Home » Eclipse Projects » BIRT » [HOW] : Dynamically changing Label value(Label value should be changed dynamically through java code)
icon4.gif  [HOW] : Dynamically changing Label value [message #1007957] Fri, 08 February 2013 13:43 Go to next message
praneeth botta is currently offline praneeth bottaFriend
I need to dynamically change the Label value.
For example Label with name: X, has value= "Total Invoice"
How can i dynamically modify this to another value from java code ???
[Updated on: Fri, 08 February 2013 13:45]
Report message to a moderator
Re: [HOW] : Dynamically changing Label value [message #1008033 is a reply to message #1007957] Fri, 08 February 2013 15:40 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
From java or javascript within the report? Also, is this any label? Or just specific labels?
Michael
Developer Evangelist, Silanis
Re: [HOW] : Dynamically changing Label value [message #1008048 is a reply to message #1008033] Fri, 08 February 2013 16:11 Go to previous messageGo to next message
Michael Williams wrote on Fri, 08 February 2013 10:40
1)From Java
2)Any label - I will give each label unique name that i know
Re: [HOW] : Dynamically changing Label value [message #1008074 is a reply to message #1008048] Fri, 08 February 2013 18:24 Go to previous messageGo to next message
From your report design handle, you should be able to do something like:
designHandle.findElement("myLabel").setText("myValue");
Michael
Re: [HOW] : Dynamically changing Label value [message #1705602 is a reply to message #1008074] Mon, 17 August 2015 17:32 Go to previous messageGo to next message
Mario Flores is currently offline Mario FloresFriend
Hello, I understand this is an old topic but I wanted to know if this way of editing the labels has changed. I am currently trying to do the same thing as OP but I am unable to do so in Birt runtime 4.5.0 (the latest build).
I would really appreciate a lead or solution. Embarrassed
Thanks!
icon14.gif  Re: [HOW] : Dynamically changing Label value [message #1705624 is a reply to message #1705602] Mon, 17 August 2015 22:09 Go to previous message
I figured out my own problem Rolling Eyes
From the book Integrating and Extending BIRT page 296:
//Access the label by name.
LabelHandle headerLabel = (LabelHandle) design.findElement("Header Label");
try {
headerLabel.setText("Updated " + headerLabel.getText());
} catch (Exception e) {
// Handle the exception
design being a ReportDesignHandle object.
Previous Topic:Indigo API Online Documentation no longer available
Next Topic:Birt reports cause temporary files to be generated in /Tmp folder
Current Time: Sat May 26 16:07:24 GMT 2018
Powered by FUDForum. Page generated in 0.02096 seconds
