Home » Eclipse Projects » Hudson » System configuration page stuck at "LOADING'
System configuration page stuck at "LOADING' [message #998343] Wed, 09 January 2013 20:55 Go to next message
Daniel Desjardins is currently offline Daniel DesjardinsFriend
We have upgraded to Hudson 3.0.0 and now when I try to go to
Manager Hudson -> Configure System, the configuration fields are loaded for the most part but the gray LOADING background stays there.
How do I go to fix that?
Thank you all for your help!
Daniel
Re: System configuration page stuck at "LOADING' [message #998349 is a reply to message #998343] Wed, 09 January 2013 21:13 Go to previous messageGo to next message
Steve Christou is currently offline Steve ChristouFriend
It sounds like a plugin might be out-dated and might have thrown an error. What plugins do you have installed and their versions? Also, do you see anything unusual in the logs (http://localhost:8080/log/all)?
Steve.
 * @author Steven Christou
 * @dev    Hudson-ci
Re: System configuration page stuck at "LOADING' [message #998361 is a reply to message #998349] Wed, 09 January 2013 21:34 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
BTW, I just fixed the issue with Mantis plugin that causes similar issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=397705
Winston Prakash
Eclipse Hudson team
Re: System configuration page stuck at "LOADING' [message #998379 is a reply to message #998349] Wed, 09 January 2013 22:05 Go to previous messageGo to next message
I do have quite a list of plugins:
Hudson MSBuild Plugin 1.14-h-1
Hudson REST Plugin 2.1.2
SSH plugin 1.1
Last Success Description Column Plugin 1.0
JUnit Attachments Plugin 1.1
Python Plugin 1.1
Email-ext plugin 2.10
Batch Task Plugin 1.14
Hudson Subversion Plug-in 2.3.6-h-1
Hudson SSH Slaves plugin 3.0.2
Static Analysis Utilities 1.42-h-1
XPath Provider Plugin 1.0.1
Subversion tagging plugin 1.16
Description Setter Plugin 1.7
slave-status 1.4
Hudson Translation Assistance plugin 1.10-h-1
Copy Artifact Plugin 1.23-h-1
Job Health Report 1.3
Hudson promoted builds plugin 2.4
Active Directory plugin 1.17
Hudson BIRT Charts Plugin 3.0.3
Hudson build timeout plugin 1.7-h-1
PMD Plug-in 3.29-h-1
WebSVN2 Plugin 0.9
Hudson CVS Plug-in 2.2.0
Warnings Plug-in 4.6-h-1
Backup plugin 3.0.0
Dashboard View 2.3-h-1
JNA Native Support Plugin 3.0.2
Hudson JIRA plugin 1.36-h-1
Static Analysis Collector Plug-in 1.28-h-1
Hudson disk-usage plugin 0.17-h-1
I only see INFO messages in my log...this is why I am puzzled.
Any idea?
Re: System configuration page stuck at "LOADING' [message #998400 is a reply to message #998379] Wed, 09 January 2013 23:03 Go to previous messageGo to next message
I installed all these plugins on a test hudson instance and ran into no issues. Could you try to get a new copy of hudson and re-install it? There might have been something that happened while the .war file and it contains missing/corrupt data.
Steve.
Edit:
Actually a good way to debug this would be to disable all the plugins, verify the configuration page loads, and then keep enabling one by one until you find the culprit.
 * @dev    Hudson-ci
[Updated on: Wed, 09 January 2013 23:06]
Report message to a moderator
Re: System configuration page stuck at "LOADING' [message #998442 is a reply to message #998400] Thu, 10 January 2013 01:35 Go to previous messageGo to next message
I noticed that you have Active Directory plugin 1.17. This plugin may not load correctly. I'm in the process of releasing a new version. Let me know if you could test it for me.
Winston Prakash
Eclipse Hudson team
Re: System configuration page stuck at "LOADING' [message #998707 is a reply to message #998442] Thu, 10 January 2013 14:38 Go to previous messageGo to next message
sure I could test the new active directory plugin.
Re: System configuration page stuck at "LOADING' [message #1007666 is a reply to message #998707] Wed, 06 February 2013 22:54 Go to previous messageGo to next message
Did you get a chance to try the new Active Directory plugin. Another thread says the new release seems to work
Winston Prakash
Eclipse Hudson team
Re: System configuration page stuck at "LOADING' [message #1007856 is a reply to message #1007666] Thu, 07 February 2013 18:43 Go to previous message
I am running the Active Directory Plugin verson 1.31-h1 and it DID fix my loading issue Smile
Previous Topic:Hudson and automatic JDK
Next Topic:How to extract metrics from a report file
Current Time: Thu Feb 22 17:18:27 GMT 2018
Powered by FUDForum. Page generated in 0.02151 seconds
