Home » Eclipse Projects » Memory Analyzer » how to Install Mat on Linux via Terminal(Installation and Run MAT)
icon10.gif  how to Install Mat on Linux via Terminal [message #1016730] Thu, 07 March 2013 13:55 Go to next message
kiran shrimali is currently offline kiran shrimaliFriend
Hi Frnds,
I am Learning Eclipse MAT and understand how to work with it.
But i am not Getting how to install this on Linux system via Terminal and how to run in Linux.
Even i am trying to get help from online but no success. So i Request you to kindly do the Needful.
Re: how to Install Mat on Linux via Terminal [message #1016936 is a reply to message #1016730] Fri, 08 March 2013 09:26 Go to previous messageGo to next message
Krum Tsvetkov is currently offline Krum TsvetkovFriend
I don't think we have a special description for linux.
If you have already a running Eclipse installation, then you can just install the MAT bundles into if from the update site (listed on the downloads page).
For a standalone standalone MAT, you just download one of the zips unzip it.
If you want to use the GUI you should and have an x-server running somewhere and export the display accordingly, but this is nothing MAT specific. Then you can start <mat_install_dir>/mat/MemoryAnalyzer.
Otherwise (without GUI) you can only use the ParseHeapdump script, to get a heap dump parsed, and eventually a report execuced.
Does this help?
icon14.gif  Re: how to Install Mat on Linux via Terminal [message #1017173 is a reply to message #1016936] Sun, 10 March 2013 13:51 Go to previous messageGo to next message
Hi Krum Tsvetkov,
Thanks for your Reply Smile .
I have install Eclipse Platform in VM Linux Ubuntu 12.4 lite Version. And Updated it with MAt Dump Analzer.Screen Short attched. Now i am looking for a tutorial and Help book were can i read the use of MAT Dump Analzer.
Plz Explain me what is x-server & <mat_install_dir>/mat/MemoryAnalyzer.
My Objectives.
1. Want to Learn MAT Dump Analyzer.
2. How to Load Dump and Analyse the Dump.
3. How to Extend this Skills for Huge Dump Analysis.
  • Attachment: Installed.jpg
    (Size: 150.40KB, Downloaded 786 times)
Re: how to Install Mat on Linux via Terminal [message #1018125 is a reply to message #1017173] Wed, 13 March 2013 08:02 Go to previous messageGo to next message
After you installed MAT, you should be able to find the MAT documentation under Help.
We have some further info in Wiki, like:
http://wiki.eclipse.org/MemoryAnalyzer
There are two Webinars (recorded demos):
http://live.eclipse.org/node/939
http://live.eclipse.org/node/520
And I find these blog grom Ian Bull very helpful:
http://eclipsesource.com/blogs/2013/01/21/10-tips-for-using-the-eclipse-memory-analyzer/
Krum
Re: how to Install Mat on Linux via Terminal [message #1018126 is a reply to message #1017173] Wed, 13 March 2013 08:02 Go to previous message
Krum
Previous Topic:Custom MAT plugin not loaded on startup
Next Topic:HeapDump
Current Time: Sat May 26 12:08:12 GMT 2018
Powered by FUDForum. Page generated in 0.02717 seconds
