Home » Eclipse Projects » Target Management » Remote System Explorer bug?(have bug?)
Remote System Explorer bug? [message #1018638] Thu, 14 March 2013 08:41 Go to next message
CHEE FEI TONG is currently offline CHEE FEI TONGFriend
Hi all
Before start, i apologize for my broken English
i try to use eclipse remote system explorer(in windows 7) connect to my windows XP laptop, it work, can edit file and do anything, but after i disconnect and close the daemon. i cannot open any Folder and the "My Computer" in the windows XP.Can i know what is the reason cause this??
i use System Restore, restore my windows XP back to the day before eclipse connect, then windows XP back to normal,
Re: Remote System Explorer bug? [message #1019034 is a reply to message #1018638] Thu, 14 March 2013 23:10 Go to previous messageGo to next message
David McKnight is currently offline David McKnightFriend
I'm not sure what would cause that. I don't normally work on windows this
way but, when I tried, I couldn't reproduce this. What level of RSE were
you using?
"CHEE FEI TONG" <forums-noreply@xxxxxxxx> wrote in message
news:khsi4d$p8a$1@xxxxxxxxe.org...
> Hi all
Re: Remote System Explorer bug? [message #1019061 is a reply to message #1019034] Fri, 15 March 2013 00:49 Go to previous messageGo to next message
Hi David,
thx for your reply.i using Eclipse Juno , Remote System Explorer End-User Runtime version 3.4.1.201302122026
Can i ask you 2 question?
1)i am doing student project,i connect to windows XP is just a testing before i connect HP-UX server.
Is it connect to HP-UX server will have same problem??
2)Can you teach me how to connect to HP-UX ? eclipse (windows 7) and HP-UX server need do any setting or install/run anything?
Zachary Tong
Re: Remote System Explorer bug? [message #1019356 is a reply to message #1019061] Fri, 15 March 2013 14:18 Go to previous messageGo to next message
Hi Zachary,
1) I wouldn't expect this in any scenario. Since we test on unix systems,
I'd expect HP-UX to be in better shape. I'm assume you're using dstore for
the windows tests - note there are also other ways to connect to unix, like
via SSH or FTP.
2) If you're using dstore, then you have to put the server jars and scripts
on the host machine. If you have admin access, then you can start the RSE
dstore daemon (i.e. daemon.pl). If not, then you may have to either connect
manually (by starting server.sh and connecting to the appropriate port) or
by using the REXEC option of starting the server. If you're not using SSH,
then you can connect via whatever SSH daemon is running and it's a similar
story for FTP.
news:khtr76$ah7$1@xxxxxxxxe.org...
> Hi David,
> Regards
> Zachary Tong
Re: Remote System Explorer bug? [message #1019540 is a reply to message #1019356] Fri, 15 March 2013 23:53 Go to previous message
Thx David,
after i try on HP-UX, then i tell you the result
thx for your teaching ^v^~
Previous Topic:Makefile of synchronized project generates with "RM := del" instead of "RM := rm -rf&
Next Topic:RSE Export / Import All Connections
Current Time: Tue Apr 24 23:21:08 GMT 2018
Powered by FUDForum. Page generated in 0.02309 seconds
