Home » Eclipse Projects » BIRT » Depth of legend elements?
Depth of legend elements? [message #144997] Fri, 17 March 2006 10:30 Go to next message
mr. burns is currently offline mr. burnsFriend
I want to know if it is possible to set/change the depth of the legend
elements? Where?
I can set the depth of the bars / pies etc. to what I want, this works fine.
But the legend elements have always same depth, independent from the series
(bar / pie, etc) settings.
Any idea?
Re: Depth of legend elements? [message #146748 is a reply to message #144997] Wed, 22 March 2006 08:10 Go to previous messageGo to next message
David Michonneau is currently offline David MichonneauFriend
It's currently hard-coded to 3. Probably it's not using the series' depth to
avoid the legend to look strange if the depth is too big. What is the
scenario where you need to set this depth?
David
"Mr. Burns" <Mr._Burns@web.de> wrote in message
news:dve39g$lc5$1@utils.eclipse.org...
> Hello,
> elements? Where?
> fine.
> series (bar / pie, etc) settings.
> Any idea?
Re: Depth of legend elements? [message #152262 is a reply to message #146748] Mon, 10 April 2006 13:58 Go to previous messageGo to next message
Hello David,
I need this just to keep the depth of the legend same as the depth of the
bars in e.g. a barchart.
Just to have the same depth of both elements.
Thanks for further info on this issue.
Re: Depth of legend elements? [message #154820 is a reply to message #152262] Thu, 20 April 2006 13:27 Go to previous message
Please file an enhancement regarding this in bugzilla.
David
news:e1doa3$rvp$1@utils.eclipse.org...
> Hello David,
Previous Topic:question about visibility object
Next Topic:Meter Chart can't Show
Current Time: Fri May 25 01:36:36 GMT 2018
Powered by FUDForum. Page generated in 0.02369 seconds
