Home » Eclipse Projects » BIRT » How to install additional plugin in RCP Designer(How to install additional plugin in RCP Designer)
How to install additional plugin in RCP Designer [message #997367] Mon, 07 January 2013 08:10 Go to next message
Mark Mescher is currently offline Mark MescherFriend
Hi BIRT Community,
I have implemented a small ecplise plugin to upload a rptdesign to our reportserver by right clicking it (and then select an upload action).
This works fine in standard eclipse by using either the dropins folder or the update manager.
But how can I add my plugin to RCP Designer?
Update Manager is not available here and the dropins-folder seems not to work.
Does anyone know what I have to do?
Thank you a lot and best regards
Mark
Re: How to install additional plugin in RCP Designer [message #997517 is a reply to message #997367] Mon, 07 January 2013 23:47 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
It should just be the plugins folder. Have you tried installing any other plugins? Or just your own?
Michael
Developer Evangelist, Silanis
Re: How to install additional plugin in RCP Designer [message #997539 is a reply to message #997517] Tue, 08 January 2013 08:36 Go to previous messageGo to next message
Hi Michael,
no, this is not working for me. To make sure I didn't have done something wrong I have created another plugin - the normal eclipse Hello World sample. I have exported this using the export wizard.
I have copied the resulting jar file to the dropins-folder and in a second try to the plugin folder of a normal Eclipse installation. Both ways are working, as result there is a new "Hello World" menu.
In the rcp-Designer, both ways are not working. There is no samle menu and in installation details the plugin is not listed.
So what is the best way to enhance the rcp-Designer. If a manual copy of the plugin is not support, is there maybe a way to enable the update manager? Than I could try to provide an update site.
Thanx and best regards
Mark
Re: How to install additional plugin in RCP Designer [message #998351 is a reply to message #997539] Wed, 09 January 2013 21:15 Go to previous messageGo to next message
Sorry. I should have asked this before. What's your BIRT version?
Michael
Re: How to install additional plugin in RCP Designer [message #998528 is a reply to message #997367] Thu, 10 January 2013 07:09 Go to previous messageGo to next message
I'm using current RCP Designer 4.2.1.
I have attached my second try (sample plugin without code modification from me) as jar.
As described it should enhance the menu by an Hello World sample.
Bye
Mark
Re: How to install additional plugin in RCP Designer [message #998800 is a reply to message #998528] Thu, 10 January 2013 18:08 Go to previous messageGo to next message
I'm seeing the same thing as you. I tried your plug-in and I tried one from the recent BIRT Exchange plug-in contest. Neither worked. Let me look into this, a little more, and I'll let you know if I find anything out about why.
Michael
Re: How to install additional plugin in RCP Designer [message #998810 is a reply to message #998800] Thu, 10 January 2013 18:20 Go to previous messageGo to next message
Thank you for your analysis. I will wait for your results. Maybe it can be fixed in next release...
Mark
Re: How to install additional plugin in RCP Designer [message #998959 is a reply to message #998810] Fri, 11 January 2013 03:15 Go to previous messageGo to next message
I'll try in an older version, tomorrow, to see if this is something new, with 4.2.1. If it is, I'll have you log a bug for this.
Michael
[Updated on: Fri, 11 January 2013 03:16]
Report message to a moderator
Re: How to install additional plugin in RCP Designer [message #999129 is a reply to message #998959] Fri, 11 January 2013 11:57 Go to previous messageGo to next message
Hi Michael,
I have tried it in 3.7, in this version it works as expected by just copiing the jar to plugins-folder.
So something seems to be broken from 3.7 -> 4.2.1.
Best regards
Mark
Re: How to install additional plugin in RCP Designer [message #999284 is a reply to message #999129] Fri, 11 January 2013 18:18 Go to previous messageGo to next message
Great. Thanks for checking that out. Can you please log a bug for this, in the bugzilla, and put the bug info in here, for future reference? Thanks!
Michael
Re: How to install additional plugin in RCP Designer [message #1000206 is a reply to message #999284] Mon, 14 January 2013 09:02 Go to previous messageGo to next message
I have created bug 398058.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=398058
Re: How to install additional plugin in RCP Designer [message #1000959 is a reply to message #1000206] Tue, 15 January 2013 19:26 Go to previous message
Thanks for the update!
Michael
Previous Topic:Charts in a crosstab column
Next Topic:Enhancing Birt Outline View
Current Time: Sun Feb 25 00:38:11 GMT 2018
Powered by FUDForum. Page generated in 0.02239 seconds
