| generating code for Keil compiler [message #1008588] |
Wed, 13 February 2013 03:31  |
Stefan St Messages: 5 Registered: February 2013 |
Junior Member |
I'm pretty new to eTrice and I just want to find out, if eTrice code-generation would fit in our developement process which uses the Keil toolchain.
Now I've tried the HelloWorld example from eTrice documentation homepage. I set up a Keil project to compile the generated code, so far. Unfortunately, Keil seems to have its own rules, that declaration should be at the beginning of a block, while eTrice generation just puts it, where it first appears. So, when compiling, I get a message:
error: #268: declaration may not appear after executable statement in block
Is there a possibility, to make the generator put declarations at the beginning of a block?
thx,
Stefan
| Re: generating code for Keil compiler [message #1008648 is a reply to message #1008588] |
Wed, 13 February 2013 07:15  |
Henrik Rentz-Reichert Messages: 204 Registered: July 2009 |
Hi Stefan,
we have been aware of this problem.
A strictly ANSI-C compliant compiler requires that variable declarations only occur at the beginning of a block.
But it shouldn't be much work to get that fixed.
Could you please file a bug for this?
Henrik
Am 13.02.2013 12:27, schrieb Stefan St:
> Hello,
> the Keil toolchain.
> thx,
> Stefan :?
FUDForum. Page generated in 0.01546 seconds
