Home » Modeling » Graphiti » Problem with rendering of elements(After editing the text in element, the element pictogram looks destroyed.)
Problem with rendering of elements [message #1008479] Tue, 12 February 2013 11:36 Go to next message
S. C. is currently offline S. C.
I use Spray to generate Graphiti Editor. The problem I stucked now with is the look of an Element after it's editing. The lines covered by the Text Editing Box looking purged away.
Where could I change the size of the Text Editing Box or do something different (e.g. change element update mechanism)? Is smth. with GraphicsAlgorithm in DirectEditingFeature wrong?
Re: Problem with rendering of elements [message #1008528 is a reply to message #1008479] Tue, 12 February 2013 16:12 Go to previous message
Michael Wenz is currently offline Michael Wenz
Not sure what Spray exactly does here, but from Graphiti point of view this
looks as if the inner Text graphics algorithm is a little too large and
covers part of the outer rectangle after the direct editing.
Can you check what exactly the direct editing feature and the associated
layout and update features do? There might be an issue with the size change
they do.
Michael
Previous Topic:text.setForeground(...) don't work as expected
Next Topic:Newbie Question
Current Time: Tue May 21 17:56:13 EDT 2013
Powered by FUDForum. Page generated in 0.01514 seconds
