| diagram palette [message #997127] |
Thu, 03 January 2013 15:29  |
joe fessler Messages: 4 Registered: December 2012 |
Junior Member |
Going from bad to worse, I installed a fresh Juno and went about adding the modeling and Papyrus items. It now seems that I can add a new diagram (model.di) but there is no palette. Prior to the fresh installation of Juno, I was using "updated" Indigo-to-Juno but ran into issues trying to generate Java code from the model; but at least the palette displayed and I could build simple diagrams.
Just speculating... missing plugin/dependency? version conflicts? user stupidity?
Yeah, I'm betting on that last one.
Could anyone please provide a way forward for me?
| Re: diagram palette [message #997262 is a reply to message #997172] |
Fri, 04 January 2013 14:24   |
Junior Member |
Same story with a new workspace.
Now, an observation (but not a pleasant one):
In this new workspace, right-click->New->Other->Papyrus->Papyrus Project follows through the usual wizard. If a project is created by naming the project and clicking Finish, subsequent opening of the model.dl produces an empty tab panel.
If, instead, the Next button is clicked, progressing through selection of the diagram language (UML), checking UML Class Diagram (e.g.) and THEN Finish, the New Papyrus Project dialog remains active and a second click of Finish closes the procedure. The result here though produces a tab panel with no label. Closing that tab and attempting to reopen the model.dl throws a NullPointerException.
At no time does a palette show.
The observation above also applies to the old workspace, so at least that much is consistent.
| Re: diagram palette [message #997502 is a reply to message #997374] |
Mon, 07 January 2013 15:08  |
Junior Member |
Indeed there are errors. After first clearing the error log, the attached file shows entries starting with the attempt to add a new Papyrus project to the workspace. As mentioned earlier, the empty tab presents itself (just shows the close X in the tab and the panel is blank). After Xing that tab and attempting to reopen the .di, the NPE is thrown.
This time, after checking the box for class diagram, then Finish, the process seemed to complete and the New Papyrus Project dialog closed.
On an immediately subsequent project addition using the same sequence of events, the Finish button did not close the dialog and produced:
Unhandled event loop exception
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3112)
at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:3020)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:3002)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2998)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2962)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2953)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.openDiagram(CreateModelWizard.java:383)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.createAndOpenPapyrusModel(CreateModelWizard.java:181)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.performFinish(CreateModelWizard.java:156)
at org.eclipse.papyrus.uml.diagram.wizards.NewPapyrusProjectWizard.performFinish(NewPapyrusProjectWizard.java:114)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.GeneratedMethodAccessor110.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:500)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1045)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:940)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:587)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:542)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.01587 seconds
