Home » Newcomers » Newcomers » Initializing project state error
Initializing project state error [message #1017193] Mon, 11 March 2013 02:17 Go to next message
Marjan Bazalac is currently offline Marjan BazalacFriend
I get this error every few minutes. What is this?
java.io.IOException: The filename, directory name, or volume label syntax is incorrect
	at java.io.WinNTFileSystem.canonicalize0(Native Method)
	at java.io.Win32FileSystem.canonicalize(Unknown Source)
	at java.io.File.getCanonicalPath(Unknown Source)
	at java.io.File.getCanonicalFile(Unknown Source)
	at com.android.tools.lint.detector.api.Project.<init>(Project.java:161)
	at com.android.tools.lint.detector.api.Project.create(Project.java:110)
	at com.android.tools.lint.client.api.LintClient.createProject(LintClient.java:592)
	at com.android.tools.lint.client.api.LintClient.getProject(LintClient.java:572)
	at com.android.ide.eclipse.adt.internal.preferences.LintPreferencePage.createContents(LintPreferencePage.java:166)
	at org.eclipse.jface.preference.PreferencePage.createControl(PreferencePage.java:232)
	at org.eclipse.jface.preference.PreferenceDialog.createPageControl(PreferenceDialog.java:1501)
	at org.eclipse.jface.preference.PreferenceDialog$14.run(PreferenceDialog.java:1258)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1252)
	at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:674)
	at org.eclipse.jface.preference.PreferenceDialog$10.run(PreferenceDialog.java:708)
	at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(PreferenceDialog.java:704)
	at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:867)
	at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:865)
	at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1205)
	at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1230)
	at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:251)
	at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:245)
	at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java:419)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:157)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
Re: Initializing project state error [message #1017462 is a reply to message #1017193] Mon, 11 March 2013 21:46 Go to previous message
David Wegener is currently offline David WegenerFriend
This is an indication that something in the Android tools is doing something that leads to the problems. Android tools are provided by Google. You will need to pursue your question in an Android tools support forum.
Previous Topic:Install Eclipse
Next Topic:Creating a custom class with a pre decided template
Current Time: Mon May 28 05:32:42 GMT 2018
Powered by FUDForum. Page generated in 0.02609 seconds
