Home » Eclipse Projects » GEF » how do I drag an object from my outline view and drop it into GEF editor?
how do I drag an object from my outline view and drop it into GEF editor? [message #996859] Thu, 03 January 2013 03:42 Go to next message
Julie Pat is currently offline Julie PatFriend
I would like to drag an object from my outline view and drop it into the GEF editor. I can drag an object from my palettte into GEF editor just fine by doing the following listed below.
Is there something equivalent to this only dragging from the outline view into the GEF editor?
Thanks in advance...
public class MyMenuBoardEditor extends GraphicalEditorWithFlyoutPalette{
protected void initializeGraphicalViewer() {
viewer.addDropTargetListener(new MyTemplateTransferDropTargetListener(viewer));
protected PaletteViewerProvider createPaletteViewerProvider() {
return new PaletteViewerProvider(getEditDomain()) {
protected void configurePaletteViewer(PaletteViewer viewer) {
super.configurePaletteViewer(viewer);
viewer.addDragSourceListener(new TemplateTransferDragSourceListener(viewer));
protected class TemplatePage extends ContentOutlinePage {
public TemplatePage() {
super(new TreeViewer());
public void init(IPageSite pageSite) {
super.init(pageSite);
// I think I need to add a drag listener here. But what listener should be added?? I saw some code for org.eclipse.ui.parts.TreeViewerTransferDropListener, etc in the old versions of GEF, but they seem to be removed from the new jars.... I am using GEF 3.7
//getViewer().addDragSourceListener(What listener should go here????);
public class MyTemplateTransferDropTargetListener extends TemplateTransferDropTargetListener {
public MyTemplateTransferDropTargetListener(EditPartViewer viewer) {
super(viewer);
protected CreationFactory getFactory(Object template) {
return new NodeCreationFactory((Class<?>)template);
Re: how do I drag an object from my outline view and drop it into GEF editor? [message #997048 is a reply to message #996859] Thu, 03 January 2013 13:37 Go to previous messageGo to next message
Jan Krakora is currently offline Jan KrakoraFriend
Hi, this should help you
http://www.eclipse.org/articles/Article-GEF-dnd/GEF-dnd.html
Re: how do I drag an object from my outline view and drop it into GEF editor? [message #997121 is a reply to message #996859] Thu, 03 January 2013 19:54 Go to previous message
Thank you for your suggestion!
Read throught the article. Will try it on my issue. I think I need to create some sort of DragSourceListener as well on my TreeViewer used in the Outline View. Is that correct? or does the Outline View already come with DragSourceListener built in as in Navigator or Package Explorer?
Previous Topic:How can I create context menu but on hover action?
Next Topic:how can I specify different text on each of the multiple "Outline View" tabs?
Current Time: Sun May 20 18:02:36 GMT 2018
Powered by FUDForum. Page generated in 0.01390 seconds
