Home » Language IDEs » C / C++ IDE (CDT) » Binary not found error(Binary not found error)
Binary not found error [message #1003642] Mon, 21 January 2013 17:13 Go to next message
Rechee Jozil is currently offline Rechee JozilFriend
Hello peeps. I'm trying to set up CDT, but I'm getting a binary not found error. I just can't figure it out. Here's what I did:
Installed cygwin
Added it to path
Installed CDT
Help would be much appreciated.
Re: Binary not found error [message #1003722 is a reply to message #1003642] Mon, 21 January 2013 21:56 Go to previous messageGo to next message
Jack FerrisFriend
This worked for me.
"Did you build test.cpp within Eclipse? On the screen shot I miss some generated folders:
Press CTRL+B (or however this key is called on a Mac). After a successfully build you should see a folder "Debug" or "Release" in the Project Explorer view and a virtual Folder Binaries. Now right click on one of the binaries and select Run as > Local C/C++ Application.
Klaus"
Re: Binary not found error [message #1003808 is a reply to message #1003722] Tue, 22 January 2013 02:59 Go to previous messageGo to next message
Tried that already.
Re: Binary not found error [message #1003829 is a reply to message #1003642] Tue, 22 January 2013 04:31 Go to previous message
Wow. I feel so stupid. I found the reason. It's so embarrassing I won't even say any thing but thanks.
Previous Topic:filter in C/C++ executable level for Ran As Launch Config;
Next Topic:Deleted text re-inserted
Current Time: Mon Jun 18 13:55:06 GMT 2018
Powered by FUDForum. Page generated in 0.01805 seconds
