Home » Eclipse Projects » Eclipse 4 » Trying to get E4 services(I guess I'm not understanding injection)
Trying to get E4 services [message #1016293] Tue, 05 March 2013 21:22 Go to next message
Jo Jaquinta is currently offline Jo JaquintaFriend
Member
So there is an E4 service I want to use in a class. Everything I read says that I get it by using injection. For example:
@Inject IStylingEngine mStyler;
However, this code only seems to work in classes that are directly invoked by the E4 layer. I.e. if I have a class that is a Class URI for a Part, then mStyler is correctly set. However, if that class uses other UI controls, and further down, one of those controls uses this code to get at the service, it is never set.
Following some other posts, I tying using E4Workbench.getServiceContext.get(XXX) or even creating an IEclipseContext from my bundle. But these always return null when I ask it for the service.
So is there any way I can get a service from an arbitrary point of code? It's going to make things awfully ugly if I have to resolve it at the point my code touches the framework and then pass it down the constructor stacks.
Jo Grant, Senior Software Engineer
Admin and Config Console Architect
OpenPages, IBM
Re: Trying to get E4 services [message #1016302 is a reply to message #1016293] Tue, 05 March 2013 22:50 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
You need to create instance of your subclasses using
ContextInjectionFactory.make()
Tom
Am 05.03.13 22:22, schrieb Jo Jaquinta:
> it for the service.
> constructor stacks.
Re: Trying to get E4 services [message #1016479 is a reply to message #1016302] Wed, 06 March 2013 15:41 Go to previous messageGo to next message
Member
Hey Tom,
Thanks for the response. That will come in useful. Someday. But since you need an IEclipseContext before you can call ContextInjectionFactory.make(), I'm still stuck as described. I don't know how to get the default IEclipseContext to pass in.
I've tried the following:
class Test
    @Inject
    public IStylingEngine mStyler;
invoked by:
        try
            IEclipseContext context1 = E4Workbench.getServiceContext();
            Test t1 = ContextInjectionFactory.make(Test.class, context1);
            if (t1.mStyler != null)
                System.out.println("Case 1 works!");
            else
                System.out.println("Case 1 fails");
        catch (Exception e)
            e.printStackTrace();
            System.out.println("case 1 fails");
        try
            IEclipseContext context2 = EclipseContextFactory.getServiceContext(Activator.getContext());
            Test t2 = ContextInjectionFactory.make(Test.class, context2);
            if (t2.mStyler != null)
                System.out.println("Case 2 works!");
            else
                System.out.println("Case 2 fails");
        catch (Exception e)
            System.out.println("case 2 fails");
        try
            Test t3 = ContextInjectionFactory.make(Test.class, null);
            if (t3.mStyler != null)
                System.out.println("Case 3 works!");
            else
                System.out.println("Case 3 fails");
        catch (Exception e)
            System.out.println("case 3 fails");
All of these report failure.
OpenPages, IBM
Re: Trying to get E4 services [message #1016497 is a reply to message #1016479] Wed, 06 March 2013 16:54 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot CelaFriend
What does the invoker look like? There is no default IEclipseContext. There are a lot IECs (the context hierarchy) and an active one. The idea is that when you do CIF.make(C,IEC); all the @Inject's in C are looked up in the IEC context and it's parents. So this invoker guy is part of your application or some out of container JUnit test or something else?
Re: Trying to get E4 services [message #1016516 is a reply to message #1016497] Wed, 06 March 2013 18:07 Go to previous messageGo to next message
Member
The problem is that this depth of code can be arrived at through a variety of means.
I have need of different services throughout my code, but for this, specific, example I have a Composite that creates a whole bunch of UI and wants to style it. (I am converting it from org.eclipse.ui.forms to being e4 CSS driven.)
Sometimes this Composite is constructed in a MPart, but other times I use it directly in a Dialog. (The dialog is launched by clicking on a button with is nested several layers down in a MPart.)
I understand that for a lot of things you want a context very local to the model element in question. But my understanding is that services are generally connected at the very top context, and are, pretty much, universal throughout. If they are, essentially, global, I'd like to be able to access them globally.
[For now I have an ugly hack. I have a startup handler, which gets passed an IEclipseContext. It passes this value to my style control code. Later, when the style control code is requested by the Composite to apply a style, it gets the IStylingEngine from the IEclipseContext it was initialized with. It works. But I'm pretty sure this is not "best practice".]
OpenPages, IBM
Re: Trying to get E4 services [message #1016648 is a reply to message #1016479] Thu, 07 March 2013 09:14 Go to previous messageGo to next message
The service context is to high in the hierarchy. The main Context layout is:
ServiceContext (E4Workbench.getServiceContext())
+ WorkbenchContext (connected to the MApplication-Instance)
The reason for this is that ServiceContext is bound to the OSGi-Instance
so it is a singleton, whereas there can be multiple WorkbenchContexts in
multi-user envs.
Tom
Am 06.03.13 16:41, schrieb Jo Jaquinta:
> Hey Tom,
> know how to get the default IEclipseContext to pass in. I've tried the
> following:
> class Test
> @Inject
> invoked by:
> try
> else
> catch (Exception e)
> try
> else
> catch (Exception e)
> try
> else
> catch (Exception e)
Re: Trying to get E4 services [message #1016651 is a reply to message #1016516] Thu, 07 March 2013 09:15 Go to previous messageGo to next message
Best pratice is that *ALL* instances are created through CIF.make() why
can't you create the Dialog, .... also through the DI-Container. I don't
see a reason you can't do this.
Tom
Am 06.03.13 19:07, schrieb Jo Jaquinta:
> variety of means.
> practice".]
Re: Trying to get E4 services [message #1016655 is a reply to message #1016651] Thu, 07 March 2013 09:27 Go to previous messageGo to next message
@Tom, I think his issue is that he doesn't want to drag down the IEC which has to be supplied to CIF#make.
If you don't want to extend this context hierarchy downards then I think, theoretically, you can access a top level context and traverse its children until you find a suitable context. But still I think that letting the DI container ( creating what you need with CIF#make) do the instantiations is a better idea, despite the depth.
I'm not sure I fully understand your issue but I hope this helps. Also here's a simplified diagram about the context hierarchy in this slideshow http://www.slideshare.net/smcela/eclipse-4-context-functions
Re: Trying to get E4 services [message #1016659 is a reply to message #1016655] Thu, 07 March 2013 09:41 Go to previous messageGo to next message
There is not navigation from Parent to Child IIRC.
But I see problem and I thought about that often myself as well because
I wanted my POJO code free of any Framework stuff as well - e.g. to make
use of them in a Guice-DI or Spring-DI context.
a) define an interface
interface DiCreator {
public <O> O creatInstance(Class<O> clazz);
public DiCreator createChild();
public void setValue(String name, Object o);
public void setValue(Class<O> clazz, O o);
b) Contribute this as the context function using DS
=> You can use DI but your code does not depend on IEC
Tom
Am 07.03.13 10:27, schrieb Sopot Cela:
Re: Trying to get E4 services [message #1016749 is a reply to message #1016651] Thu, 07 March 2013 14:52 Go to previous messageGo to next message
Member
Well, to do this, it would end up being something like this.
My part would have to create it's main Composite extended panel via make. That panel would have to create the launcher sub-panel via make. The launcher, catching the button click, would have to create the Dialog via make. Then the Dialog, when creating it's Composite extended panel, would have to create it via make(). THEN that panel could access the style object to add CSS styling.
I appreciate in the purest sense that this is the "correct" way to do things. But in a pragmatic sense, that's an awful lot of trouble to go through just to apply some CSS styling and use a service that is going to be, pretty much, global anyway. When you add in the fact that in most cases all of the non-model SWT level code is being ported over from a non-e4 environment, it's a rather large burden of work and changes necessary in order to make use of one part of e4.
OpenPages, IBM
Re: Trying to get E4 services [message #1016756 is a reply to message #1016749] Thu, 07 March 2013 15:20 Go to previous messageGo to next message
You asked for the correct solution ;-)
Like I already outlined what you expect to be a singleton is from the
frameworks point of view not a singleton (I gave you the Vaadin/RAP
usecase already).
Please note that we are publishing the IWorkbench in 4.3 as an
OSGi-Service so you can get access to the instance query the OSGi-Registry.
You are free to creating singletons to shorten call paths if you think
they are the better solution but the framework can't and won't hopefully
provide it.
Tom
Am 07.03.13 15:52, schrieb Jo Jaquinta:
> Quote:
Re: Trying to get E4 services [message #1016757 is a reply to message #1016756] Thu, 07 March 2013 15:33 Go to previous message
Member
I understand you have to balance taking a pure approach against things that will be a barrier to adoption.
Thomas Schindl wrote on Thu, 07 March 2013 10:20
We're targeting 4.3 for our release, so this is fine. I'll keep my hack for now and move over to this when it is available.
In the meantime, I'll see about making sure all new code we write use make().
Thanks for your help!
Jo
OpenPages, IBM
Previous Topic:What is your 2013 environment configuration for an RCP project development?
Next Topic:Commands in Form Toolbars
Current Time: Mon Apr 23 23:35:46 GMT 2018
Powered by FUDForum. Page generated in 0.02261 seconds
