Home » Modeling » M2T (model-to-text transformation) » org.eclipse.emf.mwe.utils.Reader is not reading stereotype(Reading .emx file of RSM)
org.eclipse.emf.mwe.utils.Reader is not reading stereotype [message #1005992] Tue, 29 January 2013 13:50 Go to next message
Prodipta Mondal is currently offline Prodipta MondalFriend
Hi ,
I am trying to read .emx file using normal mwe workflow.I am not able to figure out why it's getting the stereoTyped elements of the model.Please find the complete workflow below.I am also attaching the model and profile which I am trying to generate.
<?xml version="1.0"?>
<workflow>
<!--Store Global Vars-->
<component class="com.accn.oaw.component.common.StoreGlobalVars" skipOnErrors="true">
<globalVarDef name="target_workspace" value="${target_workspace}"/>
<globalVarDef name="project_name" value="${project_name}"/>
<globalVarDef name="package_prefix" value="${package_prefix}"/>
</component>
<component class="com.accn.oaw.component.common.RSASetup">
<extensionMap from="efx" to="org.eclipse.uml2.uml.resource.UMLResource" />
<init value="true" />
</component>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<registerGeneratedEPackage value="org.eclipse.gmf.runtime.notation.NotationPackage"/>
<registerGeneratedEPackage value="com.ibm.xtools.umlnotation.UmlnotationPackage"/>
<platformUri value="${model_workspace}"/>
</bean>
<component id="read" class="org.eclipse.emf.mwe.utils.Reader">
<uri value="${inputmodel.file}"/>
<modelSlot value="model"/>
</component>
<bean class="org.eclipse.xtend.typesystem.emf.EmfMetaModel" id="metaModelId">
<metaModelFile value="com/accn/ecoremetamodel/common/MetaModel.ecore"/>
</bean>
<!-- transform model -->
<component class="org.eclipse.xtend.XtendComponent">
<metaModel class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
<profile value="com/accn/ecoremetamodel/common/Profile.profile.uml"/>
</metaModel>
<invoke value="com::accn::oaw::m2m::common::Transform::transformModel(model)"/>
<outputSlot value="transformedModel"/>
</component>
<!-- Generate Code -->
<component class="org.eclipse.xpand2.Generator">
<metaModel idRef="metaModelId"/>
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<expand value="com::accn::expand::atomicservices::TemplateACS::root FOR transformedModel"/>
<outlet path="${target_workspace}"/>
<beautifier class="org.eclipse.xpand2.output.JavaBeautifier" configFile="CodeFormatter.xml"/>
</component>
</workflow>
Any suggestion would be appreciated.Thanks in advance.
Re: org.eclipse.emf.mwe.utils.Reader is not reading stereotype [message #1006610 is a reply to message #1005992] Fri, 01 February 2013 07:22 Go to previous message
I am still facing this issue.Is there any suggestion for fix ?
Previous Topic:XSD 2 Ecore with Xpand
Next Topic:parameter of the main template is a proxy
Current Time: Fri Feb 23 11:09:32 GMT 2018
Powered by FUDForum. Page generated in 0.02093 seconds
