Home » Eclipse Projects » Rich Client Platform (RCP) » embed audio player
embed audio player [message #1003289] Sun, 20 January 2013 22:00 Go to next message
Johnny Qin is currently offline Johnny QinFriend
Member
hi all,
I have been working on a RCP project for a while. Recently I am trying to embed an audio player so the users can play .wav files within the RCP application (without depending on whatever various audio players on their own local environment). Ideally it should be some sort of special editor that can be binded with .wav suffix and can be launched through the similar way that an editor is launched.
Didn't find useful example or discussion after looking around. Does anyone have similar experience or consideration?
Thanks in advance!
Re: embed audio player [message #1005027 is a reply to message #1003289] Thu, 24 January 2013 10:47 Go to previous messageGo to next message
Sumit Singh is currently offline Sumit SinghFriend
Hi Johnny ,
may be its better if you ask what problem you are facing to implement that.
Re: embed audio player [message #1005159 is a reply to message #1005027] Thu, 24 January 2013 15:14 Go to previous messageGo to next message
Member
Thanks Sumit.
The use case is:
1. user imports an audio file (.wav) to my RCP application
2. user clicks on it and try to play this audio file. At this point, the audio file by default is opened by whatever audio player user has installed. This is not what I want. What I am looking for is a way that a specific audio player is embeded within my application so that all audio file (.wav) will be opened by this player. And this player should not have any UI.
Re: embed audio player [message #1005196 is a reply to message #1005159] Thu, 24 January 2013 16:10 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
So did you google for how to play .wav files in Java? Why not using
AudioSystem? Something you should have found using Google in about a minute.
Tom
Am 24.01.13 16:14, schrieb Johnny Qin:
> Thanks Sumit.
> The use case is:
> not have any UI.
Re: embed audio player [message #1005217 is a reply to message #1005196] Thu, 24 January 2013 16:59 Go to previous message
Member
Thanks Tom. I was in the wrong direction and kept looking for some sort of audio player plugins to include. Thanks!
Previous Topic:Ghost Cells in Eclipse RCP
Next Topic:Enable/disable command handlers depending on command parameter
Current Time: Sun May 27 05:32:09 GMT 2018
Powered by FUDForum. Page generated in 0.01860 seconds
