Home » Newcomers » Newcomers » Trouble with Emulator
Trouble with Emulator [message #1007193] Mon, 04 February 2013 21:32 Go to next message
Sycrid Zilla is currently offline Sycrid ZillaFriend
As the title says, I'm having trouble with the emulator. I can run it without any problems, and I've tried multiple builds, but when I load in portrait mode, the "hardphone" aspect loads fine, but the software aspect loads in landscape.
I can switch between the landscape and portrait modes using the F keys, but this does not solve the problem. Landscape mode works fine, but portrait has issues, has anyone else experienced this?
Is there a fix? Pictures below.
dynamicexposure.com/images/screen.jpg
  • Attachment: screen.jpg
    (Size: 141.13KB, Downloaded 90 times)
Re: Trouble with Emulator [message #1007327 is a reply to message #1007193] Tue, 05 February 2013 14:43 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
Please ask Google your Android related questions. This has nothing to do with Eclipse.
Re: Trouble with Emulator [message #1007866 is a reply to message #1007193] Thu, 07 February 2013 20:10 Go to previous messageGo to next message
Sorry mate, I thought it was eclipse based.
Can you point me in the right direction, considering my first port of call was google. I was unable to locate a solution, nor a similar situation, which is why I ended up here.
Re: Trouble with Emulator [message #1007984 is a reply to message #1007866] Thu, 07 February 2013 21:01 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
Sycrid,
It pays to check out the sticky posts at the top of the forum. It would
have saved you some time. Here's the relevant one:
http://www.eclipse.org/forums/index.php/t/225513/
Best of luck.
Previous Topic:Need SDO Generator for Eclipse
Next Topic:PyDev (on Aptana (on Eclipse 3.7)) - install extension via marketplace
Current Time: Mon Feb 26 04:00:33 GMT 2018
Powered by FUDForum. Page generated in 0.03029 seconds
