Home » Eclipse Projects » SWTBot » Scroll an eclipse view using SWT BOT(Scroll an eclipse view using SWT BOT)
Scroll an eclipse view using SWT BOT [message #1016522] Wed, 06 March 2013 18:41 Go to next message
Anthony Ghonsalves is currently offline Anthony GhonsalvesFriend
My Perspective has multiple views.
1st View - Criteria form at the top
2nd View - Results form in the bottom.
The first view which is a criteria form needs to be scrolled so that i can set values to the controls displayed on that form.
Is there a way to accomplish this using SWT-BoT.
Re: Scroll an eclipse view using SWT BOT [message #1016649 is a reply to message #1016522] Thu, 07 March 2013 09:14 Go to previous messageGo to next message
Rüdiger Herrmann is currently offline Rüdiger HerrmannFriend
Anthony,
do you use a ScrolledComposite in your 'criteria form'? If so, there is
currently no bot for ScrolledComposite (i.e. SWTBotScrolledComposite).
You can either write a custom bot or just try without. Did you actually
try to let SWTBot set values without scrolling the widgets into view?
HTH
Rüdiger
On 06.03.2013 19:41, Anthony Ghonsalves wrote:
> My Perspective has multiple views. 1st View - Criteria form at the top
> Is there a way to accomplish this using SWT-BoT.--
Rüdiger Herrmann
http://codeaffine.com
Re: Scroll an eclipse view using SWT BOT [message #1016672 is a reply to message #1016649] Thu, 07 March 2013 10:18 Go to previous message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
I have some swtbot tests acting on a form inside a ScrolledComposite,
and, as far as I remember, I can access widgets in the form with swtbot
even if they are not visible in the running eclipse instance...
cheers
Lorenzo
On 03/07/2013 10:14 AM, Rüdiger Herrmann wrote:
> Anthony,
> HTH
> Rüdiger
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Previous Topic:More on EclipseSpy
Next Topic:Unable to Enter Text in a Tree Cell
Current Time: Wed Jun 20 17:36:04 GMT 2018
Powered by FUDForum. Page generated in 0.02295 seconds
