Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1008982 is a reply to message #1008735] |
Thu, 14 February 2013 08:48 |
Referring to the excerpt "A library with the name 'org.springframework.spring' and a version within the range '[3.0.0, 3.1.0)' could not be found" it is obvious that range excludes version 3.1.0. However this is precisely the Spring version delivered with Virgo 3.6.0. Increase the version range maximum in Greenpages.
You can find detailed instruction in STEP 12 at Wordpress site "Greenpagesvirgo.wordpress.com".
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1009170 is a reply to message #1008982] |
Thu, 14 February 2013 15:25 |
Brent Jacox Messages: 5 Registered: February 2013 |
Junior Member |
Thanks for the information it seems to get me past my original problem. Now I am faced with:
[2013-02-14 08:19:37.145] fs-watcher <DE0003E> Install failed for par 'greenpages' version '2.5.0.RELEASE'.
[2013-02-14 08:19:37.148] fs-watcher <DE0500E> Unable to install application from URI 'file:/C:/VIRGO-~1.REL/picku
p/greenpages-2.5.0.RELEASE.par'. Cannot satisfy constraints for bundle 'greenpages-2.5.0.RELEASE-greenpages.jpa' version '2.5.0'. Ca
nnot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
Resolver report:
An Import-Package could not be resolved. Resolver error data <Import-Package: org.eclipse.persistence.tools.schemaframework;
version="0.0.0">. Caused by missing constraint in bundle <greenpages-2.5.0.RELEASE-greenpages.jpa_2.5.0>
constraint: <Import-Package: org.eclipse.persistence.tools.schemaframework; version="0.0.0"> constrained to bundle <com
.springsource.org.eclipse.persistence> constrained bundle version range "[1.0.0,1.0.0]"
An Import-Package could not be resolved. Resolver error data <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">. C
aused by missing constraint in bundle <com.springsource.org.eclipse.persistence_1.0.0>
constraint: <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">
. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'gree
npages-2.5.0.RELEASE-greenpages.jpa' at version '2.5.0': Cannot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
Resolver report:
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDep
loyer.java:359)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:
185)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:14
0)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:253
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:225)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeployerFileSystemListener.jav
a:237)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:88)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:373)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:282)
at org.eclipse.virgo.nano.deployer.hot.WatchTask.run(WatchTask.java:48)
at java.lang.Thread.run(Thread.java:722)
[2013-02-14 08:19:37.176] fs-watcher <HD0002E> Hot deploy failed for file 'greenpages-2.5.0.RELEASE.par'. org.ecli
pse.virgo.nano.deployer.api.core.DeploymentException: Dependency satisfaction failed
loyer.java:362)
185)
0)
a:237)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bun
dle 'greenpages-2.5.0.RELEASE-greenpages.jpa' at version '2.5.0': Cannot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
Resolver report:
loyer.java:359)
... 10 common frames omitted
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1009326 is a reply to message #1008735] |
Thu, 14 February 2013 22:42 |
Referring to excerpt "constraint: <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">" reveals incompatibility with the Virgo's version of EclipseLink. Virgo 3.6.0 has been delivered with bundle javax.persistence-2.0.4.v201112161009.jar. Furthermore this bundle is compatible with other EclipseLink bundles of version 2.4.0. Upgrade Greenpages EclipseLink jars to the same level i.e. 2.4.0.
You can find more detailed instructions in STEP 6 and STEP 11 of my Wordpress blog "greenpagesvirgo.wordpress.com".
FUDForum. Page generated in 0.02963 seconds
