Re: Different header on the first page of report [message #1016588 is a reply to message #1016150] |
Thu, 07 March 2013 01:46 |
I think I responded to your question, on StackOverflow. There shouldn't be an issue with this and I wasn't able to recreate it. Can you attach a report design and XML file that will show me this issue? Also let me know the output format. Thanks.
Michael
Developer Evangelist, Silanis
Re: Different header on the first page of report [message #1017320 is a reply to message #1016150] |
Mon, 11 March 2013 15:13 |
You need to set your page layout to "fixed", by selecting a blank spot in the report layout, going to the general section of the property editor, and changing it from auto layout to fixed layout. Then, change all of your tables to have a page break interval of 0 by selecting each table and changing the value in the property editor. Then, when you run to PDF, using frameset, your masterpage headers will behave properly. Hope this helps.
Michael
FUDForum. Page generated in 0.02244 seconds
