Home » Newcomers » Newcomers » I have a problem when I install UML2(I have a problem when I install UML2)
I have a problem when I install UML2 [message #1002128] Fri, 18 January 2013 01:35 Go to next message
Fan Xue is currently offline Fan XueFriend
I have a problem when I install UML2. My eclipse is Version: Indigo Service Release 1.
Or can something instead of UML2?
Thanks.
ERROR LOG:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.emf,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.ant,2.7.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.codegen,2.8.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.codegen.ecore,2.8.1.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.codegen.ecore.ui,2.8.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.codegen.ui,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.common,2.8.0.v20120911-0500
No repository found containing: osgi.bundle,org.eclipse.emf.common.ui,2.7.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.converter,2.5.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.databinding,1.2.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.databinding.edit,1.2.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.ecore,2.8.1.v20120911-0500
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.change,2.8.0.v20120911-0500
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.change.edit,2.5.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.edit,2.8.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.editor,2.8.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.xmi,2.8.0.v20120911-0500
No repository found containing: osgi.bundle,org.eclipse.emf.edit,2.8.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.edit.ui,2.8.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.exporter,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.importer,2.7.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.importer.ecore,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.importer.java,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.importer.rose,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping,2.7.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ecore,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ecore.editor,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ecore2ecore,2.7.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ecore2ecore.editor,2.5.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ecore2xml,2.7.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ecore2xml.ui,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.emf.mapping.ui,2.6.0.v20120917-0436
No repository found containing: osgi.bundle,org.eclipse.equinox.concurrent,1.0.300.v20120522-2049
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.codegen.ecore,2.8.1.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.codegen.ecore.ui,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.codegen,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.codegen.ui,2.7.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.common,2.8.0.v20120911-0500
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.common.ui,2.7.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.converter,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.databinding.edit,1.2.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.databinding,1.2.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.ecore.edit,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.ecore.editor,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.ecore,2.8.1.v20120911-0500
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.edit,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.edit.ui,2.8.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf,2.8.1.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.mapping.ecore.editor,2.7.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.mapping.ecore,2.7.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.mapping,2.7.0.v20120917-0436
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.mapping.ui,2.7.0.v20120917-0436
Re: I have a problem when I install UML2 [message #1002397 is a reply to message #1002128] Fri, 18 January 2013 13:58 Go to previous message
Fan,
Better to use the eclipse.modeling.mdt.uml2 forum. You haven't mention
which repo you're trying to install from. If you're installing into
Indigo, you should find the UML that's in the Indigo repo, which should
in your list of repos by default. Then you can be sure that all UML2's
dependencies are in your list of repos to check as well. In this case
it's clear your not including the repo that contains EMF (the correct
version of which will also be in the Indigo repo).
> Service Release 1.
> Thanks.
> ERROR LOG:
> action=).
Previous Topic:Status of the eclipse bug #211784
Next Topic:Confused Newcomer
Current Time: Fri Apr 20 14:40:56 GMT 2018
Powered by FUDForum. Page generated in 0.03337 seconds
