Home » Modeling » TMF (Xtext) » Retrieve info from EMF model in UI action and then use it to modify the model itself
Retrieve info from EMF model in UI action and then use it to modify the model itself [message #1006055] Tue, 29 January 2013 16:13 Go to next message
Marco Naddeo is currently offline Marco NaddeoFriend
Member
Hi. Smile
In an UI action in my DSL editor, I want to retrieve some information from the EMF model and then use it later to modify the model itself.
My code is something like this:
public class MyHandler extends AbstractHandler implements IHandler {
  public Object execute(ExecutionEvent event) throws ExecutionException {
    final XtextEditor xtextEditor = (XtextEditor) HandlerUtil.getActiveEditor(event);
    final String info = xtextEditor.getDocument().readOnly(new IUnitOfWork<String,XtextResource>() {
      public String exec(XtextResource state) throws Exception {
        TreeIterator<EObject> iter = state.getAllContents();
        String res = "";
        while (iter.hasNext()) {
	  EObject obj = iter.next();
	  if (...) {
            res = obj.getMyFeature();
        return res;
    //do some work here...
    //and then:
    xtextEditor.getDocument().modify(new IUnitOfWork.Void<XtextResource>() {
      public void process(XtextResource state) throws Exception {
	  if (...) {
            obj.setMyFeature(info);
The setting of the model element feature with the previous retrieved string *seems* to work, but to the next call of the UI action, the feature turns out to be actually set to null! Shocked
Do you have any idea of why? Confused
Note that I'm forced to declare the info string variable as final because the compiler says that I cannot refer to a non-final variable inside an inner class defined in a different method. Is it possible that this affects the result?
Thanks in advance,
Marco Rolling Eyes
Re: Retrieve info from EMF model in UI action and then use it to modify the model itself [message #1006322 is a reply to message #1006055] Wed, 30 January 2013 20:16 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
HI,
i cannot reproduce this. (the final problem would be avoided using the holder pattern anyway)
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
[Updated on: Wed, 30 January 2013 20:16]
Report message to a moderator
Previous Topic:References from other file not working
Next Topic:IIncompatible implicit return type on short or byte with numeric constants
Current Time: Fri Jan 19 19:56:22 GMT 2018
Powered by FUDForum. Page generated in 0.01819 seconds
