Home » Newcomers » Newcomers » Problems with debugger
Problems with debugger [message #994816] Fri, 28 December 2012 10:58 Go to next message
Karl Dewe is currently offline Karl DeweFriend
Hello Guys,
I use Eclipse + CDT + yagarto GCC + J-LinkGDBServer for programming and debugging an AT91SAM9XE256 microcontroller. But when I program the chip it works fine. But debugging doesn't work so well. Of course I'm sure that the programm is right. Furthermore the points of the occuring error changes. So I thing that there is a problem with the debugger is there anybody who knows more about this or who can give me a hint to solve my problem?
Best Regards,
Karl
Re: Problems with debugger [message #994929 is a reply to message #994816] Fri, 28 December 2012 17:08 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
On 12/28/2012 06:16 AM, Karl Dewe wrote:
> Hello Guys,
> problem?
> Best Regards,
> Karl
You'll likely find that, because you're debugging C/C++, you'll be
better off asking this in the Eclipse CDT forum.
Previous Topic: report parameter button
Next Topic:JAX-RS Plugin
Current Time: Mon May 28 05:09:48 GMT 2018
Powered by FUDForum. Page generated in 0.03020 seconds
