Home » Modeling » OCL » Generating .oclinecore file from Ecore programmatically
Generating .oclinecore file from Ecore programmatically [message #1015147] Wed, 27 February 2013 15:18 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
I am creating ecore at run time and i am able to save .ecore file successfully. I would like to generate .oclinecore file programmatically as well.
Once i have tried things like
OCLinEcoreDocumentCS document = Ecore2OCLinEcore.importFromEcore(resourceSet, "test", resource);
now i have updated all components in my eclipse so OCLinEcoreDocumentCS seems missing as well as Ecore2OCLinEcore.
i am trying to explore org.eclipse.ocl.examples.xtext.oclinecore.utilities.OCLinEcoreCSResource as well.
do you have any idea how i can generate .oclinecore programmatically?
thanks!
cheers
Re: Generating .oclinecore file from Ecore programmatically [message #1015171 is a reply to message #1015147] Wed, 27 February 2013 16:14 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
You should be able to find all classes using the Type Hierarchy.
However the CST is not public API so it is likely to change.
If you really want to auto-generate, much better to auto-generate
- the AST, either Pivot or Ecore
- the text
and if you really want the CST you can use one of the concersion
routine. But if you really want the CST, I think you should revisit your
design.
Ed Willink
On 27/02/2013 15:19, ModelGeek Mising name wrote:
> as well.
> thanks!
> cheers
Re: Generating .oclinecore file from Ecore programmatically [message #1015178 is a reply to message #1015171] Wed, 27 February 2013 16:35 Go to previous messageGo to next message
Sorry i did not understand you..
I just want to generate text from my ecore model. I think Pivot2CS class might be the one i am looking for.
I have tried following
OCLinEcoreStandaloneSetup.doSetup();
Injector injector =OCLinEcoreStandaloneSetup.getInjector();
ResourceSet csRS = injector.getInstance(ResourceSet.class);
Resource r = csRS.createResource(uri1.trimFileExtension().appendFileExtension("oclinecore"));
r.getContents().add(modelPackage);
r.save(null);
and i am getting following exception
java.lang.RuntimeException: The context 'RootPackageCS' is not valid for type 'EPackage'
Recommended contexts for type 'EPackage':
The context 'RootPackageCS' is valid for types: RootPackageCS
Semantic Object: EPackage'temp'
at org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:70)
at org.eclipse.ocl.examples.xtext.oclinecore.serializer.AbstractOCLinEcoreSemanticSequencer.createSequence(AbstractOCLinEcoreSemanticSequencer.java:672)
i hope i am not creating more confusion.
thanks!
Re: Generating .oclinecore file from Ecore programmatically [message #1015201 is a reply to message #1015178] Wed, 27 February 2013 17:42 Go to previous messageGo to next message
If you want text then you need
EcoreXMI->EcoreAST->PivotAST->PivotCS->XtextNodes->text
for which the various converters and loaders are all available. Look at
the SerializeTests.
Ed Willink
> Injector injector
> ResourceSet csRS =
> Resource r =
> r.save(null);
> for type 'EPackage'
> Recommended contexts for type 'EPackage': The context 'RootPackageCS'
> at
> at
> thanks!
Re: Generating .oclinecore file from Ecore programmatically [message #1015313 is a reply to message #1015201] Thu, 28 February 2013 08:13 Go to previous messageGo to next message
can you please guide me how to access serialization tests... URL? SVN?
thanks for help!
Re: Generating .oclinecore file from Ecore programmatically [message #1015322 is a reply to message #1015313] Thu, 28 February 2013 08:44 Go to previous messageGo to next message
This information is all availabvle on the OCL project page:
http://projects.eclipse.org/projects/modeling.mdt.ocl
and in the Wiki.
The serialization tests are in the exaamples tests plugin.
Please use a little initiative.
Ed Willink
> thanks for help!
> Cheers,
Re: Generating .oclinecore file from Ecore programmatically [message #1015350 is a reply to message #1015322] Thu, 28 February 2013 10:08 Go to previous message
thanks!
Previous Topic:OCLinEcore editor hungry? (eats characters)
Next Topic:Using drag'n'drop results in exception when loading CompleteOCL resource
Current Time: Tue May 22 21:36:08 GMT 2018
Powered by FUDForum. Page generated in 0.01690 seconds
