Home » Eclipse Projects » BIRT » Language of Report Labels(Changing the language of report labels dynamically)
Language of Report Labels [message #1014119] Mon, 25 February 2013 07:45 Go to next message
Sabin V Abraham is currently offline Sabin V AbrahamFriend
Hi All,
I am working in Maximo 7.5 and I am using Birt 2.3.2. I need to develop a report where the report labels should be displayed in the default language of the user currently logged in.
I tried localization option in the eclipse by doing the following steps.
1. Selected the properties file from the localization option
2. Selected the 2 jar files which were available
3. Then I deployed the report and generated the request page.
But I got an error saying the jar files are not available. Is there any other way where the user running the report will see the labels in his own language.
(As of now, i am using a different dataset to select the translated values from the database based on the user language. But it will affect the system in performance wise)
Re: Language of Report Labels [message #1014937 is a reply to message #1014119] Tue, 26 February 2013 21:22 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Have you seen this example about localization?
BIRT Exchange DevShare - Localization Example
Developer Evangelist, Silanis
Previous Topic:cross tab - days of month
Next Topic:Birt Chart Engine Api - set y-axis labels
Current Time: Sat Mar 17 11:02:51 GMT 2018
Powered by FUDForum. Page generated in 0.01599 seconds
