Home » Newcomers » Newcomers » Eclipse .project problem(the .project file is broken after shutting down eclipse)
Eclipse .project problem [message #1004137] Tue, 22 January 2013 11:34
Grzegorz Patynek is currently offline Grzegorz Patynek
I open eclipse, start new android project from existing sources.
Then i shutdown eclipse and i have .project file only 8 bytes long.
When i start eclipse again, i get the error message:
Failed to read the project description file (.project) for 'AndEngine'.  The file has been changed on disk, and it now contains invalid information.  The project will not function properly until the description file is restored to a valid state.
I use Linux Mint.
The project has checked "is library".
The project was copied from windows filesystem and created from existing sources.
Previous Topic:Problem in passing query string parameters from HTML to BIRT
Next Topic:Jetty webServer
Current Time: Sat May 18 23:43:20 EDT 2013
Powered by FUDForum. Page generated in 0.01439 seconds
