Re: How to use default value in a local data set [message #1000811 is a reply to message #1000650] |
Tue, 15 January 2013 13:10 |
Alexander Kolesov Messages: 43 Registered: November 2012 |
Member |
Hi Alex,
I' better describe my expectations in pictures
Here is defined test case with default values specified:
I add it to test suite:
Here are default values being set as expected:
I need to call this case severeal times for various values of parameter FIRST_NAME.
So I define values for the parameter:
Now I expect to have data set with values I entered for FIRST_VALUE and all other values propagated from default settings. However other values are empty:
So, I need to manually enter missing values that is quite uncomfortable.
Eg: to repeat case with 10 parameters 10 times for only one of paraemters I will need to fill 81 more absolutelly unnesseccary for current scenario fields.
Alex.
Attachment: ref_case.PNG
(Size: 13.17KB, Downloaded 530 times) -
Attachment: test_suite.PNG
(Size: 3.18KB, Downloaded 461 times) -
Attachment: def_values.PNG
(Size: 19.59KB, Downloaded 528 times) -
Attachment: f_name.PNG
(Size: 7.35KB, Downloaded 495 times) -
Attachment: problem.PNG
(Size: 9.21KB, Downloaded 504 times)
[Updated on: Tue, 15 January 2013 13:11] Report message to a moderator
FUDForum. Page generated in 0.02448 seconds
