Home » Modeling » EMF » [CDO-Net4j] Compression of Net4j/CDO streams
[CDO-Net4j] Compression of Net4j/CDO streams [message #991500] Wed, 19 December 2012 14:43 Go to next message
Guido Scalise is currently offline Guido ScaliseFriend
Hi!
is it possible to add compression to the Net4j TCP connector? We are trying to work with a repository, accessing it over a 20Mbit and 50Mbit VPNs and the performance is not as good as we expected.
We've tweaked the view prefetch options and the session collection retrieval policy and the performance improved a bit, but we'd like to gain more performance, and being able to compress the Net4j stream seems like the next logical step.
Eike, do you see any drawbacks on this? I was thinking of a *very* lightweight stream compressor so as not to overload the server CPU with (CPU intensive) stream compression tasks, but maybe you've already implemented this in some way.
Guido
Re: [CDO-Net4j] Compression of Net4j/CDO streams [message #991825 is a reply to message #991500] Thu, 20 December 2012 09:28 Go to previous message
Eike Stepper is currently offline Eike StepperFriend
Am 19.12.2012 15:43, schrieb Guido Scalise:
> Hi!
> step.
> some way.
You can add IStreamWrappers to the protocol instances that are created per CDOSession:
org.eclipse.net4j.signal.ISignalProtocol.setStreamWrapper(IStreamWrapper)
org.eclipse.net4j.signal.ISignalProtocol.addStreamWrapper(IStreamWrapper)
A simple example is in SignalStreamWrappingTest.
These components are IContainers that emit IContainerEvents when new elements are added:
IAcceptor
IConnector
IConnectors (both on client and server side) have IChannels and an IChannel has an ISignalProtocol
Let me know if you need more hints ;-)
Cheers
/Eike
http://www.esc-net.de
Previous Topic:@ForeignKey annotation not working in all cases
Next Topic:[CDO] Using the DB Mapping to populate queries
Current Time: Sun Feb 18 09:25:26 GMT 2018
Powered by FUDForum. Page generated in 0.01892 seconds
