Home » Modeling » EMF » Usage of "org.eclipse.emf.ecore.factory_override"
Usage of "org.eclipse.emf.ecore.factory_override" [message #995931] Mon, 31 December 2012 14:57 Go to next message
Vincenzo Caselli is currently offline Vincenzo CaselliFriend
Hi all,
we are trying to use the "org.eclipse.emf.ecore.factory_override" extension point, but have some problem.
We have 2 plug-ins:
1) Model1: it defines an ecore with entity Variable
2) Model2: defines an ecore with entity CustomVariable that has Model1.Variable as super type
Model2 has also a JUnit class that has the following code:
Variable var = Model1Factory.eINSTANCE.createVariable();
var.setName("a");
System.out.println(var.getClass());
obviously the output is:
class model1.impl.VariableImpl
now, in Model2 plugin, we add the extension
 <extension
         point="org.eclipse.emf.ecore.factory_override">
      <factory
            class="org.eclipse.emf.model2.EFactory1"
            uri="http://model1/1.0">
      </factory>
   </extension>
and create the class
public class EFactory1 extends Model1FactoryImpl {
	public Variable createVariable() {
		return Model2Factory.eINSTANCE.createCustomVariable();
still the object created is
What is the correct way to override the EMF Model1 Factory?
Thank you
and Happy New Year!!!!!
Vincenzo
P.S. I uploaded this sample
Re: Usage of &quot;org.eclipse.emf.ecore.factory_override&quot; [message #995948 is a reply to message #995931] Mon, 31 December 2012 15:58 Go to previous messageGo to next message
Vincenco,
Comments below.
On 31/12/2012 3:57 PM, Vincenzo Caselli wrote:
> Hi all,
> We have 2 plug-ins:
No, there shouldn't be two models. Only one, with alternative
implementation classes.
> var.setName("a");
> <extension
> <factory
> </factory>
> </extension>
This has a public constructor?
> @Override
No, the overriding factory should create the proper instances. The
eClass() of what it creates should be the right one from Model1.
> Thank you
> Vincenzo
I'll have a closer look when I have more time, but your use case sounds
not so good...
Re: Usage of &quot;org.eclipse.emf.ecore.factory_override&quot; [message #996643 is a reply to message #995948] Wed, 02 January 2013 15:30 Go to previous message
Sorry Ed,
it is working!
My fault was to launch a test from JUnit Embarrassed : I just called the same test from a rcp plug-in and all is working fine!!!
Thank you Ed
Cheers
Vincenzo
Previous Topic:Embedding arbitrary models in a model
Next Topic:[CDO] StringIndexOutOfBoundsException thrown for a column containing a single space using H2
Current Time: Mon Feb 19 14:25:15 GMT 2018
Powered by FUDForum. Page generated in 0.03540 seconds
