Home » Modeling » Epsilon » EGL - TemplateFactory.setRoot(Method 'setRoot' not found for: TemplateFactory)
EGL - TemplateFactory.setRoot [message #1003915] Tue, 22 January 2013 08:21 Go to next message
Juan Quirós is currently offline Juan QuirósFriend
Hi! I am new on epsilon, so I am developing a simple template to get confidence on it. I am using the default TemplateFactory object. When I try to execute TemplateFactory.setRoot("/new/root"), eclipse returns an error. Does TemplateFactory have this method? According to the EpsilonBook it does, indeed, it is used in listing 7.8.
Input
TemplateFactory.setTemplateRoot("/tmp");
TemplateFactory.setRoot("/tmp");
Running
I have configured a running execution.
Error
Method 'setRoot' not found for: TemplateFactory: root='file:/tmp/' (/home/jquiros/data/proyectos/dte/crimsonCell/code_local/mde/org.us.mca.almond.eglProject/egl/ps.almond.egl@3:20)
Cause: Method 'setRoot' not found for: TemplateFactory: root='file:/tmp/' (/home/jquiros/data/proyectos/dte/crimsonCell/code_local/mde/org.us.mca.almond.eglProject/egl/ps.almond.egl@3:20)
Thanks in advance!
Re: EGL - TemplateFactory.setRoot [message #1004216 is a reply to message #1003915] Tue, 22 January 2013 20:21 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Hi Juan,
Thanks for reporting this. This appears to be an error in the book (fixed now). The correct method is setOutputRoot(String path).
Dimitris
Re: EGL - TemplateFactory.setRoot [message #1007306 is a reply to message #1004216] Tue, 05 February 2013 13:28 Go to previous message
Thanks!
Previous Topic:EmFatic
Next Topic:How to generate preserved regions from EGL @template operation
Current Time: Sun May 27 03:46:50 GMT 2018
Powered by FUDForum. Page generated in 0.01988 seconds
