Home » Eclipse Projects » Virgo » How to disable the Admin Web Console
How to disable the Admin Web Console [message #991388] Tue, 18 December 2012 20:51 Go to next message
Jeremy Taylor is currently offline Jeremy TaylorFriend
I'm currently running Virgo 3.5. Is there a properties file I can edit to disable the Admin Web Console? If not, how can I secure it (https only)?
Re: How to disable the Admin Web Console [message #991403 is a reply to message #991388] Tue, 18 December 2012 22:26 Go to previous message
Chris Frost is currently offline Chris FrostFriend
The admin console is just an application in the pickup directory. If you don't want to use it then just remove it from the pickup directory and it will be gone. HTTPS is currently not supported for the Admin console but if it is something you would like to see then please raise an enhancement.
https://bugs.eclipse.org/bugs/
Thanks, Chris
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Previous Topic:Can virgo(tomcat) hot deploy a web bundle which is in a plan
Next Topic:Snaps Host using Spring
Current Time: Sat Feb 24 22:30:19 GMT 2018
Powered by FUDForum. Page generated in 0.01213 seconds
