Home » Eclipse Projects » BIRT » Adding an object to the application context! (Book example: Integrating and Extending)(I can't get the application context in my report!)
Adding an object to the application context! (Book example: Integrating and Extending) [message #991469] Wed, 19 December 2012 11:20 Go to next message
Samo B. is currently offline Samo B.Friend
Member
Hi all,
I'm new at BIRT and trying to work into it. I'm using the book "Integrating and Extending BIRT".
In the initial situation is that I have a jsp file like this:
	java.lang.String teststr = "MyTest";
	session.setAttribute("AppContextKey", teststr);
	java.lang.String stringObj = "This test my Application Context From the Viewer";
	session.setAttribute("AppContextValue", stringObj);
	String redirectURL = "LINK TO URL";
	response.sendRedirect(redirectURL);
I also have a report file which is named AppContext.rptdesign.
Aferwards I'm trying to display the string in a data item.
The expression of the data item is:
try{
	MyTest.toString();
}catch(e){
	"My Object Was not Found";
If I start run the Application I don't get the String! It can't find the Object.
In the book is and additional code snippet like this:
config = new EngineConfig();
HashMap hm = config.getAppContext();
hm.put("MyTest", stringObj);
config.setAppContext(hm);
Unfortunately I dont't know where to add this and there is not a description about it.
Samet
Re: Adding an object to the application context! (Book example: Integrating and Extending) [message #991551 is a reply to message #991469] Wed, 19 December 2012 18:08 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Samet
This code:
Is only if you are using the engine api. Are you using the Viewer? If so you have to add a jsp page to the viewer with code like:
and call it before going into the report. the LINK to URL should be the url to view the report.
Jason
Re: Adding an object to the application context! (Book example: Integrating and Extending) [message #991631 is a reply to message #991551] Wed, 19 December 2012 22:18 Go to previous messageGo to next message
Member
Hey Jason,
first of all thank you for replying.
Yes, I'm using the BIRT viewer. I chose a wrong description with "Link to URL"
it should be "Linkt to the report" so there is already the link to my report.
Just to clarify:
If have a web project with the jsp file (the code like you can see above) and a project which includes my report.
I can start my jsp file and after that it is forwarding to the report but I still can't get the AppContext in my report to display the variable.
regards,
Samet
Re: Adding an object to the application context! (Book example: Integrating and Extending) [message #992048 is a reply to message #991631] Thu, 20 December 2012 18:56 Go to previous messageGo to next message
Is the JSP that you added in the same web app context or a different one?
Jason
Re: Adding an object to the application context! (Book example: Integrating and Extending) [message #992274 is a reply to message #992048] Fri, 21 December 2012 09:01 Go to previous message
Member
I'm not sure what do you mean with the web app context?!
Could you explain it?
Samet
Previous Topic:.getExpressionValue("row[CUSTOMERNAME]" returns a NULL ! WHY?
Next Topic:Yearly/Quarterly Report in Crosstab
Current Time: Tue Jan 16 09:52:03 GMT 2018
Powered by FUDForum. Page generated in 0.01811 seconds
