Home » Eclipse Projects » BIRT » multiples values from parameter(Not able to used multiples value from single parameter)
multiples values from parameter [message #1006134] Wed, 30 January 2013 07:15 Go to next message
jinesh vora is currently offline jinesh voraFriend
I am using Birt for creating a reports.
in that i am facing one issue , the issue is that when i try to used one parameter with multiples values than it consider the only first value.
so it will be very helpful for me if any one told me the solution.
Thanks in advanced.
Re: multiples values from parameter [message #1006254 is a reply to message #1006134] Wed, 30 January 2013 15:27 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Can you give some more detail on how you are using the multi-value parameter? If you add a text box you can iterate over the set values. Take a look at the attached example.
Jason
Re: multiples values from parameter [message #1006255 is a reply to message #1006134] Wed, 30 January 2013 15:28 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Have you seen this devShare example from BIRT Exchange:
BIRT Exchange DevShare - Using Multi-Value Parameters
Michael
Developer Evangelist, Silanis
Previous Topic:Cannot start OSGI framework
Next Topic:How to add a metadata to a field ?
Current Time: Sat Feb 24 10:43:36 GMT 2018
Powered by FUDForum. Page generated in 0.01635 seconds
