Home » Eclipse Projects » Subversive » JavaHL on 64bit Windows(JavaHL on 64bit Windows)
JavaHL on 64bit Windows [message #1015084] Wed, 27 February 2013 11:51 Go to next message
Ian Ashley is currently offline Ian AshleyFriend
I am having trouble getting JavaHL to work with Subversive on 64bit Windows.
I am trying to use it with SlikSVN. I installed this in C:/SlikSVN.
The steps I followed were;
• install SlikSVN
• Install Eclipse Juno SR1
• Added the following to Eclipse.ini
•• -Dsubversion.native.library=C:/SlikSVN/bin/libsvnjavahl-1.dll
• Started Eclipse
• Added the Subversive plug-ins from the Eclipse MarketPlace
• Restarted Eclipse
• The SVN Connector Discovery dialog is shown. I repeated the above twice each time trying a different answer in the dialog. I tried
•• Selecting the SvnKit connector
•• Selecting no connector
• In both cases the JavaHl connector was not offered in SVN preferences panel
Can anyone provide a sequence that allows this to work.
[Updated on: Thu, 28 February 2013 09:34]
Report message to a moderator
Re: JavaHL on 64bit Windows [message #1015827 is a reply to message #1015084] Sun, 03 March 2013 10:59 Go to previous messageGo to next message
Alexander Gurov is currently offline Alexander GurovFriend
1) In order to use native connector you should install not SVN Kit-based, but JavaHL-based one.
2) You need to be sure that you've installed the connector which corresponds to the installed binaries, i.e. JavaHL 1.7 based one for 1.7.x binaries or JavaHL 1.6 based one for 1.6.x binaries
3) Make sure to add "C:/SlikSVN/bin" to the PATH environment variable (please note, that Windows won't see all the related libraries that is placed here otherwise).
Re: JavaHL on 64bit Windows [message #1015942 is a reply to message #1015827] Mon, 04 March 2013 11:03 Go to previous messageGo to next message
Thanks for the answer however the only native JavaHL connectors are for 32 bit Windows. If I select the JavaHL 1.7 connector it fails to install because the platform is 64 bit.
Re: JavaHL on 64bit Windows [message #1069565 is a reply to message #1015942] Tue, 16 July 2013 06:17 Go to previous messageGo to next message
Sheae hiae is currently offline Sheae hiaeFriend
Can any good idea are offered to deal with this trouble when thi platform is 64 bit? it troubles me now...
Re: JavaHL on 64bit Windows [message #1130468 is a reply to message #1069565] Wed, 09 October 2013 15:41 Go to previous messageGo to next message
Keith Lehman is currently offline Keith LehmanFriend
Hi:
I'm having the same trouble. Were you able to resolve this?
- Keith
Re: JavaHL on 64bit Windows [message #1130578 is a reply to message #1130468] Wed, 09 October 2013 18:25 Go to previous messageGo to next message
So, I installed Silk, and updated my PATH variable. Now, I at least get the connector discovery to run for new (empty) workspaces. It doesn't find any connectors though. Does anyone know the URL(s) that the connector discovery feature searches?
Re: JavaHL on 64bit Windows [message #1130722 is a reply to message #1130578] Wed, 09 October 2013 21:50 Go to previous messageGo to next message
After installing Silk, I've been able to run svn from the command line. Nothing shows up in Eclipse though. Please let me know if you have any suggestions.
Thanks!
Re: JavaHL on 64bit Windows [message #1130986 is a reply to message #1130722] Thu, 10 October 2013 04:41 Go to previous messageGo to next message
the discovery feature searches this URL for connectors: http://community.polarion.com/projects/subversive/download/eclipse/3.0/update-site/
Also for JavaHL64 bit to work you at least need to install org.polarion.eclipse.team.svn.connector.javahl18 or org.polarion.eclipse.team.svn.connector.javahl17 connectors, depending on the binaries version you're using.
Re: JavaHL on 64bit Windows [message #1131606 is a reply to message #1130986] Thu, 10 October 2013 17:22 Go to previous messageGo to next message
Thanks Alex. That did the trick.
Re: JavaHL on 64bit Windows [message #1749230 is a reply to message #1131606] Sat, 03 December 2016 18:30 Go to previous messageGo to next message
lohitha donepudi is currently offline lohitha donepudiFriend
Hi I am also facing trouble installing svn connectors in eclipse neon and its previous versions in my win-32 bit system.
"No internet connection .please check your connection and try again " is the error i am facing while installing it through manually.
Please guide me a solution.
Re: JavaHL on 64bit Windows [message #1750839 is a reply to message #1749230] Thu, 29 December 2016 19:41 Go to previous message
Hi!
It seems there is some network problems in your case. If you can access Internet at all then please try to download an archived connectors update site corresponding to your Subversive plug-in version from this page:
https://polarion.plm.automation.siemens.com/products/svn/subversive/download
and use it to install connectors.
Previous Topic:Could not acquire the framework manipulator service
Next Topic:Merge menu item in Team sync view?
Current Time: Sun May 27 03:44:50 GMT 2018
Powered by FUDForum. Page generated in 0.02279 seconds
