Home » Modeling » TMF (Xtext) » Multiple input files problem
Multiple input files problem [message #1012818] Fri, 22 February 2013 09:24 Go to next message
n d is currently offline n dFriend
Hi all,
I am exporting my xtext project to the command-line/standalone mode. This is achieved without a problem
but now I need to modify it in order to accept multiple files (in order to resolve cross-references
between files). To do this, I have implemented a version of the suggestion in
http://www.eclipse.org/forums/index.php/m/761659/?srch=standalone+multiple+files#msg_761659
in which the model of the secondary files are added for the Resource of the main file.
ResourceSet set = resourceSetProvider.get();
Resource compositeResource = set.getResource(URI.createURI(mainfilename),true);
for (String otherfilename : getOtherSourceFiles()) {
	Resource modelFromFile = set.getResource(URI.createURI(otherfilename ), true);
	compositeResource.getContents().addAll(modelFromFile.getContents());
List<Issue> list = validator.validate(compositeResource, CheckMode.ALL, CancelIndicator.NullImpl);
The problem is, although the validation works, I cannot get ride of this exception:
0    ERROR LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.0.0.1.0::0::/3' failed.
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
        at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:346)
        at org.eclipse.xtext.linking.lazy.LazyURIEncoder.resolveShortFragment(LazyURIEncoder.java:109)
        at org.eclipse.xtext.linking.lazy.LazyURIEncoder.decode(LazyURIEncoder.java:89)
        at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:166)
        at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
        at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:197)
        at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:257)
        at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1473)
        at org.xtext.example.mydsl1.myDsl1.impl.TestName2Impl.getName(TestName2Impl.java:73)
        at org.xtext.example.mydsl1.myDsl1.impl.TestName2Impl.eGet(TestName2Impl.java:117)
        at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
        at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
        at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:403)
        at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryReferenceIsContained(EObjectValidator.java:782)
        at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDefaultConstraint(EObjectValidator.java:355)
        at org.eclipse.emf.ecore.util.EObjectValidator$DynamicEClassValidator.validate(EObjectValidator.java:1420)
        at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObjectValidator.java:333)
        at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:126)
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:159)
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
        at org.eclipse.xtext.validation.CancelableDiagnostician.validate(CancelableDiagnostician.java:36)
        at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:178)
        at org.eclipse.xtext.validation.CancelableDiagnostician.doValidateContents(CancelableDiagnostician.java:48)
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:162)
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:120)
        at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:108)
        at org.xtext.example.mydsl1.generator.Main.runGenerator(Main.java:80)
        at org.xtext.example.mydsl1.generator.Main.main(Main.java:39)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Does anybody encoutered this and have any suggestion to share?
Thanks a lot,
Nuno
Re: Multiple input files problem [message #1012833 is a reply to message #1012818] Fri, 22 February 2013 09:56 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
why do you do the compositeResource.getContents().addAll(modelFromFile.getContents()); at all?
"the model" is the set off all resources aka resourceset.
if you add all required resources to the resourceset you wont get errors like that.
you may call compositeResource.getContents().addAll(modelFromFile.getContents());
to resolve all lazy cross refs after you added all resources to the resourceset
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: Multiple input files problem [message #1012844 is a reply to message #1012833] Fri, 22 February 2013 10:20 Go to previous message
You are completely right.
By validating the resources one by one, I don't need to call compositeResource.getContents().addAll(modelFromFile.getContents()).
All the cross references are resolved.
Thanks for the swift help,
Nuno
Previous Topic:Rename of created EObject for implicit declaration
Next Topic:error when generating my language
Current Time: Fri Apr 20 18:05:52 GMT 2018
Powered by FUDForum. Page generated in 0.02027 seconds
