Home » Eclipse Projects » Remote Application Platform (RAP) » RAP File downloading
RAP File downloading [message #1016177] Tue, 05 March 2013 11:05 Go to next message
Markus Duft is currently offline Markus DuftFriend
Hey. Me again Smile
In our application i want to send a download to the client. The file is generated on the fly and sent to the client. So far everything works like a charm with this code:
    public boolean sendDownload(byte[] data, String filename) {
        DownloadService service = new DownloadService(data, filename);
        service.register();
        UrlLauncher launcher = RWT.getClient().getService(UrlLauncher.class);
        launcher.openURL(service.getURL());
        return true;
    private static final class DownloadService implements ServiceHandler {
        private final byte[] data;
        private final String filename;
        private String id;
        public DownloadService(byte[] data, String filename) {
            this.data = data;
            this.filename = filename;
            this.id = calculateId();
        public String getURL() {
            return RWT.getServiceManager().getServiceHandlerUrl(getId());
        private String getId() {
            return id;
        private String calculateId() {
            return String.valueOf(System.currentTimeMillis()) + data.length;
        public boolean register() {
            try {
                RWT.getServiceManager().registerServiceHandler(getId(), this);
                return true;
            } catch (Exception e) {
                log.error("failed to register download service handler", e);
                return false;
        private boolean unregister() {
            try {
                RWT.getServiceManager().unregisterServiceHandler(getId());
                return true;
                log.error("failed to unregister download service handler", e);
                return false;
        public void service(HttpServletRequest request, HttpServletResponse response)
                throws IOException, ServletException {
            try {
                response.setContentType("application/octet-stream");
                response.setContentLength(data.length);
                response.setHeader("Content-Disposition", "attachment; filename=\"" + filename
                response.getOutputStream().write(data);
                log.error("failed to dispatch download");
            } finally {
                unregister();
the problem i have with this solution is, that it will open a separate browser window, and leave it open (at least with chrome), after the download was sent. is there a way to
1) close the browser window again?
2) don't open a browser window at all, but send the download in the main window (without destroying the running application Smile)?
Thanks!
Re: RAP File downloading [message #1018844 is a reply to message #1016177] Thu, 14 March 2013 15:01 Go to previous message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi.
We are aware of the issue. It was discussed, but no full solution could
be implemented for 2.0. I suggest you open an enhancement request for a
RAP downloader service on Bugzilla. As a workaround you could use the
JavaScriptExecuter to render something like "window.location = myURL".
Greetings,
Tim
Am 05.03.2013 12:05, schrieb Markus Duft:
> Hey. Me again :)
> service.register();
> return true;
> private String id;
> this.data = data;
> return id;
> data.length;
> try {
> this);
> return true;
> e);
> return false;
> try {
> return true;
> handler", e);
> return false;
> @Override
> try {
> } finally {
> unregister();
> window (without destroying the running application :))?
> Thanks!
Tim Buschtöns
Twitter: @EclipseRAP
Previous Topic:RAP nightly download link
Next Topic:RAP Textfield problem
Current Time: Sun Apr 22 16:48:48 GMT 2018
Powered by FUDForum. Page generated in 0.01819 seconds
