Home » Language IDEs » Java Development Tools (JDT) » Error occur when delete a file from package explorer
Error occur when delete a file from package explorer [message #1001601] Thu, 17 January 2013 03:03 Go to next message
huahsin68   is currently offline huahsin68 Friend
When removing a file from package explore view, I got the following error message popup, hope you guys could raise some help.
Refactoring
An unexpected exception occurred while performing the refactoring. See the error log for more details.
org/eclipse/jpt/common/utility/internal/StatefulCommandExecutor
Here is the detail extract from the log:
Exception Stack Trace
java.lang.reflect.InvocationTargetException
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.run(RefactoringWizardDialog2.java:331)
	at org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPerformFinish(RefactoringWizard.java:605)
	at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFinish(UserInputWizardPage.java:153)
	at org.eclipse.jdt.internal.ui.refactoring.reorg.DeleteWizard$DeleteInputPage.performFinish(DeleteWizard.java:185)
	at org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFinish(RefactoringWizard.java:678)
	at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.okPressed(RefactoringWizardDialog2.java:455)
	at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperation$1.run(RefactoringWizardOpenOperation.java:181)
	at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperation.run(RefactoringWizardOpenOperation.java:193)
	at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperation.run(RefactoringWizardOpenOperation.java:116)
	at org.eclipse.jdt.internal.ui.refactoring.actions.RefactoringStarter.activate(RefactoringStarter.java:38)
	at org.eclipse.jdt.internal.ui.refactoring.UserInterfaceStarter.activate(UserInterfaceStarter.java:62)
	at org.eclipse.jdt.internal.corext.refactoring.RefactoringExecutionStarter.startDeleteRefactoring(RefactoringExecutionStarter.java:284)
	at org.eclipse.jdt.internal.ui.refactoring.reorg.DeleteAction.run(DeleteAction.java:173)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:119)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:468)
	at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboard.java:786)
	at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:885)
	at org.eclipse.ui.internal.keys.OutOfOrderListener.handleEvent(OutOfOrderListener.java:76)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
	at org.eclipse.swt.widgets.Widget.wmKeyDown(Widget.java:1809)
	at org.eclipse.swt.widgets.Control.WM_KEYDOWN(Control.java:4892)
	at org.eclipse.swt.widgets.Tree.WM_KEYDOWN(Tree.java:6069)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4560)
	at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5937)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4985)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jpt/common/utility/internal/StatefulCommandExecutor
	at org.eclipse.jpt.jpa.core.JptJpaCorePlugin.buildJpaProjectManager(JptJpaCorePlugin.java:791)
	at org.eclipse.jpt.jpa.core.JptJpaCorePlugin.getJpaProjectManager_(JptJpaCorePlugin.java:784)
	at org.eclipse.jpt.jpa.core.JptJpaCorePlugin.getJpaProjectManager(JptJpaCorePlugin.java:248)
	at org.eclipse.jpt.jpa.core.internal.refactoring.AbstractJpaDeleteTypeParticipant.checkConditions(AbstractJpaDeleteTypeParticipant.java:113)
	at org.eclipse.ltk.core.refactoring.participants.ProcessorBasedRefactoring.checkFinalConditions(ProcessorBasedRefactoring.java:257)
	at org.eclipse.ltk.core.refactoring.CheckConditionsOperation.run(CheckConditionsOperation.java:85)
	at org.eclipse.ltk.core.refactoring.CreateChangeOperation.run(CreateChangeOperation.java:121)
	at org.eclipse.ltk.core.refactoring.PerformChangeOperation.run(PerformChangeOperation.java:209)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
	at org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAdapter.run(WorkbenchRunnableAdapter.java:87)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.lang.ClassNotFoundException: org.eclipse.jpt.common.utility.internal.StatefulCommandExecutor
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	... 11 more
Root exception:
	... 11 more
Session Data
eclipse.buildId=M20110909-1335
java.version=1.6.0_37
Framework arguments:  -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product
Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product -data D:\workspace -product org.eclipse.epp.package.jee.product
THanks @!
[Updated on: Thu, 17 January 2013 03:03]
Report message to a moderator
Re: Error occur when delete a file from package explorer [message #1001739 is a reply to message #1001601] Thu, 17 January 2013 10:05 Go to previous message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Thanks to this part of the stack trace that you have provided:
We can see that the plugin "org.eclipse.jpt.jpa.core" has provided a refactoring participant which is triggered when a file is deleted from the workspace.
I don't know why but for some reason, the work of this class crashes due to a "NoClassDefFoundError". Since the plugin "org.eclipse.jdt.jpa" seems to come from the Dali project, you should ask the same question on the Web Tools Project forum. there may be a problem with the installation of the plugin or it may be a known issue for them. You should mention a problem with the Dali JPA Tools refactoring participant.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Previous Topic:Stable JDT anywhere
Next Topic:Development with eclipse
Current Time: Mon Jun 18 06:21:39 GMT 2018
Powered by FUDForum. Page generated in 0.01588 seconds
