Home » Eclipse Projects » Remote Application Platform (RAP) » JS-libraries in custom widgets
JS-libraries in custom widgets [message #1001242] Wed, 16 January 2013 09:56 Go to next message
Christian Hager is currently offline Christian HagerFriend
Member
Hello everyone,
I was wondering if someone could tell me what's the best way to integrate JS-libraries and CSS-Resources in custom widgets?
I'm especially interessted in the following to cases:
  1. How would I best integrate a js-library like ckeditor consisting of various js-files, css-files and images?
  2. How would I best integrate a js-library like jquery which which would potentially be used by several of my custom widgets
Thanks in advance for any help or hints.
Christian
Re: JS-libraries in custom widgets [message #1001766 is a reply to message #1001242] Thu, 17 January 2013 10:39 Go to previous message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi.
I'll assume we are talking about RAP 2.0.
There are three ways to register the resources: The
ApplicationConfiguration[1] (non-workbench applications only), the
org.eclipse.rap.ui.resources extension point (workbench applications
only) or using the ResourceManager[2] directly.
Using ApplicationConfiguration is simple, but then the resource
registration is part of your application instead of your custom widget.
Using the ResourceManager (e.g. in the custom widgets constructor) is
more flexible. But then you need to check first if the resource is
already registered, so it's not registered multiple times.
You also need deliver the JS to the client (except when using the
extension point), which can be done with the new JavaScriptLoader[3]
service. Here it is not necessary to check if the content was already
loaded, JavaScriptLoader already does that.
I would suggest to have a separate bundle used by the custom widgets. It
will have a util class that uses ResourceManager and JavaScriptLoader to
ensure the library is registered and loaded on the client. The custom
widgets could then call something like: JQuery.ensure();
If you have trouble with the details, just ask me.
Greetings,
Tim
[1] application.addResource( name, loader );
[2] RWT.getResourceManager(), register, isRegistered, and getLocation
[3] RWT.getClient().getService( JavaScriptLoader.class ).require( url );
> Christian
Tim Buschtöns
Twitter: @EclipseRAP
Previous Topic:plugin.xml, i18n and umlauts
Next Topic:Operation "listen" on target "w4" of type "rwt.widgets.MenuBar" failed
Current Time: Mon May 28 04:56:24 GMT 2018
Powered by FUDForum. Page generated in 0.01738 seconds
