Home » Eclipse Projects » Buckminster » Null Pointer Exception when building update site following the tutorials
Null Pointer Exception when building update site following the tutorials [message #996944] Thu, 03 January 2013 09:02 Go to next message
Dao Hoang is currently offline Dao HoangFriend
I create an update site project in Eclipse 4.2.0 follow the tutorial http://wiki.eclipse.org/Buckminster/Examples/Building_an_Update_Site#Creating_an_index.html_file
I call action "build.site" from UI and got a NullPointerException in error log
<eclipse> \configuration\org.eclipse.osgi\bundles\271\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:348: java.lang.NullPointerException: java.lang.NullPointerException
<target name="create.legacy.site" depends="create.legacy.site.common">
<buckminster.updateSiteGenerator versionProperty="site.version" outputfile="${site.xml}" template="${sp:template}">
<buckminster.filesetgroup value="${fs:features}"/>
</buckminster.updateSiteGenerator>
</target>
Here is the log file
!ENTRY org.eclipse.buckminster.core 4 293 2013-01-03 15:43:45.145
!MESSAGE org.eclipse.core.runtime.CoreException: D:\Projects\Eclipses\eclipse\configuration\org.eclipse.osgi\bundles\271\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:348: java.lang.NullPointerException
!STACK 1
at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
at org.eclipse.buckminster.ui.InvokeActionJob.runInWorkspace(InvokeActionJob.java:67)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: D:\Projects\Eclipses\eclipse\configuration\org.eclipse.osgi\bundles\271\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:348: java.lang.NullPointerException
at org.eclipse.buckminster.pde.ant.UpdateSiteGeneratorTask.execute(UpdateSiteGeneratorTask.java:73)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.GeneratedMethodAccessor47.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:392)
at org.apache.tools.ant.Target.performTasks(Target.java:413)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:672)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:498)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318)
... 9 more
Caused by: java.lang.NullPointerException
at com.sun.org.apache.xml.internal.serializer.ToStream.writeAttrString(Unknown Source)
at com.sun.org.apache.xml.internal.serializer.ToStream.processAttributes(Unknown Source)
at com.sun.org.apache.xml.internal.serializer.ToStream.closeStartTag(Unknown Source)
at com.sun.org.apache.xml.internal.serializer.ToStream.startElement(Unknown Source)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerHandlerImpl.startElement(Unknown Source)
at org.eclipse.buckminster.pde.tasks.SaxableSite.writeFeatures(SaxableSite.java:112)
at org.eclipse.buckminster.pde.tasks.SaxableSite.emitElements(SaxableSite.java:191)
at org.eclipse.buckminster.sax.AbstractSaxableElement.toSax(AbstractSaxableElement.java:41)
at org.eclipse.buckminster.pde.tasks.SaxableSite.toSax(SaxableSite.java:147)
at org.eclipse.buckminster.sax.Utils.serialize(Utils.java:308)
at org.eclipse.buckminster.pde.tasks.UpdateSiteGenerator.run(UpdateSiteGenerator.java:132)
at org.eclipse.buckminster.pde.ant.UpdateSiteGeneratorTask.execute(UpdateSiteGeneratorTask.java:67)
... 29 more
!SUBENTRY 1 org.eclipse.ant.core 4 1 2013-01-03 15:43:45.145
!MESSAGE D:\Projects\Eclipses\eclipse\configuration\org.eclipse.osgi\bundles\271\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:348: java.lang.NullPointerException
It did not bring me further to figure out what is missing or wrong.
Some one please help me fix it?
Smile Smile
Re: Null Pointer Exception when building update site following the tutorials [message #997662 is a reply to message #996944] Mon, 07 January 2013 12:38 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Dao,
From the looks of it, there are some problems during the writeout of
the site.xml file. Not sure why it happens. I'd like to ask you though,
why are you creating an old legacy update site? That format has been
deprecated for several years now. I wouldn't recommend anyone to use it
today.
- thomas
> error log <eclipse>
> at
> </target>
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> ... 9 more
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 29 more
> !MESSAGE
Re: Null Pointer Exception when building update site following the tutorials [message #999083 is a reply to message #997662] Fri, 11 January 2013 09:50 Go to previous messageGo to next message
Hi Thomas,
I wanted to make an update-site including required features for our tool and I found this tutorial.I did and success with this project before with Eclipse 3.6 and compatible Buckminster.
But now, our product is upgraded to Eclipse 4.2, I re-used the old project and got this problem. What I should do? Create a new project and follow exactly the tutorial, or could you please suggest me a newer tutorial to move on.
Thanks and regards,
Dao
Smile Smile
Re: Null Pointer Exception when building update site following the tutorials [message #1001251 is a reply to message #999083] Wed, 16 January 2013 10:21 Go to previous message
Would it be possible for you to simply skip the legacy site and just
create a proper p2 site? A 'site.xml' shouldn't be needed anymore.
- thomas
On 2013-01-11 10:50, Dao Hoang wrote:
> Hi Thomas,
> Thanks and regards,
> Dao
Previous Topic:Site.p2-generated product includes launcher source bundle
Next Topic:Bucky maven2 reader cannot read a repo that is created by B3 aggr
Current Time: Tue Jun 19 12:58:41 GMT 2018
Powered by FUDForum. Page generated in 0.01822 seconds
