Home » Newcomers » Newcomers » Error in starting eclipse
Error in starting eclipse [message #1008660] Wed, 13 February 2013 13:27 Go to next message
Chaitanya R is currently offline Chaitanya RFriend
I was using eclipse with Java 1.7 but today I have uninstalled JRE1.7 and installed JRE1.6 in my machine to solve some issue. After that when I am starting eclipse I am getting below error in alert box:
Java Virtual Machine Launcher
Error: Registry key 'Software\JavaSoft\Java Runtime Environment'\CurrentVersion' has value '1.6', but '1.7' is required.
Could not find java.dll
Please help how to solve this issue, Thanks in advance.
Re: Error in starting eclipse [message #1008908 is a reply to message #1008660] Thu, 14 February 2013 05:24 Go to previous messageGo to next message
You can tell eclipse which JRE to use in the eclipse.ini. If you've
installed bundles that require 1.7 in your IDE you will need a 1.7 JRE
to run the IDE itself.
Re: Error in starting eclipse [message #1008931 is a reply to message #1008660] Thu, 14 February 2013 07:03 Go to previous message
Thanks a lot Ed Merks.
I have added below lines to my eclipse.ini file and it started working fine now.
-vm
C:\Java\jdk1.6.0_35\bin\javaw.exe
Previous Topic:Marketplace feature Cannot satisfy dependency:
Next Topic:Error in Ecipse installation on UBUNTU 12.04 WITH 64 BIT M/C
Current Time: Sun May 20 18:02:39 GMT 2018
Powered by FUDForum. Page generated in 0.02693 seconds
