Re: EMF Compare models containing "Non-Model Intermediary View Objects" [message #1004581 is a reply to message #998604] |
Wed, 23 January 2013 13:55 |
You got most of this right : CompareUI cannot find the proper content type for your "virtual" objects.
Seen from afar, this does not look like a bug : unknown types fall back to text comparison. However, it is probably the responsibility of EMF Compare to set correct content-types for these special model elements. Could you raise an enhancement request on the buzilla with two models that will allow us to reproduce the use case.
We will need to make sure the UI is extensible enough for users to add their own content types for their own elements, but this case seems like something that should go in the generic code base.
Laurent Goubet
Obeo
[Updated on: Wed, 23 January 2013 13:55] Report message to a moderator
FUDForum. Page generated in 0.02945 seconds
