Home » Language IDEs » ServerTools (WTP) » Plans for URIResolverExtension for public consumption?
Plans for URIResolverExtension for public consumption? [message #145805] Tue, 01 November 2005 15:28 Go to next message
Steve Speicher is currently offline Steve SpeicherFriend
Member
Here's a high-level summary of what I'm trying to do:
I want to be able to associate an XML file with a plugin contributed
XML Schema, using resource metadata. I want validation and content
assist to use my contributed schema instead of the XML Catalog or
xsi:schemaLocation. I'm doing this because I don't want to change the
XML file (to include specific schemaLocations) the user has but enable
them to validate it and edit it using alternate schemas. I also don't
want to contribute it to the XML Catalog as it would affect too many files.
I was going to do this by simply using the extension point
org.eclipse.wst.common.uriresolver.resolverExtensions to do this but
this doesn't appear to be public (still verifying if it will support my
scenario as well).
- Am I approaching the problem in the correct way?
- Will the uriresolver.resolverExtension extension point become public?
I see 2 bug reports for public APIs in WTP: 110275
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=110275> Publish APIs for
WST in WTP 1.0 and 112281
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=112281> Declare XML
Catalog Extension Point API for WTP 1.0.
Thanks in advance,
Steve Speicher
Re: Plans for URIResolverExtension for public consumption? [message #147169 is a reply to message #145805] Wed, 16 November 2005 06:14 Go to previous message
Craig Salter is currently offline Craig SalterFriend
Steve Speicher wrote:
> scenario as well).
> Thanks in advance,
> Steve Speicher
Yes, I think you're using the right approach. We're aren't planning on
making the URIResolver API public in WTP 1.0 since we're not convinced
that we have designed the API correctly at this point in time (any
feedback would be appreciated). I'm hoping we can make the URIResolver
public API in the WTP 1.5 time frame.
thanks for posting
Previous Topic:problems in creating dynamic web project
Next Topic:it feels very slow in jsp editor ...
Current Time: Fri May 25 03:42:18 GMT 2018
Powered by FUDForum. Page generated in 0.01896 seconds
