Home » Eclipse Projects » Eclipse Platform » Minimum supported Java version for Indigo / Eclipse 3.7
Minimum supported Java version for Indigo / Eclipse 3.7 [message #1003569] Mon, 21 January 2013 14:30 Go to next message
Sascha Vogt is currently offline Sascha VogtFriend
Hi all,
I was trying to find the minimum supported Java version for Indigo / 3.7
Is there any page documenting that?
Greetings
-Sascha-
Re: Minimum supported Java version for Indigo / Eclipse 3.7 [message #1003575 is a reply to message #1003569] Mon, 21 January 2013 14:40 Go to previous messageGo to next message
Sacha,
Each bundle has its own constraints for what it needs to run. Many
Eclipse platform bundles will run with Java 1.4, but I'm pretty sure
some need Java 5.0. I'm also pretty sure that none need Java 6.0; I
don't think the class file formats have changed. Don't mix that up with
which JDKs you can develop against in the IDE. There is no minimum for
that.
On 21/01/2013 3:30 PM, Sascha Vogt wrote:
> Hi all,
> Greetings
> -Sascha-
Re: Minimum supported Java version for Indigo / Eclipse 3.7 [message #1003594 is a reply to message #1003575] Mon, 21 January 2013 15:22 Go to previous message
Hi Ed,
thanks for the quick response. Yes, I was talking about the runtime dependency. I thought there was some sort of minimum required version (the project plan for Kepler contains one: http://www.eclipse.org/projects/project-plan.php?projectid=eclipse#target_environments - and there it is Java6) and every bundle participating in the release train is checked against that target environment.
Anyway, as my main concerns were regarding XText and EMF I think I can trust your intuition that it's all Java5 compatible Wink
Greetings
-Sascha-
Previous Topic:IDocumentProvider.getAnnotationModel is null
Next Topic:AbstractLaunchConfigurationTab - Messages
Current Time: Thu Apr 26 21:23:00 GMT 2018
Powered by FUDForum. Page generated in 0.01503 seconds
