Home » Eclipse Projects » Remote Application Platform (RAP) » [Theming][Text] Internet Explorer ignores css tags on disabled Text Widgets(Not possible to get rid of shadow on disabled Text widgets)
[Theming][Text] Internet Explorer ignores css tags on disabled Text Widgets [message #1016927] Fri, 08 March 2013 08:58 Go to next message
Fabian Henniges is currently offline Fabian HennigesFriend
RWT renders Text widgets as HTML input elements with style.
Disabled Text widgets are rendered as input elements with disabled=true.
While theming works fine on these elements in mozilla and webkit browsers, IE ignores it.
index.php/fa/13746/0/
You might reproduce it starting up the RAP demo and changing the rendered HTML with some web dev tool.
I do not have an idea how to fix or workaround. You?
Re: [Theming][Text] Internet Explorer ignores css tags on disabled Text Widgets [message #1017078 is a reply to message #1016927] Fri, 08 March 2013 21:05 Go to previous messageGo to next message
Markus  rüger is currently offline Markus rügerFriend
If I remember correctly, this is not an issue of RAP. It is an IE isse thst
dors not allow the change of the background color. Maybe IE10 csn do it,
but IE 7-9 does not. A common workaround is to use readonly instead of
disabled.
> [Binärdaten ausgeblendet...]
[Updated on: Mon, 11 March 2013 18:24] by Moderator
Report message to a moderator
Re: [Theming][Text] Internet Explorer ignores css tags on disabled Text Widgets [message #1017238 is a reply to message #1017078] Mon, 11 March 2013 09:36 Go to previous message
Maybe it is possible to let the client part of RAP handle this quirk of IE.
Rendering the disabled Text as <div/> instead of <input/>?
Previous Topic:Image Map
Next Topic:deployed war reports 404 but works in IDE
Current Time: Sun Feb 25 13:59:24 GMT 2018
Powered by FUDForum. Page generated in 0.01254 seconds
