/!8(84HMK=O?;Y>=]#30V"
> M(`CRC)&=FQ\2%N
> M`T,%>D%?&$$S)F/(JGT%@\%@GJ'`FV!<G\;F=B7Y-V9,!7.3>8OJZ?X,3?V@B'-^/7WMW=T/1G0%T;0C,D8\JHV_`]5>PP&?N@Y974(,D*,XKL*
> MO`F:.WHTO#;'@^$35\B8YAS:WG"/4'_/)IC/HTXR;?'7VO9LU
> M^J-_$=BLWEM"IRK,C<^6\:?-6?)[]HI10+[=_.4&"((@PP>(<F]?O\G<(5-Q
> M]VE[=LL5@)0`_5P5*R$OC""9DP&JC;&H<`//;NT%D%&B-%5;5-'MRW`
> MMMD&DHD+?%MOON6Y^_\$;I^9Q^GZWZ:3-\=\+6#V;GML2W:R$
> M`<5Z^V<<_&(Y4E^YI8`R2!I_-0!V"NGLPH"\S9)H800$01`5;IS6UF
> M!O'L[]^O^/)S>`2WENNA_(#5?_<^M)'KH2^,H!F3,?RJ?>?.G=#0T,#`0#\_
> MO]K:6EZ+^9L'?NA9);4(,D*,KFJWM7?;@=DV/()DLPTD=;5UQU=]H6FF03;(
> M5/HT53)"L$/=444<#?ORIUK<_.A1/>KNU4<,MF$H@^L
> M_8TM)D;AK2L/OIC6OGUK^XXM4$A>_@O4P".4+5(EU,CMH2^,H!F3,6RJG9^?
> MGY65!07P__Z:F)M8,\S<-_-`SBVMDCOUQ?-^^
> M?<=/GA(K@=__.+%Z]>H=NWEO=J,]N^?>Z&IIF(
> MV-#^:KC%O^X]]Z?2H++)NOK2Q'O7@FO;V
> MNK..,(W4&WP9&$9@E8MCC6<%];0OOP3ZU/X92GX
> M5(\?R6=]$01!#'!U]^,@:-B8^@+(VC&9`R/:H-;W[MW+R(B(B4E)3`P$#R[L;'1S<TM-37U
> M\N7+7EY>[NZ1E&US/[]^S,R,G[[]L]&NQ=K#.]"8:^#=A!IPJ#:Y"D_(QV3EX47'T$0
> M1,]M=Z^NGKZ:AF:1S/EK$B=--/^ZQ#P/6&RACXF3WH1Z34OH"R-HQF0,@VJ#
> M9\?'Q]?5U=74U$1'1S]^_+B"!K3;Q\<'GM;7UX-V7V+M()V1=M0.TI(GJ+;R%%XT/AE>
> MCR`(8@,0Y<[NOIKZ9@V)KG5X^?##6:-@#T):JM&Q88!M6N
> MKJZ.C(PL*RL#DZZJJBHM+2TH*,C+R\O-S87'HJ(B>'KJU*F`@`#>01>/V>/&
> MS?;@3I*\=(8OC*Z2KBT8;DN\A(-_H,`G[;20,%6C8;15>UF4Z=];I^H_9%X',#
> MM\[E[?FU['4E\]0/CB`(HN:6FV=G=V]U7;.&Q'^\5/72FVT??F^B0!EJ-&T`
> MZ`LC:,9D#(-J0RHK*V-C8\&SBXN+,S,SP\/#@X.#'SQXD)J:"D_=W-R"@H*:
> MFYMY:TU`@L?/GCW>EE2.M&_^17Q6/PV/V7\9SX;`#STUOTK$XWY&F.'HK#GS)DV:]-T/,\4N%&J!=S65@_)DO88$
> MG.+K==Z:2@?Y$Z9G"\-3:RI#URV\$JX<?3)2CBS\>MKVO8Y<J2S6$"AKGFH:
> M,T97M9M,G8/RS:;@FNI:)ME0^'WY9\=7_5O31L1;$M-DW2%`<Y0_U<"/5AQB
> MYJK%U5L84$0]N-1];RH57;-(YOPU]_DF[/G
> MSIWPKMMTJFSAQ8DA(R(LOOJCIE9(?LG;&\L-W-96#\F2]
> MAL33G.)/F)XM#$^MKKR;'*8<>DH<O5)1K^5`I::9S.BJ=F-;IR/</G<#A!N`
> M`G@VLVU-&QDO24P?Z0X!NJ.*.TZ[5J$J8^N<7/UXD>UJ+M+??>F
> MLJ-VNK..,`'QJ=Q1-RMY*`E'SVC_8F5T/BT-*!^:=BU5?&6$OH#\HAT_F"/6
> M(PB"&'#3U;.XK"*GH%2&>/9__!?3Z]Q_OICP__M?\`CEUBG_3OB/_P5'Q<;0
> M%T;0C,EX6M6^?_]^45%1<W-S555586%A>'@X>#8<5Z%
> MR,V[;<^8O/!1=<C:F_%%5W(;SV;&C->Y]\_=QSSWWP\:>:
> M7H_S@M?,6'[(^_)/,(I_?&BA<-1[
> M[_N%C_-5L]]"<17C*BYH&Y+D\@%#FPT*-
> M@]>N*0];X$?Y*+="9M?NO?#37.>R*S"Y<Y]/U;78ABO1]9<B:\^'UYX)J3X9
> M6/6'7^724_EB%PEPM:]!X$*@?`>$;_G!.RIO+Z+M:W@MNKEI,&Q#*NW.WU8O
> M38%,GHXCM#>\-'NO,"`,.!AZU=8T$!E=U:YOH^+N79#ITN=>8YXM
> MUS/;+GGN57B$-G(]](41-&,RGE:UX^/CKU^_?OGRY=C86%#MAP\?NKN[@V1#
> MH-[/SP_JP;]7K%@!9K9@P0+>38KHU\1DF3>*M8HXVK))?0.F@4I-,YG15>VZEO8G!CP;
> MT%0.+QY0OUYX4S5$$01!#KM_V:&PQ5=:WR##;
> M!K<6*P%FVW!4K(2^,()F3,;3JC9+>7FYEY=704%!6EK:W;MW;]VZ=?7J57]_
> M_XB("'#QDR=/>GM)L
> ME!HI^AIUA+/P4:2Q>(0&AJ>68V.22ME6@V$+_-"3LLMDUJS;\,,//RQ=9(^LO831R&*EX5FDI^KNCI1%!CV+V%&>
> MFP;#-D\VLE2IX,'#^!Q[=JUMV_?YAWD:)U0=DPXH!BJ
> MM/AKRR;ELKY@JY)$LE^]>W=#0P/O0R,Z(XLBC,072<9K/A:I54RQK"\8
> M5<+_\PAJRI^)'<E<2%1^K.LLM2+A532ZAA!2)S_3->`5[)EV6#BHOR)U61YP
> M]FRAP;`%?NCW,TOU3'_O_>>??W[BE`_8II&#'N7[W<KVW"YY[K5W_\?_^!__
> M4]/^?B9QM=5;09W)EH;5S,69?)_#LOTQ4J7[;M9LYHF+T$NNO[3U
> MZVE;`WD;!<.12:4RH.%9.&)+1\HJR)1@6#8K@%*Z
> ML.F)`]HJ&[F&;129I15N\F"(`B"C&42'V4$AD;5
> M-;::.;X(>>F%&JYU__^I>_O_]__N?_M?A$_H*C
> MN?,.Y\[:G_7SGJS__M__^ZU;M_ZW_^U_T[0?%BYN_7J5F[8R,2-PU8QE^Z(U
> ME7\1')G;7VC^-E3'?S"KAZTWVH0"_HJQE-9GA4
> M&W+GSAWV=VKV/^NP5^
> MZ/<R2O1,>^_#__D__^>4=]_3U$]X:_)_^V__/4#P/1%V<NN.BGJ20$
> M4%755(X$<")A?7?&,/\J?-?S!LOL(CR.BJ=E6C&4$0!$%&@F%3
> M;3E'CQ[=MFT;^YLU965EO'9,AVT'^3N+-OVA)Z07CS;W]SJ!E2[;&ZVI9_BO
> MM'EHU'%D;G^%^=M_A4>0T57MR@8S@B`(@HP$PZ_:F&<R\$._FU:,("/$Z*IV
> M1;T901`$048"5&V,0X$?>GQJ$8*,$*.KVNS;43`8#`:#&?:@:F,<"OS0XU**
> M$&2$&%W5#DDJ1A`$09"18,BJ#7=$S-A,;'(A@HP0_!^RT0BN:F,P&`QFY`)W
> M&7Z_<2SC8AX7(`B"/#.@:F,P&`QFY`)W&<U]QSZHV@B"/%.@:F,P&`QFY#)D
> MU>;],!@,YID(JC8&@\%@1BY#O<N@:F,PF&<JJ-H8#`:#&;D,6;4'!JP(@B#/
> M#*C:&`P&@QFYP%U&<]^QS!$.29`54;@\%@,",7N,MHQWD%O3US_`GV,P&`P&
> M8?TDREGVZ@)W&4T]QW4.SI3K(\CX=01!DS"#?(^P$QIDLT9WB.`OJ7:&4)E18-QXN"&J
> MO32N)^/F"7J#=//7-D`09-085+63<JOAL;:Y7<.#J\?IO]';IETMUQQ2$4G,
> M=4&D4AZDO2VR(J;!Z?:DL*?N>US=Q:,B3W"6X9HD@B#(6$*^1]@)W&4T]QW[
> MC(.W8)GI-ZM-'=V4]"523=I-?OL!I_3C1PVQWT4^&DT*2Z+36#U=AY9Q?`)^
> MDFKS<0!Q**6^^G>V`KT_76E`CRK#\L922V%,WD8\BX`T@OV7!4&0/Y5!53NY
> MH!8>ZUK:U90?6+SM/Q:'<=^RC4FW"_O2V]NZV=LETE\B:2UD2G4J.&F*_
> M"S\J5G)=UN#8!&359D]3%1W7M*P^HMKLP=$.2T\J#7+\2`$94^X+ND^?:I':
> MN_GI#B$(,EH,JMII177PV-#:H2([<AKH?@W^OC!>R-`HYZ3=>8T,G=4\T01\]]&C;#1I*&ENO"]]*JLV&T<>
> MEIU%.LIGQ8].OU%-QN'#LI8&2%/B,T00Y*_`H*J=6=(`CXUMG2+<L',Z&Z.9
> MF%:0^AQ)FH667E1D%T73IW)CH1<=BC5(703=]Z:2EFPH5I9@+1G\C(9=E,&-
> MC@YQDJR[,DE62;L+,T<0!!F+R/<(.X&QA_.(&J>0MB_1B0@)W&4T]QW5BIN0)+FL63-?@
> MJ"'VN^B.RJK]1!/@BKPX*D492@OM6\7OH&#,9!S-4_4XREE@5KRE[>L55%MW
> M"$&0T6)0U2ZH:H%'52_V+SY_'V#_\<.Q
> M="CZ#L.Z*V]BMI%/9-Q%.HOA4<<GJ:IDEPSS9.^?0YPP@B#(,XE\C(&]//@4B?]V#=Y8]SQ$5+GP,AI-YT4W\LA/8R
> M["*?Q?"HXY,49JLT8)\7%SZOPB\'01!D["'?(^P$=!^+W)O:9.IL
> M,M$=@7KX44/L=^%'0;7E+MIQ",)_
> MHA5G*R`-HF91M*89@B"CP*"JS?Y2]]K)-4;?(N1V%UU"O%+D#2']%W$LQ@.Z/@DV:6)+5D--).F)(V`(`@R
> MYI#O$78"=QG-?<<^*M46/@W#37?:M53ZR7H*^RR.3>QWD8^RC_Y(J+<>&DV@
> M@GV^AR!,@%<*GP02/V`D'*K@D^%]-4\-QE':L,](*?4R<@,5^%DB!/DK,*AJ
> M5S62/U*@^1,#"((@""+?(^P$QFF^Y40B92'51^VW4-GC";K\-2F7
> M=#Q%=PA!D+\Z@ZIV'?TC!>VZOYV+(`B"C''D>X2=P%U&<]^QS
> MQS-<Z>%,U1!$'^%@RJVJT6\AGSKIX^!$$0
> M!!&1Q!=N/U]/8C"((@B(A\C[`3N,MH#=>+U]_0B"
> M(`@B(M\C[`3N,IKPDZ(:NMN
> M/7885]UH01`$>6885+7QE-/<=^XSC_3`8#.:9"*HV!H/!8$8N0[W+C`M)*D80
> M!'EF0-7&8#`8S,@%<%4;@\$\4T'5QF`P&,S(9<BKVOS_,1@,YID(
> MJC8&@\%@1BZHVA@,9DP'51N#P6`P(Q=4;0P&,Z:#JHW!8#"8D0NJ-@:#&=-!
> MU<9@,!C,R`55&X/!C.D\F6H'.XW39.+1`EI-_W^$4G!TXHB.8;^0
> M$7UEACJX8?L1G2$&@_EG82E%H
> MICV+X9C2`,I!4JE,63]Y6JN<0^S%BJJAQ%,
> MRG8&Y,?(7)1*WA6*M$2'TTY/:*:4!ZL4!N158@\,!O-,!%4;@\&,Z0S_JC9_
> M*I6IM2G1:QZ/W-B6"(IE*$B&QRKLG$4_IKI&&LO6B?258EFL)$^&-M009B)'
> MKA$.&5R^K4%L#PB#*$>$2CXHC<V1':X<9$`,!O.L!54;@\&,Z?PIJJW8I"K*
> M(<GR#!H;C2EUD+HY>!8IZAH8E#XQ/)'QV6TTD,<=M*54'L),Y,@UPB&#RD6"F6H2#5*D,I)>&XS>Z.S42.V%=LIFEG:Q"Q
> MS"+7D$&4"Q`JU1T,1QM2I5)+(S03>V`PF&<BJ-H8#&9,9^15FXL;#_=*%ND`
> MD6:Q(X\LGM(3<7S:5QS-YED@VC&%QD83%LHVSBZ728%^I$]JQ<*<#4]JY>X!\?+EFRXVQ[
> M9Q\\0KF]JZ^CJ\_UX%3>;A0BJ?:?'2+:3L'\"0:#P3P;0=7&8#!C.J.EVM?W
> MO6ONZ#5W].PYXP&&;>H@S@UE6MD+1WF[4<@HJC:N*V,PF&<MJ-H8#&9,9[14
> M^^+NZ:V67DH/DVQXA#*KN;1GJP".M`1-)=7*":EHA-9AX]*B!O"K=
> MY15D396LO.I"L#PL&U$WD,'(4@RGI&H/I^`19ZPT@;!1A2KE-`:5JCE#I=Q$
> M'%^(^F)AFO8:8S`8C*-!U<9@,&,ZHZ7:IW>^WV3J83#/AL<F4S>K@:.\G39$
> M2;E-$GF4
> M>Z%&&_EDRE":RS>LU!?%MNK``:&U8W]K-
> MD%>UZUM[6,T?VS[D8`T<B]]@02>
> MD`YT**56/[(<PRD9M%>=10P_(T0]6V$FNDK5:+;*8N1Z1QIC,!B,HT'5QF`P
> M8SJCI=J'MGQ<T]P-,,FN:>YBPLTJX2AOI\F@6FGHM7+4W4GT-4HO?0&BZD">
> M,$\V&$<*'-)/R=YYU8%JU?F47OR(8:5J-%ME,7*](XTQ&`S&T0Q9M0O@G4?\
> M#XGX7]<P&,S?.:.EVGLV?5+9V%752):TE^PX6]G8S;Z!I+*I"^KW;OJ$M].&
> MO`7S=UU%,35VR&OI6IK(5!!#^E'5G4WFI*M]F(9
> M"N+IE*&$F=BJU(^F*8N1ZQUIC,%@,(YFZ*O:\,XCO3_2-TW5NR`&@\'\O3):
> MJKUS_6?E]5U`&3PV0*&SO*$3RF7T<>>&3WDBFA,%@,'^/H&IC,)@QG=%2;9<UG]N'MWN*D'?KX3'D85/MX9O24X;>
> MR93@?0R#P8Q4GE"UV?N24,1@,)B_949+M4<LREZ*X7MJ8S`8S#,45&T,!H/!C%Q0
> MM3$8S)@.JC8&@\%@1BZHVA@,9DP'51N#P6`P(Q=4;0P&,Z:#JHW!8#"8D0NJ
> M-@:#&=-!U<9@,!C,R`55&X/!C.F@:F,P&`QFY(*JC<%@QG10M3$8#`8S<D'5
> MQF`P8SJHVA@,!H,9N:!J8S"8,1U4;0P&@\&,7%"U,1C,F,Z3J7:P$_N;N4KH
> M'RY_RC]@/EC(W^H=R?$=CS*3)9/BJ7X5&*-!1OX-!,Q-CO"]%>K')N?FHIPS@3
> M$OFI4*\4I9*F$P:#>=8S9-6^@L%@,,]0AENU)2,C1=GTI#;!3C8L2VY#=$_=
> M1CR%5(;_%V20%H5FVK,8CBD-H!PDE<J4]9.GM<HYQ%ZLJ!I*OQ.;D,!4D`686=L^C'5-=(8]DZD;Y2+(N5Y,G0AAK"
> M3.38*!=68^NX8#&9,9,BKVOS_,1@,YIG(GZ+:
> M.OEC40Y!R59CHS&E#E(W!\\B15T#@](GAB<R/KN-!O*X@MG,1Y3\DIR4"N(0MFP4BQ#0:I5AE)*PG&;W1V;B1SP-,.62D@?J4A+*H@',1C,&`BJ-@:#&=,9>=5FZB:%VQB+
> M=(!(L]B11]8]Z8DX/NTKCF;S+!#MF$)CHPD+91MGE\ND0#\K*;5BX=V@RFF0
> MH1R>B136+O]./]9_3P]6+Z08O3+X6I$H+Y3\4N%K
> M93_D);/SRN!KQ2+\D\5?"8=>*U1M#`:#P8Q<AJS:RG^0H*X.OE3;2*X*OE=T$.TV<*+\*^%K9#ORK1U\(*0Z^5JC:&`P&@QFY
> M#%FUI5L9NZO)=RZY9C0S;MQ?87\+O"9P#]>_,OA:Z0(O`]$=?*WL!5X+^G=,
> MF!CB:V4GFLMW]+5"U<9@,!C,R&7(JBTMFL&-"N[])'_6O#+Y6
> M<N#R:;CJX&ME)^Q;D^47`5\K.X'+YZ'_9#GZ6J%J8S`8#&;D@JH]O)%?!/TK
> M@Z^5-F2-D;P,^%K9#%R\VAKUKXR^AI5')W^%?Z[(RT!>-D=?*U1M#`:#P8Q<
> MGD:UX68&LB3>NO@JY6AEM&_SXHU<_\K@:Z4/>\7PM;(9Y7-^)/A:.9BA_7.%
> MJHW!8#"8D<N059O=GN"6Q0IPO]+4C-6PNSM_`M&_,OA::4)>!_J:X6LU6)1_
> MNO"U&CS2*^+@:X6JC<%@,)B1R]!7M?E794FW*7K/4M>,Q<BO`@VS(OTK@Z\5
> M"=B.%#NO#+Y68D`1Y5_D\+6R$?EE&.)KA:J-P6`PF)'+D%6;_S\&@\$\$T'5
> MQF`P&,S(!54;@\&,Z8R6:@<>G60(/XS!8#"89R*HVA@,9DQG%%6$_7/.Z,BE26W^O%G9C_TY#WI%]B_'D1?$?H;KY8)QY`Q]''MG
> M%T?6?S#\*><O#V[JGO(%>8J,X@OUYU^L+D-6RNZ#1C_"DXVI]')8>QP\D?UF3S?_X*.LI>T^
> M<$36\*&,/&H9K4F*+]18#-QE^/W&L>!>;0P&\TQEM%3YHZ>/6<\
> MP+!-'<2YH4PK>^$H;Z?-D]TLY5Y_SKUV5.A!3_J4W0>-
> M?H0G&U/LY>`(P]),?]3!856!7P]L]!%'>Y*1__2,UB3_%B_."&:H=QE4;0P&
> M\TQEM%3[XN%^TI34BLDC(HRP:&53*MSI:
> M".8-1$W@X1U(,R<G:.44K+I+*D-#0^$\XNF5P6BET%_J,/'H47$^_$0&TY"C
> M.B\?4WL5PHF4&'64SJN9E716>@@F2$,;08T4U<1H2VD:<$0>29F',KC05:K4
> MO`Y2)E\EW4`&(TLQG)*J/9R"1YRQT@3"1A6JE-,85*KF#)5R$W%\(>J+E7Y6-AJ/
> M2%"U,1C,F,YHJ?;IG>\WF7H8S+/AL<G4S6K@*&^GC7S;8&7I]D/N-O+MQ+!2
> M.<J+RE$YJF;\F%QGU($&6BAW1AJECV9,UH.)-#*Y1
> MCG@11IB0$@EM*0\COF*Z_NIY\DKUZR"/+Y?%2AJHX,.Q
> MZ%M"P>"4+4Q&,R8SFBI
> M]K'M']:W=C/D5>WZUAY6\\>V#WD[;>3;!KOW*'<+.$">&%8JO83NRE%:XC%H
> MQJ,>68XRB!*QNU2&((W<2U\@
> M@2>D`QU*J=6/+,=P2@;M56<1P\\(4<]6F(FN4C6:K;(8N=Z1QB,25&T,!C.F
> M,UJJ?6C+QS7-W0"3[)KF+B;<K!*.\G;:"'>()N:#M"P?44Q)C5*ETET\I
> M-C,JZV>K'WE$YD_C^(0=F:<^@\Y'/BV);D#]2>U-0U^`J#J0)^P?,X-QI,`A
> M_93LG5<=J%:=3^G%CQA6JD:S518CUSO2>$2"JHW!8,9T1DNU]VSZI+*QJZJ1
> M+&DOV7&VLK&;?0-)95,7U._=]`EOIXWF;B'=B)19>/R@=)C=Q,
> M.HM25`Y+@6/\5#1R4Z&H(
> M0_'(A\2RXY5B&0K2"Z2:I_YU4`0U(9]W@I%+57]U>=\AP
> M!$V!E:4Y*]/7--#WDB+7D;".KNAM-R59.4Q<CUCC0>D:!J8S"8,9W14NV=ZS\KK^\"RN"Q`0J=Y0V=4"ZC
> MCSLW?,K;Z0*W".7^3.]O-,)MPZ!2=;.1/WG&[V%R!W)$:<;UT'U>C1ZU,PVIHS1E4J^BG=
> MQ9\D?^IM$H/YR^5I_PV2,WS_*@W;E)N'MWL6`[?W
> MI+P3>DI0R8BY"]A_ZC:&`QF3&>T5'OL1?DOP4]]
> M_T/5QHS!#.._07*>\E^ED9C2,QA4;0P&,Z:#JHW!8#"8D0NJ-@:#&=-!U<9@
> M,!C,R`55&X/!C.F@:F,P&`QFY(*JC<%@QG10M3$8#`8S<D'5QF`P8SJHVA@,
> M!H,9N:!J8S"8,1U4;0P&@\&,7%"U,1C,F`ZJ-@:#P6!&+JC:&`QF3`=5&X/!
> M8#`C%U1M#`8SIH.JC<%@,)B1"ZHV!H,9TT'5QF`P&,S(!54;@\&,Z3R9:@<[
> M\3]&+(?^=>,1_H/AY*\@C_P?)!^VL]A]-=@K",?MG\A;#8S$F/J\R?/'`Z-<PKF3QS+B+X.0QW<
> ML/T37!0&@WGV@ZJ-P6#&=%"U:?-J%'*I*]N9/&H<1<^
> M@R',4-MWL*GJ1Q.:*>7!*H4!>978`X/!/*-!U<9@,&,ZP*9>IQ2O3B
> MQR,WMJ6&8AD*DO.QBI$XB!#&
> M4;<S',1^I:VC3S!#;=_AGJJF4JFE$9J)/3`8S#,:5&T,!C.F,_*JS56.AXLA
> MBW2`2+/8D4<V1^F).#.,H0?QF`P&,PS$51M#`8SIC.*JMW=TZ<ATW\1VC8&@\$\2T'5QF`P
> M8SJCI=I^1R9K/!O(C]J<Y;\(#O%&&`P&@_F;!U4;@\&,Z8R6:GL=GM+5W<?H
> MW\'V\P#\^7+)DQ]GVSCYXA')'5Y_KP:F\
> MW2A$4NT_.T2TG8+Y$PP&@WDV@JJ-P6#&=$9+M:_O>]?<T6ONZ-ESQ@,,V]1!
> MG!O*M+(7CO)VHY!15&U<5\9@,,]:4+4Q&,R8SFBI]L7=TULMO90>)MGP"&56
> M<VGW=-Y.'<7"-.TUQF`P&$>#
> MJHW!8,9T1DNU3^]\O\G4PV">#8]-IFY6`T=Y.VV(DG*;)/(HVZ$LA4H#*I<:
> M5Y2%DA1I21E%BMQ&+$@CR<VA3E%=B'YD.:2[;DKZ]D*--O+)E*$TEV]8J2^*
> M;=6!`T)KW=DP&`SFR8*JC<%@QG1&2JUS%A)M5PE'>3I-!M=+0:^6HNY/H:Y1>^@)$U8$\89YL,(X4.*2?DKWSJ@/5
> MJO,IO?@1PTK5:+;*8N1Z1QIC,!B,HT'5QF`P8SJCI=IV(8@\%@'`VJ-@:#
> M&=,9+=7>N?ZS\OHNH`P>&Z#06=*'7B%W%A5H!^(8@\%@'`VJ-@:#&=,9+=7>NG9&25TGHY124M<E/]VZ;@9O]S0A`BIY
> M\%-E^(QSV*:$P6`P?X^@:F,PF#&=T5)MES6?VX>W>XJ`(`^3(0^;:@_?E)XR
> M9")"T/XQ&,Q(!54;@\&,Z8R6:H]8M-LRAB-/J=HC,24,!H/Y>P15&X/!C.D\
> M<ZJ-P6`PF+]04+4Q&,R8#JHV!H/!8$8NJ-H8#&9,!U4;@\%@,",75&T,!C.F
> M@ZJ-P6`PF)$+JC8&@QG30=7&8#`8S,@%51N#P8SIH&IC,!@,9N2"JHW!8,9T
> M4+4Q&`P&,W)!U<9@,&,ZJ-H8#`:#&;F@:F,PF#$=5&T,!H/!C%Q0M3$8S)@.
> MJC8&@\%@1BZHVA@,9DSGR50`^7/^4?,!\LY`^<C^3XCD>9R1-=
> M\M-<R)_Q(HSPSQ&#P8REH&IC,)@QG:=;U=8XV4@HVNAJWZ!G=WQZPWXA(_?*
> MC.YKCL%@GJF@:F,PF#$=5&VOV"]DY%Z9T7W-,1C,,Q54;0P&,Z8S
> M_*H=?'2BLJ6$ANQY8'$*YE4\T(%'.2*V5H)33\,EI6JJ?*OTP&`R&!U4;@\&,Z0RW:DLJ1XK,SH0VP4XV3$QN
> M0]1-W48\A52&_^?F)Q>%9MJS&(XI#:`<))7*E/63I+!
> MF<@1^^H')$5:HH,(X_'#I*P9T/YKSB+5P/^+O?5/-?TP&,R8#ZHV!H,9TQG^
> M56W^5"H3D1.B]T8>N;$MLQ3+4&#-)*VV<Q;]F.H::2Q;)])7BF6QDCP9VE!#
> MF(D<N48X9'#YM@;1#:A_?<0V4.2A-?1$2G_-4PP&@]$%51N#P8SI_"FJK3$Y
> M*<HA*-EJ;#2FU$'JYN!9I*AK8%#ZQ/!$QF>WT4`>=]"64GD(,Y$CUPB'#"B/*:DAN0@*QJ>R+!2+$-!JE6&4DK"<9O='9N)'+&OV$S3
> MSM8@8IG%\/6A%7);71.H$)_SI_JQ,1C,F`^J-@:#&=,9>=5FHB:%>R6+=(!(
> ML]B11Q9/Z8DX/NTKCF;S+!#MF$)CHPD+91MGE\O___;.`SZJ,MW_SZ_/;L^]Y^TR(?.<P<T86E,]*
> M^GJI>(=Q5>)IIFKQ3GSX:W03&A]^4Y,8)V2\,S'*9%H?WZ3:#\C8T4O@.```
> M\`'5!@!$-.>FV@```$!S0+4!`!$-5!L``$#X@&H#`"(:J#8``(#P`=4&`$0T
> M4&T```#A`ZH-`(AHH-H```#"!U0;`!#10+4!``"$#Z@V`""B@6H#```('U!M
> M`$!$`]4&```0/J#:`("(!JH-```@?$"U`0`13=NJ]L8]F_^9^MP],Q^\97SO
> M;DD/<)EKO&T````N?J#:`("(I@U5>TSY3#;LQ[.>'58X7`V7;Q[;@^N]/0``
> M`%SD0+4!`!%-6ZDV^_1O1M\UIG1DT>?Y;<K7RU^Y>:Q/?!.$@``
> M^`$`U08`1#1MHMKW+1KZ4/IC:>L6JJ=56U;,6#.U=%,1EW<?VS6A<ARW/K)X
> MF-IZWJE(I%N3M@FQ+>E6M7#>X)69TZYYRL^I3
> MYJ4U5SYSY%9:OH/S_Z<+@#8"J@T`B&C:1+7OG/Y`W_H[U-XW\VXTC
> MUNG]CKYC'WJ)W/.VWE0^%>]SS,'XZ7"LUO6]_:3,]6?^S!
> M$TK33MJF'KU5(6CU;0!P$0#5!@!$-&UU5?NV";V&%4>T,*A*
> M\Z'`0H4VK3JC8:(0,_L(N:6`_KR$E\`=:WO0E_657OSC_8OK%_"W*QUT,_A[
> M:4.55MZI@K&?X>%)9+.^(<2T3:_E>VZY4NOB6U?;:LA=Z1Z(KABX66U3.*]/>DA>YCS><^&?RDWWG/OAT[ABE;Q#2
> M5_QZXY406>G3$7\'16""+$7G-Q6)2LD_BP^MC[3*(7NJ:$W-/"Y]F0NAGT]OK=;.A8#'&TCP:DU.&WHM0U'7ETNZ
> M9JU.5_+BG9K1ALBB4M+5^-$JY23^`;Z9Y![]'?SM2BEP0N`_2AWZ4
> M5O:O&/RT!#]8`"Y*H-H`@(BF3513CTI4#NW&M<M)43W]M(+(MH"GDM"U?
> M*Z!L+(2JU$^N;-6/K-:/5<Z\&&;FL?Z.^LEU&";4#_)OQ%_2T(_23^XY;="#Z4^,*'EC7.54/G)YT()'?_MZ
> M+V@OBM%ZBMQZCHQCMISD?,A:8@`'R1%6O$//XX";CEII;5X^^,N1^%/RS
> M^18[S?R^<F`WKE5.0O54D-T#7T<PLM+?12'DM&>VEE8V%D)7\O3^4O`>=6/]
> MK=J(P%9?T5_?_(2R'(32^?2C0DS.M<I)J)X`7)Q`M0$`$4U;J3;#/OW+D7?V
> MG?OPP(6/#ESP*!^YS#5->K:$M<,G)GY'"?(2;ZUL]]9K'61KH+;(7H$U^LZ&
> M409_X@JER3ASP/!06VJJO[ZL6\\_0FOU%0*Z!Y=\:)WT92[XYO<O%;*G%^ZE
> MG.MG".B@T-2T+5]+*QL++:GTURKHNFE%_S,4-(EW9[+=W\'?0R'4A%ZTQ^9?
> MP$?00FI93M[BIP6`BP^H-@`@HFE#U68V[MG<?_Z3?YHT^"]3[N/C_<G/G?Z;
> M:Q0#4FC"1:2ZJ,W:Q]IT'?S#-<'Q#?!6:)T#"LK'YK0^AD%,\,S:<'_G)CYI
> M9^@?:BPE)OHJM5:MX)LKX'YSVDCO%KWG06N=YOGTE4-,)NO]U1IJ>XAI6[R6
> MOZP]+G4I8T]]I3*]>N9?R+L?[N<K:W-JSU7`)+ZN7-7,#\L_8>!@B>RK/@G:
> M7+YG11L5L*A_<FTF_:S&%0"XF(!J`P`BFK95[?"B4YYSH_5<I]6V!,(/?E@`
> MM`90;0!`1/,#5FUY!;%U#+G55+OUM@3"#GY8`+0*4&T`0$3S@U-M_S_&^_[1
> M_MPY1]4.QY9`F,`/"X!6!JH-`(AH?L!7M0$``+0Y4&T`0$0#U08``!`^H-H`
> M@(@&J@T``"!\0+4!`!$-5!L``$#X@&H#`"(:J#8``(#P`=4&`$0T4&T```#A
> M`ZH-`(AHH-H```#"!U0;`!#10+4!``"$#Z@V`""B@6H#```('U!M`$!$`]4&
> M```0/J#:`("(YNQ4NR+1^]75&LH7EY_C%YBW!O)[M=4]G-5F_,-;BW-^3EI_
> M2P``</Z`:@,`(IISNZH=Y)'G4[5/NU;+-Q/6;9_/YP0``"XXH-H`@(@&JAWF
> M;9_/YP0``"XXH-H`@(BF]56[(NE6_UM*%.1;(%02*[Q5&H8V?X766YDVR?N>
> M%65:KO$A.\D.B8D\CD^T+87<C-:JE?GHPS>5?WC`H@J^[2EM_FH%94B3*VJ%
> MP')S$ZH$SA"T)?VL``!PX0'5!@!$-*VMVCX'E$55E75]*A(#M5!J9F"-?YBN
> M49E6F\PXK5+K7T,_2BT&3*4?U7QER$6])<60M5$JRA"U+L2*6B&HLID)50(Z
> M!V]$:P0`@`L2J#8`(*)I_:O:WE-?65%(/ZHIJL@F_7EP#4]AT$FM'+)27]97
> MRI,SG"I4)6]/JPOHH!)0PR>!*^I;?>60$_J?,?6I:'8&``"XL(%J`P`BFO.B
> MVGY[#L#8%%C#4P3:JKX<LE)?UE=J\YZV9[.5/(U6%]!!15]C7/$L)E1I=@8`
> M`+BP@6H#`"*:L*NV+#1EA=)'`YMD9Z]K:[+:Y+3&2GV9"[Y:_U3^DJZ]J>$A
> M*W43^3NHR%9O58C--[5T,Q.J:#-H!5U97P<``!<>4&T`0$03?M7V6J07KVQJ
> M<#<OWA9_YU!3Z<K>D7)8R`ZRH'Q6TM=+Q3N,JQ*;G4HK!)9]PYOZ6*1AQ1!C
> M]4LW.Z&*-H-N*JVLKP,`@`L/J#8`(*(Y-]6.8'07J7V<F_:&F!```"YZH-H`
> M@(@&JGUVL%8;O/J<5#O4A```<-$#U08`1#10[3.AN;?"G)5J-S\A``!<]$"U
> M`0`1#50;``!`^(!J`P`B&J@V``"`\`'5!@!$-%!M````X0.J#0"(:*#:````
> MP@=4&P`0T4"U`0``A`^H-@`@HH%J`P``"!]0;0!`1`/5!@``$#Z@V@"`B`:J
> M#0``('Q`M0$`$0U4&P``0/B`:@,`(IH+0;7_.7$#QWL"``#@!P14&P`0T;2Y
> M:K-DCTK^F'/!V+;O^]7EEZ:?Z1>MGQN\,F-84VXDL<+;JA#X'>ZZ!HEAO&QO
> MX0/Q?U&\;PFM1K>F<<+@&N,H;9.^;KI=-[=6$*=?6D%?:5B(*PP#``#A`JH-
> M`(AH+@35GICUZ:2LC5QX=QIQO`UM1EN9F%3"$([)_JEL9]LVWYZ:Z"@)WKLB
> MKXF)+7U$%4G>;KXEY'AE*5_!.&&()0RC=/ORE8P/QS@J$.-"QAJ5;4F)MVHO
> MDT(];SPP:`@`(%Q`M0$`$4W;JC;K-6?^\B\7+-_,!=>AY9RV%FZ_%IY?0J\;
> MR@JY9P@599K8^ED\(G6(3GIUQ5`3ZFN,HW0/0E?TP6/5/B'7"J+YI14J$F]-
> M2C)T8]2%@HL`@+`"U08`1#1MHMJJ87-RJK9.SOXXM^I;+O"ILSK759V[J:"W
> M8]?4-9-)9HKAO[K2P[SHO.G6Q$1YA5-6^#J$]BW_<$VU@JHT=0LL5&C3JC,:
> M)@HQLX^06PKHSTMX"=PQ=PJL4,<95E#0-AQ$R/K`:8*Z>)?5US955CE=3_Y_
> MW\,,VKMO'TW-$(2Q*:B&YU,7"IXAX`%['R``(.Q`M0$`$4V;J/8S4U<KJ7IG
> MXUXM_4=_X*[_BK-I1:+S:$GYC)\Y=[S.\8[QP@KE\R6I3JHNR4J?./D[R/9F
> MM$Q>^^22?Q8?6A]]P3>3UIWK-&^3&&?6D,,-6S+VU]7XT2^CC&8"UM41<@))
> M$PVZN?7+J`LII_IJ_23&"8-:C:-\F_<W!3V<D*.,&)L":[S3Z"M#/F_>?@"`
> M<`/5!@!$-&VBVG>_6*4FIVKKL%EO%[ZS??F[V^]^J<JY9S9G4^Y=CJTCRD91
> M^2CBHW>,BB:!"CY=TGD5=_![E]ZW%#3?4^'!@1,J:*.,!0F?R`'*5/Y:X\P:
> M(;<4HG_`*CZ\JP7`=<;*)L8K--6B31[PXD`WO7Y@4V65YGOJGF6N"-J\MR;4
> M#/YG21NB[Z:BK]&>:V,W;2&5@)\*`"!\0+4!`!%-FZBVQFU/%O_AR>*LE5NR
> M*K=PP;ESLG/GI.7#B>/M$83.V1AV)^5$YU4!!F7PK<#A$F.-?Y2QP`0,D">J
> MOH68QP<W&;?4W+IZN-(X;5,]C94J33:I6]-O,'!?NI:`!N.$^AKC*&[5QNI:
> MO:ACFUHKB.:7YK*>YGLVM00`H#6!:@,`(IJV56WF?Q[*GU/XY9R"35Q8]B)Q
> MO`VAD2[E522_D`7+EEHKV[WU6@?9&NA?LE=@C;ZS893!`KE":3+.'#`\U)::
> MZJ_'-[T>?T=_R?`P]+,%S:P[E=,G)LHW-RL$=52G51JU@H*A7V"-812W^D8'
> M3B3Q#6UBK2!.L[2/4)7Z.E[#.`@`$`:@V@"`B.9"4.T)F9].S-S(!6]5\T@1
> M"[IF&>A5?.9MUCZ#J.O@'Z[9GV^`MT+K'%!0/G:I]3$,8H)GUH;[.S?QL4A#
> M?QT^)PRQ;]T0V1HX6&W2C]*>,/U"2@?O?(&=O=6^2N\(XX0AEP@:%3`N8%J)
> M]G`,HP(P+F2LT0AX9GQH"RGMNC,`0/B`:@,`(IHV5VV&);NEGGU&2,MJ%9_2
> MN^FY<19;XB&MM#CP@><4@/,'5!L`$-%<"*H=)EB06\F06TVUSVY+K?:2`2C(
> MGP*>3P#.%U!M`$!$\X-3;>FE/EK+I\Y1M<.Q)0``N#B`:@,`(IH?\%5M````
> M;0Y4&P`0T4"U`0``A`^H-@`@HH%J`P``"!]0;0!`1`/5!@``$#Z@V@"`B`:J
> M#0``('Q`M0$`$0U4&P``0/B`:@,`(AJH-@``@/`!U08`1#10;0```.$#J@T`
> MB&B@V@```,('5!L`$-%`M0$``(0/J#8`(**!:@,```@?4&T`0$0#U08``!`^
> MH-H`@(@&J@T``"!\0+4!`!$-5!L``$#X@&H#`"(:J#8``(#P`=4&`$0T4&T`
> M``#A`ZH-`(AHH-H```#"!U0;`!#10+4!``"$#Z@V`""B@6H#```('U!M`$!$
> M`]4&```0/J#:`("(!JH-```@?$"U`0`1#50;``!`^(!J`P`B&OZ/(````!`^
> MO'_?M`RH-@```.#')=Q:A$?XX_;'+MQ:^-SEM`N/2VF8L7'F]9OF_7+'XEN=
> MI60O)D<)<4&LN+0V-WKM"&HH2'`6FT_FD7BWDZO$XBPA417M*"91:145=/J4
> M<S>;+V9=>`F3+Y;3)V!LF%-^NI29SBG\G)19M'A*S<U'\+.M97F\%G>I58NG
> ME#CN$AEG(8F5\9YBB[O([%K*0RRB)$I4Q(FB&%$8Y5YJYJ.K@'\Z5E$9U9A'
> MQW*Z.$I^=#RW:\H`&O5WFCJ(QO>A+U-_*[[\S?ZRSL?77%VS^LJ1?:W#>]"K
> MO<VC^MF>'ACW6!_;__V=^M]./6],N/NZJ#M_;KWK%[8_W4"#_D+_UXV>&FA[
> M^@[B/',GC1K8?MD0VC2KXQ<S.VR>T^FU7O3,[?3QPM^^.^/&#7/IXSFT9A*)
> MK__74QEC+[4T%)O$JKB:HG:-JRX3G]^X+\>Z<V[GO8LNWSV_ZZ&,:S[-_-6W
> MA;>]W)/N^R7]]J9KA>>$C.M8P)]YT>B/AW\=O+$+_A7PAG]/N*=Z%,Z],N[]
> MHFZ'*.WD*;FD<5F\O2#!461QE=B<Q59/6;0GW\)/FC.7'#ET*I_JELKP;T1#
> M3ESM8EMC;OS)S*B3.983V:93>3;.5UE_^&31_PC7'-$X0SAY"24.T2#\$2ZW
> M-Q<D4&T```"@";2_VCDZU7:*DUID$QN'<MR11">RR+XL1I1V8+T0Y3'L%N[2
> M*'LA2YLBA1RVZI4V>Q&)56QL)&U[E<53SJ[<1/2JW90N^SW;).</F:;&ACM!
> M8ATR0?9\1E&?U9:K-K_RT5+848N^C^;<_')(E,7:\\E9P$]R@H?MO(+<14J6
> MD>`?(H==O*2](]?JX9][<3NQG`0W\<!<VE;1\Y4!-*POC;F?7NY%,Q^/2GGA
> MDM$#9<W(P?1B+^+6H0/C'^U&_6^E;K^B[M=V[/G33IP>/[F$5?NO-Q$?'^[1
> MY?'^\0_UL#[2*^K![I;7[J&Q/6G>(_3>M!]_^N9E7\_Y$1^_G'G55S/;;9AH
> MJ1I.:UXE4?WKNM6V^C71)ZOXY]Y%E'8499>(HG8GRG[Q74;G[Y=<OCOKTGTY
> ME^_)ZGJXX!HN/#[@^C_^M^E/-YJ%YTMV9BV!OP!U6@(TU^U1)-LECZZ/A=@H
> M/)]\5#96+#.+?),\%D755U##"G)6F6I+R+7$XLFUB;PH/K)JLV37YLK4+XD^
> MD6&VY\4=3S?5Y<379L<>SXP^FF[=FG7]MYG_Q1'NUSWU_NV<$OX(M\.;"Q*H
> M-@```.#')>JU2'O0PI+-?Y6S@+B%R\4E*=T>#QO&;F'?+IS?Y:>,/I%"GJ5L
> M8S'R6-[9L2Q.%'>H6V)M9,]81?9*>0PV45\\Y2;=J<^MI5[K-/J<HE/MD/&M
> M[BDW<;P*:XQ^;RV*]J!:%(^R>O,)MNW31;U*[4VQ28TH,3<=JS_%NO#+)RW+
> MS;I8M7C8O$O))6V;&G.O]!1>>S+STK1>-+K'Y9S7NE\VLEO7Y_]I?6H@#1E,
> MS]Q+PWI=\\2?._:ZCGK^@KK?:+KK/^G.Z^CN_Z+;;S#]]5=1?[B>_GR3]=5[
> M.SW?._:9[K:G_FX>VLTRY"YZYFX3'U/^12O'T*=S.VR<T_Z+I*O6C>^T9F1L
> MV0NT;1J)CZ[W%'<6I5T=*]K/[4>-Y0F<ZLI+Q=;??U>8\&U>]+[LJ_=F756=
> M^^,]BZ^H+KAE5_:ODP;0P]?1+V_XD>`7D*[C?&2M/B$\JE_+UY.-OJ.;_\>_
> M`C(._G7@:I>BYO9,SI["P;N6#73E7?GY2'(OO8I37T;V%51;)'-\F46+R"2.
> M9[',T5P+YTB.F5.;;>*7K,<SZ=ABJLZ\8F_:I1QQZFGU.CJG0?U]],4C?5]&
> M^0V^X(!J`P```'[T=JW_ZUPX'?)?SY6C6]@=[GJ/<+C8.QI+A*=R5<J@E<D#
> M19YR13.7_=)6GQO%MKUGMG1NSTJSHYP:V?-6!IME$]&I:K`QMTH,GLT)WH,N
> MYU&U.1Z#6P<ER*1;$DVU#58=,F>JVKJ4D[M4OC5"/O:E,9XE_*1UYN.N_-]-
> M[$<3^M+8'C3TOF@U3_8W/=^SRX/_:^Y[$_7_%=U^+0WX/0V^C>[[`]U_=^R@
> MOUH'WV'K>SO=?2U-?J3+B`%1+_:@YWJ8GKZ;GNE&S]Y#+]Q)S]U!D^Z/SA[^
> MTT]G7;(AJ7WI<%KV'"U[BCY]D\3Z6QI77-=09>'4KS*+#]LU5L6<JK35K;"*
> M([=\O_AGA_)N.)A[/>=0[H\/9%]]K.#G7'C^'[?]_EI3C]]>*AJW-#0H[\YP
> MN3P>]MAZ&=<I/M8*F>.BCH^JB!]3C%R(1[;EQ]>LN>;`BLM$7
Re: Command contribution to EditorActionBarContributor [message #1022290 is a reply to message #1021911] Thu, 21 March 2013 16:04 Go to previous messageGo to next message
Thanks for your effort Wim,
Yes, I've defined that command with the command extension point.
Actually I can use any existing command (org.eclipse.ui.file.save, ...)
and the result is the same. The command is not included within the toolbar.
Defining a handler doesn't help either. Although I don't think it's mandatory to define
a handler for a command to be visible in the menu. It should be disabled,
but still visible.
Re: Re: Command contribution to EditorActionBarContributor [message #1022396 is a reply to message #1022290] Thu, 21 March 2013 19:35 Go to previous messageGo to next message
Does this help?
http://www.eclipsezone.com/eclipse/forums/t115168.html
mandatory to define
> but still visible.
Re: Re: Command contribution to EditorActionBarContributor [message #1022621 is a reply to message #1022396] Fri, 22 March 2013 08:54 Go to previous message
Unfortunately it doesn't.
My problem is about declarative contributing a command to the toolbar created by EditorActionBarContributor class.
I don't use visibleWhen on that command.
Previous Topic:Editable tableitem
Next Topic:Project Explorer View
Current Time: Sun May 27 19:59:05 GMT 2018
Powered by FUDForum. Page generated in 0.02306 seconds
