Home » Language IDEs » C / C++ IDE (CDT) » eclipse creates exe for C++ not for C project
icon5.gif  eclipse creates exe for C++ not for C project [message #1007891] Fri, 08 February 2013 00:51
Missing name Mising name is currently offline Missing name Mising nameFriend
I just installed juno eclipse and Mingw and created a C++ project. That worked fine and ran like it should. But when I tried to create a C project, eclipse looks like it works, but looking in the directory, there is no executable. I was wondering if anyone else has had this problem and knows how to fix it.
Oh, one other thing I noticed is that the C++ project creates a Binaries folder under its project root while there is no such folder in the C project root.
(I have attached an image of the project explorer).
The code is the standard hello world template for both projects.
Sad
C++:
16:31:02 **** Rebuild of configuration Debug for project Test ****
Info: Internal Builder is used for build
g++ -O0 -g3 -Wall -c -fmessage-length=0 -o "src\\Test.o" "..\\src\\Test.cpp"
g++ -o Test.exe "src\\Test.o"
16:31:03 Build Finished (took 890ms)
C:
16:32:08 **** Rebuild of configuration Debug for project Test2 ****
gcc -O0 -g3 -Wall -c -fmessage-length=0 -o "src\\Test2.o" "..\\src\\Test2.c"
gcc -o Test2.exe "src\\Test2.o"
16:32:09 Build Finished (took 1s.119ms)
Oh, I discovered another thing. If I create a C++ project hello world it will compile fine, but if I then replace the C++ code with straight C code as in:
#include <iostream>
using namespace std;
int main() {
	cout << "!!!Hello World!!!" << endl; // prints !!!Hello World!!!
	return 0;
with
#include <stdio.h>
#include <stdlib.h>
int main(void) {
	puts("!!!Hello World!!!"); /* prints !!!Hello World!!! */
	return EXIT_SUCCESS;
So, I have a Test3.cpp file with C code and it does not compile to an executable either.
[Updated on: Fri, 08 February 2013 01:12]
Report message to a moderator
Previous Topic:No error when class not #included?
Next Topic:How do I create an OS-neutral run configuration in Eclipse?
Current Time: Fri Jun 22 15:41:16 GMT 2018
Powered by FUDForum. Page generated in 0.02181 seconds
