Re: Plugins won't update [message #1006009 is a reply to message #1005911] |
Tue, 29 January 2013 14:31   |
Doing a upgrade from hudson 2.2.1 to hudson 3 will not install the latest version of the plugin. We do not force an install of the latest plugin because some older plugins still work with with hudson 3. We leave the upgrading choice up to the user on whether to upgrade or not.
* @author Steven Christou
* @dev Hudson-ci
Re: Plugins won't update [message #1006277 is a reply to message #1006138] |
Wed, 30 January 2013 16:33   |
Winston Prakash Messages: 534 Registered: August 2011 Location: Fremont, CA USA |
Your understanding is not quite right
- Bundled plugins can not be updated via update center until you create a dummy file called plugin.hpi.pinned. Once pinned, that plugin can be updated only to new versions in the update center.
- However, when you get a new version of bundled war and it has bundled new version of the plugin, then Hudson will not automatically update to that new version, until you unpin the plugin.
Basically, you get new versions from update center by pinning the plugin or get new versions from next version of bundled war by unpinning the plugin.
Yes, you can switch to the standard version, just by switching the war. This will bring up a one time initial setup screen which helps to update any plugin that needs update.
Winston Prakash
Eclipse Hudson team
[Updated on: Wed, 30 January 2013 16:45] Report message to a moderator
Re: Plugins won't update [message #1006280 is a reply to message #1005911] |
Wed, 30 January 2013 16:46  |
Winston Prakash
Eclipse Hudson team
FUDForum. Page generated in 0.02581 seconds
